Old 06-02-2012, 01:23 PM   #1
Madman1 OP
Oddometer: 81
95 R100RT - shed fuel supply
I have a problem that comes and goes, bike will run for a while, then run on 1 cylinder is seems like, and than stop.
During the winter a got the bike dual-plugged, and also fitted a SilentHektik ignition system.
I adjusted the ignition and testdrove a week ago, bike seemed to run better than ever. Next morning drove off for work, bike stopped after 5 min drive. I suspected the rotor bolt, where the ignition signal is picked up, to have gotton loose. It sure didnt take much force to unscrew it. So new adjustment, and bolt fastened with correct force, 25nm.
Today I was gonna test again, it ran 200 meters. Hmm. I hr later Im gonna chech the ignition with a lamp. Its right on the mark. So I dress up, planning to go for 2-3 hrs. After 7-8 min., the problems are back. Loosing power, seems like I run one 1 cyl. Turns around trying to make it home. Stops on the side of the road. Right float chamber is dry, seems to be lower than usual in the left one too. With ignition on, not a drop of fuel flowing into the chamber.
I friend picks me up. Im starting to suspect the fuel shed system;
http://www.realoem.com/bmw/showparts...41&hg=16&fg=13
Back home, ignition on, fuel flows again.
On a bike without this system, european, and older american, does the fuel line run directly from the petcock to the carburator? Or are the sides connected?
I understand its not uncommon to remove the system. Anybody else experienced problems with the shed system?
There are 2 valves in the shed. Are the output lines connected? If so, if 1 valve failed, I should have gotton half of normal fuel flow?
Hans
Norway
Madman1 is offline   Reply With Quote
Old 06-02-2012, 02:20 PM   #2
JPSpen
At Large
JPSpen's Avatar
Oddometer: 1,185
Simplest explanation is a plugged vent line.. Once the bike builds up a vacuum, The fuel stops flowing...
I'd just take the fuel system apart.. If it's still got the solenoid valves and stuff I'd ditch all that...
Check fuel flow at each of the fuel taps.. Get some new fuel line and two T's... And a couple of in line fuel filters...
fuel comes from each tap to T #1, The T#1 connects to T #2 and the two lines from that T go to the carbs...
Throw in a couple of in line filters and you're golden....Get the see thru kind so you can see the fuel thru them...
Make sure your vent line is not plugged..Take gas cap off.. Blow into vent line ..
When mine runs out of gas it drops one cylinder and the second about a couple hundred yards later...
Good Luck...
John.
'03 BMW R1200CLC "Flipper"(Tis but a scratch!)
'01 BMW R1100RT "Lucky"
'91 BMW R100GS "itsnotamoneypit"
I like the wind in my face and Boobies too !!..
JPSpen screwed with this post 06-02-2012 at 02:54 PM
JPSpen is offline   Reply With Quote
Old 06-02-2012, 03:35 PM   #3
Madman1 OP
Oddometer: 81
Thanks, will look into that.
Hans
Old 06-03-2012, 03:40 AM   #4
Madman1 OP
Oddometer: 81
The vent line was hard to mount this time, ended up in a 90 degree bend. So Ill correct that. I dont fully understand the system, but I thought venting came through the fuel cap also.
Hans
Old 06-03-2012, 05:32 AM   #5
Madman1 OP
Oddometer: 81
I was draining the tank, soon gas flow slowed down. Got rid of the bend in the vent hose, flow restored. I think problem is solved. That drain hose need to work properly, lesson learned for me. Thanks for all replies.
Hans
Old 06-03-2012, 11:24 AM   #6
supershaft
because I can
Oddometer: 9,116
I just glanced through your post Madman but your bike still has the fuel shed system? Take it off ASAP. That very well could be the only issue. They act up regularly. It's a miracle it is still on there and was working at all. Plus, those two solenoids suck at least a whole volt out of your charging system. There is articles on how to disconnect it. Do it right and take the whole setup off and go get two fuel line tee's and reroute your crossover under the airbox. The two disconnected lines on the main harness just plug into each other and you are done. You might have other issues but that shed system is junk and it WILL fail if it hasn't already. It sounds to me like it very well could be the shed crap. Good luck!
Old 06-06-2012, 02:52 AM   #7
Madman1 OP
Oddometer: 81
I had not mounted the vent hose correct. Will do some measurements on how much the system draws. January issue of BMWON mention it in the Parkhouse article. The valves on a 95 might be better than the early ones, at least can't hear any noise (clunk) from them. The environment is important too, so will leave them on for no. Thanks for the advice anyway!
Hans
Old 06-06-2012, 08:51 AM   #8
supershaft
because I can
Oddometer: 9,116
They are the same valves on a 95. They draw a lot of current and make your bike very unreliable. The setup makes your bike greener just setting there with gas and oil in it. They are greener yet never running.
Old 06-06-2012, 02:43 PM   #9
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
If youre smart, you'll dump that whole Shed system and go back to a simple cross-over inder the Air cleaner. It's simple and it works better that what BMW came up with way back when to pass US regs.
If you can save a volt by removing those valves, do it. Any time you can get a free volt on an Airhead, get it. Someday youre gonna need it!
Get your bike running in tip-top shape and let the environment take care of itself. Youre already riding a motorcycle, for Dogs sake!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 10-28-2013, 06:24 AM   #10
Darryl's bmw
Darby
Darryl's bmw's Avatar
Oddometer: 228
Removal of Shed System?
Where can I find the article on removing the Shed System?
Darryl's bmw is offline   Reply With Quote
Times are GMT -7.   It's 10:36 PM.
