Hondamatic 750A
Discussion in 'Old's Cool' started by RABBIT170, Jun 4, 2012.
  1. RABBIT170
    RABBIT170 CB750 Adventurer
    Feb 3, 2011
    111
    Ft. Wayne, IN
    Did a search and really came up with nothing,
    So here it goes:
    I got a 78' Hondamatic with 12,000 org. miles on it. All there and overall in great shape. Last time it ran was 04', so I need a carb kit for it and some other engine gaskets.
    But I'm having a hard time finding anything for a 750A carb kit on the web.
    Could anyone please share some links and tips to this bike and its parts?
  2. kbasa
    kbasa big big energy
    May 28, 2002
    122,181
    Sonoma County, California
    Off to Old's Cool, man.
  3. RABBIT170
    Feb 3, 2011
    111
    Ft. Wayne, IN
    ^Thanks
  4. 396
    396 low-post lurker
    Dec 23, 2005
    209
    Simi Valley, Ca.
    I'm pretty sure they use the same carbs as the K model. Might check bikebandit, and compare part numbers.
    Edit, looks like slight differences between K & A. Bikebandit does list carb parts for the A however
  5. deadzed
    deadzed Meat Popscicle
    Jul 11, 2010
    232
  6. JLeather
    JLeather Bike Butcherer
    Aug 15, 2010
    397
    Maryland
    The "A" carbs are very different than the K. They have a vacuum-operated idle adjustment so when you drop it into gear the idle picks up (just like a car). My buddy Carl oughta have a clean set or two kicking around, he loves those old 'matics. PM me if you need some carbs. You can get the float gaskets from a couple sources, and a lot of the internals (jets, needles, etc) are the same as other CB750 carbs.
  7. bringenufgun
    bringenufgun Been here awhile
    Oct 9, 2010
    885
    apparently halfway to motorcycle hell
    if it needs a head gasket, the engine has to come out.
  8. stainlesscycle
    stainlesscycle Long timer
    Jun 6, 2008
    2,329
    morgantown, wv
    on the 750a, the head can be removed in frame. it's tight, but it will come out. not so on k models. aside from the obvious differences, the exhaust header is different, the frame is different on 750a, and the carbs have the vaccuum idle
    #8
  9. spo123
    spo123 Man About Town
    Nov 7, 2006
    1,459
    North Shore Mass. USA
    I also heard that the swing arm on the automatic is a little bit longer than the clutch bikes.......some use them on cafe bikes, for a bit of extra wheelbase.
    spo
    #9
  10. CoyoteCowboy
    CoyoteCowboy Easily Distracted
    Jun 20, 2005
    330
    Medicine Lodge, Ks (Gyp Hills)
    As usual, go here >> http://forums.sohc4.net/ . Tons of good information there and a pretty good bunch of guys too.
    And if you can't figure out what to do with it, go drag racing. The auto Hondas can be made into lethal bracket racers :evil. The sport bike power ranger guys will hate you :lol3
    #10
