Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 06-20-2012, 07:52 PM   #16
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,065
Originally Posted by Padmei View Post
Excellent lil reply old no.99. So the 4 valves pushed more mixture thru in a smaller area of the combustion chamber & a better detonation happens in a 'squarer' chamber?
Why are the valve recesses there on top of the pistons? if the cam etc are timed right there shouldn't be any chance of the valve hitting the piston. Am I right in guessing that the space in the cylinder is limited perhaps due to a short stroke & the further the valve opens the more mixture can pass thru however the only place to gain depth for the valves is the top of the piston? Rotary valves or sliding valves no good?
Wouldn't the valve recesses affect the efficiency of the combustion?
If the valves open further then they will allow more air/fuel to enter but piston to valve clearance is harder to achieve so valve recesses and dome shaped pistons need to be used so a decent copression ratio is achieved. The other way is to have a cam with a long duration but again compression ratio is affected because the valve is also closing later therefore there is less volume of fuel/air mixture (e.g.the piston is further up the stroke when the valve closes) to compress to achieve decent compression so generally pistons are domed.
Yes there are a lot of compromises in engine design.
innathyzit is online now   Reply With Quote
Old 06-21-2012, 12:57 AM   #17
Padmei
enamoured
Oddometer: 3,678
Thanks I went & did a bit of research after posting & learnt a lot.
benelli content
When I first saw that pic I thought it was some kind of dogs face???
Padmei is offline   Reply With Quote
Old 06-30-2012, 02:48 PM   #18
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,065
Don't panic, haven't lost interest, just a little angry with myself for being a dum ass.
Made a new gudgeon bush up yesterday with my new lathe tool set (don't tell Mrs Woodman). After machining up the bush and polishing it all smooth I took it out of the lathe and went to fit it into the small end and that when i realised that I had machined it for clearance instead of interference. Still have some stock bushing left so will try again today, or take the KLR for a hoon. Probly this.
Another issue discovered yesterday was that the benelli small end is wider by about 4mm than the distance between the gudgeon bosses on the xr piston. Dremmel time. Padmei? did you have an electric dremmel?
Anyway not major issues , just annoying challenges .
Old 06-30-2012, 10:08 PM   #19
Padmei
enamoured
Oddometer: 3,678
Bugger.
How much do you allow for interference fit? a thou or same dia?
Yep I've got a ryobi dremel machine thing. i'll drop it out to you with your welder - i'm gonna buy my own one.
Old 06-30-2012, 10:35 PM   #20
Pete-NZ
Pete-NZ's Avatar
Oddometer: 743
LOL..
Wasn't hot when yer done the final cut was it..
then shrunk when it cooled..
I have done that before... wonder why the bearing suddenly be come a lose fit..
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 06-30-2012, 11:55 PM   #21
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,065
Bugger.
chur bro, not too worried about the welder though. thou and a half seems to work from memory.
Originally Posted by Pete-NZ View Post
LOL..
No, just subtracted instead of added. Made and fitted another bush this arvo, had to make a wee jig to wind it in as the crankcases are all assebled up. Went well and didn't need to hone the bush to suit the gudgeon so got that right. Made and fitted the bronze valve guides too.
Was too cold for a ride.
Old 07-01-2012, 01:33 AM   #22
ztaj
jatz
ztaj's Avatar
Oddometer: 955
Pussy...
ztaj is offline   Reply With Quote
Old 07-04-2012, 01:57 AM   #23
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Originally Posted by ztaj View Post
Pussy...
Time for another snow ride.
Inwood Lookout is close by...
NordieBoy is offline   Reply With Quote
Old 07-04-2012, 04:45 AM   #24
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,065
Sounds good to me, but better get over this orrible cold first.
Old 07-04-2012, 12:12 PM   #25
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,834
its a real fooker isnt it
perfect riding weekend last weekend and Glen and I were way too crook to ride - what a waste
These are the best days
Mark_S is offline   Reply With Quote
Old 07-04-2012, 11:13 PM   #26
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Pussies!
It was 24* last weekend!
Old 07-04-2012, 11:28 PM   #27
Padmei
enamoured
Oddometer: 3,678
Pussies!
Not up at the lake where the real men (idiots) were VMZing in the snow.
Old 07-05-2012, 01:57 AM   #28
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Just been looking at the pics.
https://plus.google.com/photos/11444...wa&gpsrc=pwrd1
That would have been fun on the 705's
Old 07-05-2012, 02:43 AM   #29
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,065
Did you see in the paper who was the main naming rights sponsor for the series again this year?
Please say yes.
Old 07-05-2012, 04:01 AM   #30
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Wouldn't be that Mot Repco outfit.
Too dodgy.
DR650 Wiki
Times are GMT -7.   It's 05:14 AM.
