Old 06-07-2012, 07:03 AM   #1
Tato OP
Oddometer: 25
F800GS Hand Grips
Hi guys. Does anyone know if the rubber hand grips fitting an R1200GS will fit a F800GS? Mine are all worn down, but the dealer sells the whole warming grip thing, not just the rubber grip. Found the grips on the internet, but i'm not sure it they will fit right. Can anyone shed some light please?
Tato is offline   Reply With Quote
Old 06-07-2012, 01:38 PM   #2
GH41
Oddometer: 822
Are you saying you have heated grips and want to replace the rubber grip but not the heating element? GH
GH41 is offline   Reply With Quote
Old 06-07-2012, 01:55 PM   #3
3Rrr
Read Ride Reflect recycle
3Rrr's Avatar
Oddometer: 170
Thumb Grips only? Pro Grip 699 Open End
If you are just looking to replace the grips, I recommend getting two of these, Pro Grip 699 Open End. You'll need two packages since the diameter is the same on both sides.
Helps reduce the vibration and also gives you fatter grips. I run them on all my bikes.
Kyle twitter.com/ducumph
3Rrr = Read, Ride and Reflect
09 BMW F800GS
11Husqvarna TE 449
3Rrr is offline   Reply With Quote
Old 06-07-2012, 06:47 PM   #4
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,196
Everything you wanted to know about 800GS grips, but were afraid to ask !
http://advrider.com/forums/showthread.php?t=493833
"All that is necessary for the triumph of evil is that good men do nothing." - Edmund Bourke Irish orator, philosopher, & politician (1729 - 1797)
Ducksbane is offline   Reply With Quote
Old 06-08-2012, 02:57 AM   #5
Snowy
Oddometer: 1,887
I'm trying to remember the brand of grip I bought. They were just the standard dirt bike grips at the local bike shop. I listened to advice from ADVrider and bought 2 sets, and used the throttle side grip from each set. After carefully cutting off the old ones I fitted the new ones by just stretching and working them on.
They moved around a bit on the bars, especially when the grip heater was on full and they were wet.
When they wore out, I took the non throttle side grips (the smaller holes) put them in a bucket of hot water, pulled them out and fitted them straight on. They were tight, but not overly so compared to other grips I've fitted.
They are snug and tight wet or dry, hot or cold.
Win/win.
TAG grips. The dual compound MX ones. They've changed the design slightly.
Snowy is offline   Reply With Quote
Old 06-08-2012, 05:21 PM   #6
itsatdm
itsatdm's Avatar
Oddometer: 4,978
BMW K bike grips fit. Cheap and sold individually. A little thicker and I have not noted any effect on temps.
Old 06-10-2012, 08:43 AM   #7
Tato OP
Oddometer: 25
Thanks for the advice! GH, yup that's what I meant exactly. But I need to cut carefully the old grips and there's no turning back from that, so I want as much advise as possible. Replacing just the rubber grip saves me a lot! But I wanted something that looks similar to the original ones it came with.
I'll go ahead with your advice guys, and put a picture to show you how it turned out.
Old 06-26-2012, 07:51 AM   #8
Tato OP
Oddometer: 25
Hey, found these on ebay: Harris Ariete Replacement Style Grips BMW
They look just like the stock ones on the F800GS for little over $21 and they claim to fit.
Just ordered them, so I'll post a picture of them once installed.
Old 06-26-2012, 09:00 AM   #9
HappyHighwayman
Oddometer: 295
I wrapped some "Beemer buddies" around mine, I prefer the additional thickness.
HappyHighwayman is offline   Reply With Quote
Old 10-04-2012, 04:28 PM   #10
Herr Bae M. Vae
Insurgent Squirrel
Herr Bae M. Vae's Avatar
Oddometer: 18
+1 on the Pro Grip 699s. I've run those on my MX bikes and like them for their tackiness and buzz dampening. The dual compound ones don't wear out as fast as a lot of other MX grips. They carry several other models.
Herr Bae M. Vae is offline   Reply With Quote
Old 10-05-2012, 09:05 AM   #11
Natnewt
Natnewt's Avatar
Oddometer: 486
That's what she said!
1980 XR80s Deceased, first ever teardown.
1987 XL185s Deceased, at the bottom of the ocean.
1985 750 Interceptor Sold still alive somewhere.
2006 XR650L heavily farklefied Tendering in the garage.
2012 F800GS Triple Black Let the mods begin.
Natnewt is offline   Reply With Quote
Times are GMT -7.   It's 09:40 AM.
