12-09-2012, 02:29 AM
#166 | |
Oddometer: 177
I would fix 2 of them to sell and the other one keep it Don´t forget to post them |
12-18-2012, 05:05 AM
#167 |
Oddometer: 177
Hi guys, just thought I´d give some updates on the big donkey.
![]() ![]() This thing is a hoot to ride in its element There are a few things to tune but for the most part it´s great, it pulls and pulls and pulls
12-18-2012, 05:40 AM
#168 |
Oddometer: 177
I´ll make a video as soon as possible, I promise.
I have a few adjustments to make though. Suspension: after rebuilding and assemble, I just left everything at midway and didn´t even set the sag. That was an oversight and it shows big time. The rear doesn´t complain, at least with the medium pace that I´ve run at. The front is not so peaceful. At the top of 3rd, headshake sets in. I´m guessing that 15mm down on the front forks is too much and the rear sag really has a happy place. Vibration: i know this thumpers do vibrate, but I get a strange one when accelerating from idle up to medium rpms. It´s not that hand and feet numbing type, it seems like when the engine is not held tight on its mounts. I have to check them but I´m pretty sure they´re good. It doesn´t make any strange or out of place noises though. Do you think that the shaving fof the flywheel has anything to do with it? I just shaved around 400grs. Carb:I´ve fitted the 40mm FCRmx with 165/40 and it runs as is but I´m way too rich on the main and lean on the pilot. A NCVT, OBEMN needle, 158,160 MJ, 42,45 PJ and 70,80 LJ are on the way to sort it out. I´ll make the AP mod too and I´ll follow the lead of a guy on Thumpertalk that jetted on a dyno, so my guessing and wasted money will be reduced. Apart from that, she rips |
12-18-2012, 05:47 AM
#169 |
Oddometer: 177
Left to right: Djubi the old girl, my younger sister, my girl and the 2 latest additions to the family, Bob `the pirate` Marley
and the Big Donkey ![]() ![]()
12-18-2012, 06:20 AM
#170 |
Oddometer: 177
So, riding impressions.
On the road: I don´t care I have other bikes for that.Can´t say about singletracking her since there´s not so much of that around here. Countryside and 2 Track: Lots of tractable power, easy to ride slow, demanding, but fun, when faster. I do not feel she´s heavy like many say, it´s not a lightweight but it´s very manageble and the power she put on the ground helps. I´m 5'10, 85kg, fit athletic build and I´m sure that it helps to manhandle her, but I´m a bit suprised with the easy handling after reading so many guys complaining about the weight. Man up, build some muscle and she wont be that bad I´m sure that on a singletrack she could be a handfull, but for me and her intended purpose she´s perfect. There are newer, faster, lighter machines and way more expensive machines but none like the mighty XR600! ![]() Long live the Thumper!!! |
12-18-2012, 06:27 AM
#171 |
Oddometer: 177
Some mods that I´m really pleased with, shaving the flywheel, 40mm FCRmx with a bigger cam on the accel. tube and the oil radiator.
She revs up FAST When I sort the jetting, she should be an animal
12-18-2012, 08:45 AM
#172 | |
Oddometer: 3,954
I know that cw and other engine builders, shave and balance the crank...maybe this would of been nice to do at the same time suspension for sure needs to be all the way up on the front especially on the stock forks...springs... |
12-18-2012, 08:51 AM
#173 |
Oddometer: 3,954
Btw congraaaaaaats!!!!!!!!!!!!!!!!!!!!!
