Old 06-09-2012, 03:26 AM   #1
Steve_Col OP
Steve_Col's Avatar
Oddometer: 13
GS100PD - Green Nuetral light not showing - so won't Start?
Green Neutral light not showing - so won't Start?
GS100PD 1994
Grrrrrrr
Intermittent fault:
Happened twice a couple months ago; got going with no repetition so I did nothing
Happened again tonight :
Happens when I pull up and Before switching off. I know I just clicked her up to neutral , yet the green light does not show.
Later, I go to fire her up - no green light - no firing - no start.
I rocked forth and back - hit into gear and out a coupla / few times - messed about with the switches ... Randomly the light came on and I was away.
Late
Cold - Icy ;
Not Happy Irene.
Any suggestions?
(I have noticed the green light is slow to come on regularly ... as if there is 'lag' between hitting neutral and the sensor / machine mind catching on to that fact.)
Steve
Steve_Col is offline   Reply With Quote
Old 06-09-2012, 04:47 AM   #2
jackd
Oddometer: 3,047
Pull the clutch lever in - try again.
Old 06-09-2012, 06:28 AM   #3
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,531
Could be your neutral switch. Clean the connections, if that doesnt works, jump the switch, if no lite may have to replace but chase the wire to the cluster and clean in there....then request the badass MOD to move this thread to "AIRHEADS"....you'll get more help there.
Old 06-09-2012, 06:36 AM   #4
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,687
..and if this doesn't work, adjust the switch at the clutch.
Boon Booni is online now   Reply With Quote
Times are GMT -7.   It's 09:43 PM.
