Old 05-11-2013, 09:16 AM   #31
tugboat OP
MicroTourer (tm)
Oddometer: 101
http://groups.yahoo.com/group/hondah...55653/pic/list
You may have to be a member to see the link.
tugboat is offline   Reply With Quote
Old 05-11-2013, 10:12 PM   #32
asphaltmueller
nomad acc. 2(3)AVV
asphaltmueller's Avatar
Oddometer: 1,006
Originally Posted by fullmetalscooter View Post
I wonder if you could set up a reverse off the sidecar wheel using a starter motor mounted so it some how turn the sidecar wheel backwards. A chain or little solid rubber tire that you can drop down on it's wheel and hit a button to make it go. Just a wild Idea .
A friend has a starter motor mounted. Driven with a fan belt to a fan belt disc (? vocabulary) that is fixed on the sidecar-wheel axle instead of an original spacer.
A generator should work, too.
Those are rather mounted to give extra way in deep snow; might even drive both directions, if you put a switch to change polarity, but in your case backwards should moreless do.
good luck and a lot of fun with your rig
asphaltmueller is offline   Reply With Quote
Times are GMT -7.   It's 11:38 AM.
