Old 08-16-2012, 04:49 AM   #91
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Originally Posted by mcma111 View Post
Perhaps consider the time, labor and expense of tearing the engine down.
Do it right the first time.
I know, I know... if it brakes on the first ride I'll punch myself for it.
nikolic- it usually goes in front of of the steering tube or the front of the frame midway between
the tank and bash plate. As long as it gets cool air, it's good.
I also got a new oil cooler from a Yamaha XJ 550. The one I got was a bit big and not appropriate.
SlickSix is offline   Reply With Quote
Old 08-16-2012, 04:53 AM   #92
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Originally Posted by brucifer View Post
Looking good, man! Your furry companion looks like she's enjoying the sunshine. :)
Yep, pretty much the only thing she does now, she s 17 and enjoying retirement. Eat, dump it and sleep
Old 08-16-2012, 11:10 AM   #93
nikolic
Oddometer: 480
I meant "where" as where in the lubrication system, where to connect it?
Home rides ;)
nikolic is offline   Reply With Quote
Old 08-18-2012, 01:02 AM   #94
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Hey nikolic, sorry for the late reply, been pretty busy around here.
Didn't understand it the first time. I have a diagram that another member
has done, I'll just upload it to photobucket in a few and post it here ok?
Old 08-18-2012, 01:04 AM   #95
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Here you go
Old 08-18-2012, 03:33 AM   #96
nikolic
Oddometer: 480
It's never too late for a right answer ;)
edit: here's a few pics of it: http://www.4strokes.com/tech/honda/x...r1/default.asp
Home rides ;)
nikolic screwed with this post 08-18-2012 at 06:12 AM
Old 10-29-2012, 10:31 AM   #97
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Hey guys, sorry for waiting. Im opening a new coffee shop and priorities changed a bit.
Enough of excuses, right? Its update time
Shes pretty much finished, but Ill give you the run down.
Old 10-29-2012, 10:35 AM   #98
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Ok, so after I fixed the broken piece of the case I started on the wheels which
were not as bad to straight as I initially thought
Did the same to the back wheel on my improvised stand and they turned out ok
Old 10-29-2012, 10:38 AM   #99
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Mounted the new disc and wheels
Also retrofitted the rear fender and side panels from the CRF450, handguards and some decals
Old 10-29-2012, 10:47 AM   #100
SlickSix OP
SlickSix's Avatar
Oddometer: 185
In the meantime my rod arrived!!
I was suprised to see the original honda big end rod, it was not that bad for 18 years of abuse
The new, shiny one looks better
Old 10-29-2012, 10:52 AM   #101
SlickSix OP
SlickSix's Avatar
Oddometer: 185
While waiting for the shop to press it, the head was assembled with new seals and springs
Had to fit a new plug boot and wire to the coil
Since I was doing electrical stuff, decided to make some LEDs taillight
Old 10-29-2012, 11:10 AM   #102
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Got the crank from the shop along with the lightened flywheel. Not much was removed, around 400grs
Sorry about the lack of assembly photos but I just forgot, was in the zone and in no time it was done
Got the timing right but the chain is a bit streched, half a tooth. I think it will be alright
Old 10-29-2012, 11:17 AM   #103
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Off to the frame it goes. A little of cardboard, a wiggle here and there and its in place
The cooler was next. Easy mod, if youre unsure how, just search for it or ask, theres nothing to it.
I got one from a 125cc with pretty good flow, cut the oil rail and just connected the original ones that
came with the cooler.
I think the pictures speak for themselves
Old 10-29-2012, 03:44 PM   #104
nikolic
Oddometer: 480
Nice job on that cooler! How did you fit CRF plastics? How does the left one fit on the air filter?
Home rides ;)
Old 10-29-2012, 04:45 PM   #105
MacNoob
MacNoob's Avatar
Oddometer: 1,675
That timing chain doesn't look good at all. If it's not fitting tight to the bottom of the gear teeth I wouldn't run it like that.
"Persuade thyself that imperfection and inconvenience are the natural lot of mortals, and there will be no room for discontent, neither for despair."
MacNoob is online now   Reply With Quote
Times are GMT -7.   It's 04:54 PM.
