Old 06-07-2012, 11:42 PM   #1
bikecat OP
bikecat's Avatar
Oddometer: 1,117
Dead battery on a R100R - cause?
Hiya,
I did not ride my r100R for say 10 days and found the AGM battery died, turned on the ignition no lights, voltmeter reading is nought. Battery is relatively new, so I suspect there is a leak somewhere. What are the likely suspects that I should hunt down?
The battery is indeed dead. I hooked it up to an Oximiser and hope to revive it, but I think the situation is bleak. Any recommendations on a last ditch saving of the battery or it is a sure goner?
Cheers
bikecat is offline   Reply With Quote
Old 06-07-2012, 11:51 PM   #2
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,583
In my experience the agm types fail suddenly, little warning.
Reasonably new may not be much of a reason either. Warranty? They can do it anytime, but usually not of course, otherwise no one would buy them. I've read that the Odyssey batteries can fail early also, and they seem to be most peoples favourite battery too.
I've had good experience with Deka, with a recent manufacturing date stamped on it. 5 years so far, so it may be getting to it's end sooner v later. Motobatt are getting good reviews now, for good price and 2 year warranty.
boxerboy81 is offline   Reply With Quote
Old 06-08-2012, 02:12 AM   #3
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,577
unsubscribed.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider screwed with this post 06-08-2012 at 08:20 AM
Unstable Rider is offline   Reply With Quote
Old 06-08-2012, 03:46 AM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,202
Exactly how old is the battery?
It's hard to say what or where the fault could be. If it's not the battery, then it'll require breaking out the multi-meter and checking for current flow with key off.
In case you're not familiar with the procedure, with a good battery leave the negative disconnected. Turn the meter to AMPS and connect the leads to the battery negative and the ground cable. If current is flowing, it'll give you a reading. If nothing, switch to miliAMPs. If still nothing, it was the battery dying. If you do get a reading, start disconnecting things till the meter reads zero. I'd start at the starter relay since it has an unswitched hot lead.
Old 06-08-2012, 08:18 AM   #5
bikecat OP
bikecat's Avatar
Oddometer: 1,117
Battery is less than 6 months old. It is a Yuasa AGM 17.2 AH batt.
Now putting it on a tender in hopes of reviving it, if not for anything for my education.
Cheers
Old 06-08-2012, 08:28 AM   #6
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,753
My father had that problem on his R100S, I think he told me that it was something with the abs that doesn't wanted to shut down and ate the power even if the bike was off
Loutre is offline   Reply With Quote
Old 06-08-2012, 08:51 AM   #7
supershaft
because I can
Oddometer: 9,116
First things first. You need a new battery. How old is it? In my experience it really does not matter. New batteries fail all the time. Not as much as old batteries but that isn't saying much.
Old 06-08-2012, 10:02 AM   #8
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,746
Now putting it on a tender.
You've got a drain or a bad battery from the factory. The Yuasa's are usually great. I've had "off" brands die a quick death but never a Yuasa.
BTW, a tender will probably not reserect a dead battery, you'll need a good 1 amp charger overnight.
West - "Oeste Sanchez"
RideAbout is online now   Reply With Quote
Old 06-08-2012, 06:23 PM   #9
Wirespokes
Wirespokes's Avatar
Oddometer: 8,202
I wouldn't say off hand that it's bad!
I've recharged batteries lots of times and had them last years and years. So just because it's dead now doesn't necessarily mean it's toast!
True - draining a battery is bad for it, but doesn't necessarily mean it's now junk!
Old 06-09-2012, 06:25 AM   #10
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,973
I think that the Battery Tender needs to ba able to read a certain minimum voltage to start the charging cycle-- it doesn't like a dead-flat battery.
A couple of years ago I had a problem with a sticky brake light switch in a car and it drained the battery down to zero a few times. That battery died within a year.
'73 R60/5 Toaster
Times are GMT -7.   It's 09:46 AM.
