Old 06-11-2012, 05:24 AM   #16
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
Hey Mike
In regards to your headlights it sounds similar to what I experienced with my RT . I had just changed over to HID lights amongst other things ... and when I tested with the tank off it worked fine ... put the tank back on and I couldn't get high or low beam ... just the flasher ... take the tank off to check ... it all worked fine.
Drove me mad for a couple of days ... checked everything ... from my wiring of the new HID and relays etc ... By chance I lent on the electrical connectors ( left hand side of frame, past the relays ) and it all worked fine. Basically I think they must have worked lose whilst removing and replacing the tank a few times.
Solution was just to simply to tape them down a bit tighter to make a better connection.
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 06-14-2012, 11:39 AM   #17
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 7,014
Thumb Resolved!
The new (used) solenoid arrived from Motorworks today...
It wasn't the solenoid that was the problem.
More and more these last few days I have been coming to the conclusion that this was something REALLY simple. Sure enough, when refitting the starter (with the battery connected) I brushed the INSULATED end part of the power lead against the starter case and got a spark.
There was a fine cut in the insulation that tightening down opened up and created the short. A bit of red heatshrink later and the starter works as advertised, as does the headlamp.
Thanks very much everyone for your words of advice - it is really appreciated.
Let the rebuild continue!
Mike
All text & original photos Mike Oughton 2004 - 2015
MikeO is offline   Reply With Quote
Old 06-15-2012, 09:22 AM   #18
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,195
Well done getting that one sorted out! Chalk one more up to just taking a good close look!
Times are GMT -7.   It's 04:57 PM.
