Old 11-06-2012, 02:14 AM   #121
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Yes, yes I know. It´s in the work sheet
I just want to get her dirty for now and maybe on xmas I´ll score some forks. I have buried way too much money on her
and I have to lay back on expenses for a bit.
But she´ll have USDs that´s for sure, along with a nice flatslide or FCR
SlickSix is offline   Reply With Quote
Old 11-06-2012, 05:57 AM   #122
CrustyD3mon
CrustyD3mon's Avatar
Oddometer: 282
Well done mate...need to read this later....only subscribing....
CrustyD3mon is offline   Reply With Quote
Old 11-06-2012, 07:52 AM   #123
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Originally Posted by SlickSix View Post
Hey nikolic, thanks, it did turned out pretty good. The front and rear fender were pretty easy but the side panels
took a bit more work.
It´s hard to explain, pm me if you need photos and more info ok?
Really interested in finding out how to fit CRF side panels on the bike.....
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 11-07-2012, 10:21 AM   #124
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Hey guys, I´m pretty bummed right now.
I took the bike out to start her and it seems that the rebuild just took a turn and my fear just came through.
I started her, pretty easy I might add, and I have a nasty clattering, which I suspect is the tensioner and or the chain.
Don´t think that the auto decompression would make this sound, I tested it like the manual says and it seems ok.
She wasn´t making this noise when I brought her home and that´s whats bumming me out.
Checked the condition of the shaft and it seemed ok
Checked timing several times and I´m half a tooth off
The guides showed no remarkable wear
Valve lash is perfect and done like Steve says to do it
The tensioner does seem to back out way from the guides a tiny bit when some force is applied
It sounds like a coke can full of pebbles
If she wasn´t making the sound when I bought her, why now?
There´s no wrong way to install the tensioner right?
Old 11-07-2012, 10:39 AM   #125
mcma111
mcma111's Avatar
Oddometer: 12,386
Did you adjust the valves on the compression stroke? Is the noise at the right exhaust rocker? Recheck the valve adjustment. If you set the valves on the exhaust stroke the right exhaust rocker will have a mile of clearance and make a lot of noise.
If this is not the issue did you put the keeper bolt in the tensioner shaft? Can you rotate the tensioner shaft?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-07-2012, 10:41 AM   #126
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 564
boas
Se tens meio dente de diferença a corrente já esticou demais
Será que montaste a corrente ao contrário ?
Mas pode ter o tensor partido
Não deve ser muito caro ?
Nuno
-ENG------------------
hi
If you have half a tooth then the cam chain has streached
Can you have put the chain on fliped ?
the chain tensor could have a broke spring
Can't be to expensive
Nuno
webmonstro is online now   Reply With Quote
Old 11-07-2012, 11:03 AM   #127
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Hey Steve,
I did adjust them at the compression stroke. Checked and rechecked. I turned the crank counterclockwise
until the decompression click was heard and then backed the crank a bit to line the T to the notch.
The bolt is in place and tightened.
I´ll recheck them but the noise seems to be more on the side of the cylinder than on top. Like scrapping and clattering
Old 11-07-2012, 11:08 AM   #128
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Originally Posted by webmonstro View Post
boas
Nuno
hi
Nuno
Boas amigo
It´s impossible to fit the chain flipped but the tensioner might have broken, I just don´t see how. It was not noisy when used the last time.
It sort of is a bit on the expensive side, even on ebay. Chains of uknown quality goes for 50e and a new tensioner from Honda is around 70e. Without the shaft or spring...
I´m just gutted but will check the valve clearances again like Steve said before removing the cover
Old 11-07-2012, 12:40 PM   #129
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Well, the valve lash checks out. 004 and 005.
Maybe teh guides are way of spec and I didn´t realize? It could be, but there´s no reference in the manual as
to how to measure them and I didn´t see anything unusual.
I´ll remove the cover and the right side and check out if something is out of order. No way around it.
Damn, so close.
Anybody have some parts lying around that want to get rid of them?
Old 11-07-2012, 12:56 PM   #130
mcma111
mcma111's Avatar
Oddometer: 12,386
If you think the noise is at the cylinder you may have had the wrist pin keeper pop out and if that's the case your piston and cylinder are screwed. If the valves are in spec I wouldn't start the engine again as you may cause further damage.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-07-2012, 01:02 PM   #131
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Do you think that´s a possibility!?
I did make sure the keepers were well seated and with the opening far from the piston opening.
Man, i´m pissed right now
Old 11-07-2012, 01:48 PM   #132
mcma111
mcma111's Avatar
Oddometer: 12,386
Better safe than sorry.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-08-2012, 07:34 AM   #133
nikolic
Oddometer: 479
Did you check if the oil is getting to the head? Maybe it's dry! If not, I'll bet on a chain! When
I boiught mine, i replaced chain and tensioner with spring and shaft just to be calm...
Home rides ;)
nikolic is offline   Reply With Quote
Old 11-08-2012, 12:11 PM   #134
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Hey Nikolic, I primed the pump before and didn´t even had a chance to see if I was getting oill through, I heard the scraping and I turned her off.
I do know the cause now. It was the spring of the tensioner that broke where it fixes itself on the tensioner...
Never heard that one before,
Luckly, all the pieces stayed in its place, the spring and the tip
Old 11-08-2012, 12:14 PM   #135
mcma111
mcma111's Avatar
Oddometer: 12,386
You got off easy.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 04:19 PM.
