Old 06-08-2012, 10:57 AM   #31
Thumperama
RIP Husaberg
Thumperama's Avatar
Oddometer: 182
I'm in.
'12 GasGas 250 Raga Replica
'11 Husqvarna TE630, '11 Husaberg FE & FS 570's
'10 Triumph T-Bird 1700, '07 Ducati Monster S2R 1K
'01 Triumph Sprint ST 955i, '97 & '87 XR600R's
Thumperama is offline   Reply With Quote
Old 07-10-2012, 08:36 AM   #32
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Ok guys, Iīve been pretty busy with life so I had to leave the bike in the backburner for a while.
I read some forum posts everyday but I had no updates to write about. But I do now, even though
small in importance, itīs still updates.
Since the most important parts have arrived and I now have some time to kill, the rebuild will
not see much down time, hopefully.
SlickSix is offline   Reply With Quote
Old 07-10-2012, 08:41 AM   #33
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Iīve been mostly cleanning and scrubbing tatty parts that for the most part, came out alright
The tank
Linkage
Miscelaneous parts
For an 18 year old bike, it cleans nicely
Old 07-10-2012, 08:52 AM   #34
SlickSix OP
SlickSix's Avatar
Oddometer: 185
So far, the exhaust is only modification done.
Iīve bought an OEM Aprilia Mille exhaust for 20e but, as expected, itīs tatty, dirty and heavy
like a son of a b****!
Not kidding, this guy with all the internals must weight at least 12kg. Really, itīs heavy!
This is just the connecting pipe
The rest of the internals were just as bad, 3 cross walls, pipes, grids and honeycombs. I guess sound regulations
rule...
Old 07-10-2012, 08:58 AM   #35
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Iīve removed most of the restrictive stuff and just left a small spark arrestor grid.
The outer shell had to be modified from this
to this
I just rolled up a carbon fiber shell around the original one and it turned out pretty good.
Old 07-10-2012, 09:02 AM   #36
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Some new parts arrived
and my dad got me this old Jaguar oil cooler to retrofit
Iīm now in the process of making a supporting frame for it. Will post it as soon as done.
Old 07-12-2012, 04:22 AM   #37
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Ok guys, just got some good news from my brother. My frame and the rest of the parts
are painted!
But the little weasel just sent me photos of the parts primed. Heīs playing me, that
little, no good cockroach!!
Itīs going to be all black.
Old 07-12-2012, 06:51 AM   #38
elsalvadorklr
southern xr rider
Oddometer: 4,154
nice progress man!
hey what are the dimensions of the oil cooler? looks big man!
jajaja
good luck
elsalvadorklr is offline   Reply With Quote
Old 07-12-2012, 08:15 AM   #39
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Itīs not that big, itīs more an optical illusion it has 18x16x4. It maybe a bit bigger
than most but if I see that it looks misplaced Iīll replace it for something a bit smaller.
How about your bike? Iīve seen your recent "develpments"...tuff luck man., but sheīs rolling again
so itīs all good,right?
Old 07-12-2012, 08:16 AM   #40
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Oh, and thatīs in cm not inches by the way!
Old 07-13-2012, 06:50 AM   #41
elsalvadorklr
southern xr rider
Oddometer: 4,154
my bike is fine man! its me thats suffering! jajaj
after getting a wrong cw rocker I decided to just replace springs and seals and wait till I get my correct reground rocker so I can put in the cw hrc cam! cant wait!
the mikuni tm38 is a bit lean up top but other than that rocks...
yeah I figured cm's jajaja we use metric mostly down here too...
thats still pretty damn big! where do you plan on mounting it?
I need to install a cooler asap If i want to keep this carb
Im sure as soon as I install the new cam temps will go up too cause of the spirited riding Ill be doing so Im really interested in what you come up with
cheers man!
christian
Old 07-28-2012, 04:03 PM   #42
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Hey guys, Iīve been slacking a bit cuzī my brother still havenīt brought me the frame
and the rest of the parts but itīs time for some updates.
Iīve split the cases and it was pretty much as expected, worn out gears, piston in spec but
a bit scratched, cylinder scratched and out of round. 98mm it is then.
The good news are that the rod is within spec with only minor visual scratching.
Remember my crusty chamber and valves?
The inner springs were way below specs but not the outside ones. All of them leaked, especially
the exhaust ones, which were pitted.
Old 07-28-2012, 04:10 PM   #43
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Cleaned the chamber
Picked up my highly advanced and precise valve turning equipment
Worked the valves with the magic machinery
Itīs all good and sealed now
Old 07-28-2012, 04:20 PM   #44
Rot Box
Oddometer: 237
Great so far can't wait so see more!
00 KTM 640 Adventure R - 94 ATK 605DSES - 84 Honda CR500R - 81 Honda XL500S
Rot Box is online now   Reply With Quote
Old 07-28-2012, 04:23 PM   #45
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Itīs a shame about the piston, it looks brand new, itīs within spec at 97,48mm, had no
signs of blowing through but it was probably put on a non fresh cylinder that was
already out of round. Slapping as left some skirt marks and it was dangerous to leave it as
is.
The grinder took care of the welded sprocket and shifter. Unfortunately, the previous owner
welded the shifter directly to the shift shaft and it has to be replaced.
Times are GMT -7.   It's 05:12 PM.
