Old 06-04-2012, 12:06 PM   #16
DiabloADV OP
Semi-Occasional
Oddometer: 2,322
While there is a long trail of tears around no-circlip problems, I've yet to come across an archive of owners complaining that the 0.05mm axial play clearance of the gearbox shafts is causing people's RTW trips to come to a halt. Perhaps maybe they got that one right.
Besides, given the shim sizes they made available (when they were all available), the 0.05mm figure obviously has some play in it as well. A little more; a little less. Probably OK. I'm shooting for a fit in the 0.05mm to 0.10mm range since shims are not available in an infinity of sizes.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 06-04-2012, 01:12 PM   #17
supershaft
because I can
Oddometer: 9,116
Originally Posted by DiabloADV View Post
Yes...and I know exactly who....
The engineers at BMW that decided that 0.05mm was the right number. They get paid to think about such things.
Where did they say that? Everywhere I have looked they said 0 - .1mm. You can usually get it a lot closer to zero if you stack shims. That is if you want to.
Old 06-04-2012, 08:37 PM   #18
bmwrench
Oddometer: 2,198
In a Service Bulletin about 1985. I suspect it was needed with the 17.5 degree gears.
bmwrench is offline   Reply With Quote
Old 06-04-2012, 09:34 PM   #19
supershaft
because I can
Oddometer: 9,116
I don't remember that one. Never seen it mentioned in other manuals. I wonder what their reasoning was? I know from experience that less works just fine on the later PFA gearsets. I wish I could read that one. Somebody around here knows how to look them up. I believe trannys are in group 23?
Old 01-22-2013, 09:00 PM   #20
Olliew72
Olliew72's Avatar
Oddometer: 48
Well I'd just like to say that I tried this solder trick for measuring the end play and it worked perfectly. I just wish that I was smart enough to have thought of it myself. I'm glad I stumbled on this thread. Thanks.
1970 BMW R75/5 (Came as a free box of parts)
Olliew72 is offline   Reply With Quote
Old 01-22-2013, 11:34 PM   #21
ME 109
ME 109's Avatar
Oddometer: 2,991
Well then, after my recent tranny rebuild using a shim plate, I've more confidence in the solder method.
What diametre solder did you use?
If you took just .05mm from your solder thickness, and your input shaft spun freely after assembly, it would suggest that my concerns of the solder distorting the cover (and ultimately giving a tighter clearance than thought) are groundless.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 01-23-2013, 01:36 AM   #22
a_bakla
A&F
a_bakla's Avatar
Oddometer: 124
My Rosen core wire was tin and had space at the center. This tin was soo soft that I can even bite and shape it.IMO this type solder wires cant distort the cover.The cover is designed to handle much more force to be able to function.
a_bakla is offline   Reply With Quote
Old 01-23-2013, 07:02 PM   #23
mendoje
Oddometer: 240
Can you post the exact brand and part no. of the solder you used? I'm suggesting this so that if we all use it as part of a standard procedure, we can get consistent results.
Jeff
Today, I tried a method I'd read about. Place little pieces of hollow-core solder so the ends sit across the outer races. Heat the cover and install and torque. Then take the cover back off. Measure the squashed solder, subtract 0.05mm, and you have your shim specs.
It worked perfect, and took 15 minutes instead of the tedious afternoon of ultimate failure. Plus you don't need a $70 flat plate and a $100 indicator. Or much skill.
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 01-23-2013, 07:23 PM   #24
supershaft
because I can
Oddometer: 9,116
As I have said a while back, any solder I have around is soft enough. I just thought that I would be concerned with the solder being too soft as far as measuring your clearance with the oil baffles on the bearings. The solder might not be hard enough push them down all the way. Oh well, loose doesn't hurt a thing as far as I can tell. Too loose does from what I can tell. Like I said earlier, I think they shift slightly better set up as tight as possible but, then again, I shift my airheads way more often than anyone I have ever ridden with.
I set up all my tranny work including my own setups without the paper gasket. I have never had a problem for it and I do think it is easier to nail the clearance if that is what you want to do. I use Durko there. Actually, I think they hold oil better without the gasket myself.
Old 03-14-2013, 07:21 AM   #25
2VEZR25
Recuerde el 911
2VEZR25's Avatar
Oddometer: 60
Shim stack range
For those with transmission experience: As a guide and after all calculations; What would be the typical measurement range of shims (min/max) before being alerted that either a calculation or something internal is not right?
Thanks.
2VEZR25 is offline   Reply With Quote
Old 03-14-2013, 12:27 PM   #26
ME 109
ME 109's Avatar
Oddometer: 2,991
Thanks.
For me, it was .85 - .95mm
Old 03-14-2013, 02:16 PM   #27
Bigrider
Living the Legend
Oddometer: 16
I have taken apart two five speed trannies. After the first one I was given some advice to measure the clearances of the tranny with original shims right after taken off the cover before removing anything. This will give you a ballpark figure for what the whole system should measure once you get everything back together, generlally within a few thousands. Any gross difference may indicate the pieces weren't seated fully. Another tip was to place new shims on a flat piece of 800-1000 grit sandpaper and lightly snad to take off any burrs that may throw off the measurements even by a little bit.
Dave H
San Antonio, TX
Bigrider is offline   Reply With Quote
Old 03-14-2013, 07:50 PM   #28
supershaft
because I can
Oddometer: 9,116
IMO, I wouldn't use what was in there as a guide. A lot of them I have worked on were set up more than a couple of thou on the loose side. Tons of them were shipped that way. They work fine that way but I do think they work better set up tighter. I think that loose end play has something to do with some bearings walking on later snap ringless trannies while others don't but that is really another story. That and I put them back together without the gasket. I know quite a few that do that. Easier to nail the shimming and they tend to leak less without the gasket IMO.
Old 02-06-2015, 02:48 AM   #29
plainshorse
Oddometer: 5
Airhead gearboxes
I have recently uploaded a series of videos on my YouTube channel on rebuilding airhead gearboxes:
https://www.youtube.com/channel/UCvd...view_as=public
In my opinion there are two problems with squashing solder to find the clearance. First, although solder is very malleable, it is a relatively hard material (in engineering terms) and it also has some elasticity. BMW state the clearance should be either 1/10th of a mm or 1/500th of a mm. Given the aforementioned properties of solder, and the required clearance I am not sure if it would give the desired accuracy. Plastigauge may be an option, but in either case I would need to see convincing evidence before using it. However, the factory method also requires much patience and practice to get consistent and accurate results.
plainshorse is offline   Reply With Quote
Old 02-06-2015, 04:49 AM   #30
Darryl's bmw
Darby
Darryl's bmw's Avatar
Oddometer: 221
Are you using a transmission shimming plate
To keep the shafts parallel when you are doing the measurements.
There is a BMW tool for that, very expensive.
I have seen one made out of an old rear cover that was cut down to .200"
Darryl's bmw is offline   Reply With Quote
Times are GMT -7.   It's 08:48 PM.
