Old 07-17-2012, 05:49 AM   #61
adventure950
Anglo-Saxon
Oddometer: 427
Mr Gregor I think you have it spot on with what MK66 says - (I read his stuff on the other forum) The 296 feels very torquey, smooth power delivery and so on and i think your right some other set ups will give more torque - but its not a bad starting point and its certainly a very rideable engine configuration - with this cam in. Cheers Jake.
'A tourist sees what he went to see,
a traveller sees what he sees'
adventure950 is offline   Reply With Quote
Old 07-17-2012, 06:23 AM   #62
RGregor
Oddometer: 334
Hi Jake,
I just reported what others have experienced. No personal experience with that cam.
Best regards, Rudi
RGregor is offline   Reply With Quote
Old 07-17-2012, 06:24 AM   #63
RGregor
Oddometer: 334
Originally Posted by supershaft View Post
Too bad the numbers mean almost nothing unless you got your numbers form the same dyno I did with the same operator when he was in the same mood.
Two additional questions: what configuration do you have regarding exhaust (header pipes and mufflers) and air box?
Old 07-17-2012, 11:21 AM   #64
supershaft
because I can
Oddometer: 6,209
Fed up and annoyed? We have finally come real close to the same conclusion. Let's leave it at that. The rest of us are discussing cams.
supershaft is online now   Reply With Quote
Old 07-17-2012, 11:35 AM   #65
supershaft
because I can
Oddometer: 6,209
If this thread and the other current cam thread could ever have anything close to a conclusion I guess it would be that we are left to researching individual opinions about cams that hopefully they have actually run and compared. It's a real shame that many of the cams for our airheads do not have specs with check points so we could compare specs. Pretty much everyone realizes that comparing specs is as much art as science but perhaps not as much as comparing a bunch of he said/she said. Since the he said/she said is all we have, I hope the stories about other cams are a lot closer to the truth than that what I have found to be true about the 336 compared to most the stories about them out there. Going simply by reported performance, my 336 experience tells me to buy the cam with the worst reputation. There's a small crowd here that is real happy doing just that!
supershaft screwed with this post 07-17-2012 at 11:42 AM
Old 07-24-2012, 12:53 AM   #66
adventure950
Anglo-Saxon
Oddometer: 427
Means very little to me but maybe you tech guys can use this cam timing readout graph
Old 07-24-2012, 01:08 AM   #67
Padmei
enamoured
Oddometer: 2,518
The dark blue is more natural. The red is a bit OTT if you ask me, a bit too much pornstar but if you feel you really do need enhancement just go with the lite blue.
Can we see side view too please?
Padmei is offline   Reply With Quote
Old 07-24-2012, 01:14 AM   #68
adventure950
Anglo-Saxon
Oddometer: 427
Padmei - you really need to be getting out you know .
Old 07-24-2012, 03:25 AM   #69
Beemerboff
Oddometer: 2,066
Nice curves, but just one point, can anyone see a lift point where all the durations match the claimed figures.
And if they can, shouldnt that give us the checking clearance?
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 07-24-2012, 10:39 AM   #70
supershaft
because I can
Oddometer: 6,209
The degree graph isn't near big enough to tell anything I don't think. You have six OR seven dashes representing 30 degrees. Ballpark figures again?
Times are GMT -7.   It's 09:12 PM.
