Old 06-02-2012, 12:46 PM   #1
Twin-shocker OP
Oddometer: 1,673
Ducati fuel tank problems?
Not heard of any problems with Ducati tanks here in the UK, and wonder whether issues in the US related to problem tanks have now been resolved?
Old 06-02-2012, 02:18 PM   #2
mendoje
Oddometer: 235
Legally resolved, argueably yes. Technically resolved, emphatically nooooo See it all here:
http://www.ducatimonsterforum.org/in...?topic=43639.0
http://www.ducatimonsterforum.org/in...?topic=25074.0
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 06-02-2012, 02:45 PM   #3
Twin-shocker OP
Oddometer: 1,673
Thanks...............had a read of that, and it seems astonishing that people with Ducati's are needing to put ridiculous tank sealers into their tanks, which seem to me clearly not to be fit for purpose?
What would happen if Ford or GM sold cars with defective fuel tanks I wonder?
Old 06-02-2012, 05:26 PM   #4
ttpete
Rectum Non Bustibus
Oddometer: 5,948
The tanks are made by Acerbis. They are made of nylon. I haven't had any problem with mine, which is over 2 years old.
However, I removed the carbon canister and replaced the original fuel filler with a competition version that has no valving in it. This prevents any tank pressurization, something that I believe contributes to the tanks swelling. The vent is open to the atmosphere. I also try to keep the tank out of direct sunlight by covering it with a jacket when it has to be parked in the sun.
15 BMW RnineT
09 Kaw Versys
Old 06-03-2012, 12:23 AM   #5
Twin-shocker OP
Oddometer: 1,673
Is it legal to remove the emissions equipment in all US states I wonder? I get the feeling that the PA6 nylon absorbing water has a lot to do with the problems that are occurring, and not heard of any issues on other bikes with HDPE tanks, that are generally fitted with covers.
Old 06-03-2012, 04:47 AM   #6
jules083
jules083's Avatar
Oddometer: 3,895
Every state is different as far as inspections and what they check for. My state, ohio, has no inspection at all unless you buy the bike from a different state, then they just check the VIN number.
My XR isn't even close to legal, but they gave me a plate for it because I told them it was legal.
I don't think, however, any state inspector would check the fuel tank. Most states seem to be somewhat relaxed about motorcycles, but really crack down on cars and trucks. California is the worst, I've heard tons of stories about people jumping through hoops to keep their cars on the road.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 06-03-2012, 06:34 AM   #7
scrannel
Scrannel
Oddometer: 1,457
There was a similar issue with Speed Triples over here (everywhere?) due to the factory sometimes assembling the "pollution valve" backwards which would cause the tank to implode (tank was OK... until implosion, of course). I thought the Euro-Zone had pretty much similar pollution standards to the US by now. Live in California, probably strictest state, never had any bike here seriously scrutinized.
If evolution is outlawed only outlaws will evolve.
scrannel is offline   Reply With Quote
Old 06-03-2012, 11:20 AM   #8
Twin-shocker OP
Oddometer: 1,673
Removing the emissions parts may well mean fewer tank problems then..............seems strange that someone has not come up with a kit to help with this, as I get the feeling that removal might well help?
Old 06-03-2012, 01:09 PM   #9
ttpete
Rectum Non Bustibus
Oddometer: 5,948
Competition style filler cap assemblies are available for just about any motorcycle. Some OEM caps can be modified to eliminate the valve. The rest is simple. Remove canister, extend tank vent line, plug or cap off vacuum purge line.
15 BMW RnineT
09 Kaw Versys
Old 06-03-2012, 01:31 PM   #10
OConnor
Bad juju
OConnor's Avatar
Oddometer: 3,662
I haven't read anything that would point to tank venting being the issue. I'd be up for about anything that would help though. My tank has ripples in the knee pockets and the top triple contacts the tank at full lock on both sides.
2013 Husky TR650
2008 GSX1250N
1990 HD Ultra Classic
2000 SV650 track bike
1971 CB175 vintage racer inabox
OConnor is offline   Reply With Quote
Old 06-03-2012, 01:49 PM   #11
ttpete
Rectum Non Bustibus
Oddometer: 5,948
Water and alcohol tend to soften nylon. Pressurizing the fuel tank can expand softened nylon. Consider a 6 inch square area on a tank. That's 36 square inches. At 1 psi, you have a total force of 36 lbs. At 2 psi, the force is 72 lbs.
Figure out the total surface area of the tank and multiply by the psi that the valve is set for. It's not inconsequential.
15 BMW RnineT
09 Kaw Versys
Old 06-03-2012, 09:57 PM   #12
Twin-shocker OP
Oddometer: 1,673
Pressurised plastic tank is certainly going to expand quite a bit, and I would guess may in some cases mean the tanks actually going to start leaking. Seems a great opportunity for someone in the US to come up with a easy fit of parts to stop tanks pressurising? Ducati owners even seem to be trying tank "sealers" which may well result in need for new fuel pumps when they fail..................
Times are GMT -7.   It's 02:17 PM.
