06-04-2012, 02:58 PM
#1 |
Oddometer: 280
Riding the 990 in the sand?
06-04-2012, 03:28 PM
#2 |
Oddometer: 329
I haven't done much sand riding, couple days around Moab, but it seems like if you slow down you are screwed? keep it a t 5-6000rpm in 3rd and it works fantastically well, steer with your feet (like waterskiing). Not sure how to get it moving again once you slow down??
06-04-2012, 03:37 PM
#3 |
Oddometer: 33
haha , probably dont bury it down to the bashplate for starters
06-04-2012, 03:42 PM
#4 | |
toda su base
Oddometer: 420
In general for sand riding, lower your tire pressure and keep up your momentum. Sometimes easier said than done. |
06-04-2012, 04:18 PM
#5 |
Oddometer: 8,040
Another recent thread on sand riding on the big katoom: http://www.advrider.com/forums/showthread.php?t=789052
06-04-2012, 04:48 PM
#6 | |
And be prepared to go where the bike goes and not where you want to, works well in open areas. But I might not have it all figured out, not a lot of really loose sand around to practice on. /Johan |
06-04-2012, 07:11 PM
#7 |
Rough Rider
Oddometer: 829
Meoni Said
Meoni said ride it like a 125 2 stroke !
Keep a lot of speed and gas it ! Twist it, Max
Da oggi la strada é senza limiti |
06-04-2012, 07:32 PM
#8 |
Oddometer: 672
keep up speed and STAY FORWARD, standing is best
I got a personal one on one lesson from Scot Harden and he taught me to "sit on the gas cap , it will feel weird at first but once you get used to it , it will be like a whole new world in the soft sand" we naturally want to get back but that is wrong this happened when some quadtards cut in front of me and made me brake to get out I just dug out to one side, lean the bike over , then with the bike on its side fill the hole through the spokes with sand , then pick up the bike, took only a few minutes to get out
04 KTM 950 S 04 KTM 525 EXC street plated |
06-04-2012, 08:05 PM
#9 |
Rinho Féroce
Oddometer: 969
I guess it depend on the speed... the faster you go the more forward you must be...But accross Withe Wash Sand dune (Moab), up to 50Mph, I was not able to get my weight out of the rear (but not sat), and I felt safe.
The right hand is also your best friend! Throttle must be high enough to make the front lighter (and that,s the reason you should put your weight on the back) all the trouble I had in the sand were when I was following a lighter bike, wich can be riden slowly without exhausting the rider... you can't ride a 9X0 LC8 slowy and sat in the sand (Hulk may be...)
'06 950 LC8 Adv S '02 F650GS (wife's bike) '99 LandCruiser '92 KTM 400 LC4 (the first 400 LC4 produced, pre-serie unit) |
06-04-2012, 08:16 PM
#10 | |
Oddometer: 367
Everything that I have read on sand riding is to keep your weight back to get the front end up. I am definitely no expert on sand riding, I get a warm and sweaty feeling anytime I get in it especially on a 500 pound bike. Now I am confused. |
06-04-2012, 08:42 PM
#11 |
Master of None
Oddometer: 5,054
Tires--flat
Throttle--on That bike is so heavy I don't know if it matters where your body weight goes. Ridden sand for a million years but on light bikes. Seen 950's do well but with no baggage and a paddle. Tire speed is your friend. Front will wobble but don't fight it.
Originally Posted by Javarilla Evolution, or, natural selection, has nothing to do with better. It merely weeds out what is no longer suitable for the given context. Originally Posted by Dragoon I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle. |
06-04-2012, 09:01 PM
#12 |
Rinho Féroce
Oddometer: 969
Yes, It matters (maybe not if you are less than 100Lbs)
06-04-2012, 09:08 PM
#13 |
Oddometer: 367
06-04-2012, 10:09 PM
#14 |
Oddometer: 16
I rode my 990 in the sand today for the first time on a section of the Tour of Idaho. I have ridden sand a lot on smaller bikes but on the 990 it was exhausting. I thought I was going down a dozen times but managed to save it. This bike is a lot of work in the sand. Im going to replace my Pirreli Scorpions for something a bit more dirt orientated and hopefully that will help in the sand.
stephenwclark screwed with this post 06-04-2012 at 10:23 PM |
06-04-2012, 10:42 PM
#15 |
Oddometer: 161
At least if you dump it in the sand it is a relatively painless event...
