Old 06-10-2012, 03:13 PM   #16
Kai Ju
Kai Ju's Avatar
Oddometer: 1,817
Originally Posted by supershaft View Post
How did you get to those jets Kai Ju?
Do you mean the specs or the jets themselves ?
Thanks to a friend I got both from Sudco.
The original specs were close but needed a bit of help. They called for 17.5 pilots, not even close since the engine would only idle with the airscrews seated. I then tried 22.5 which brought the airscrew setting to 1/2 a turn out and now I'm running 25s with the airscrew right at one turn out. I could probably go to 30 since the plug body is clean with no carbon whatsoever around the perimeter.
The mainjet spec was 200 and the engine would gain power/rpm if I closed the throttle a touch. Made me think rich, so I tried 190s and it got worse. Went to 210s and I'm a happy man with a happy engine.
The rest of the specs seem to be right on the money. I'll ride for a week and see what happens. So far the plugs are burning very clean with just a hint of color at the tip and no detonation.
Kai Ju is offline   Reply With Quote
Old 06-10-2012, 04:10 PM   #17
supershaft
Oddometer: 9,110
I meant jet numbers or specs. Who's specs? Just curious.
I just reread your post and realized you got the specs from Sudco. They recommend jets for different model bikes? I did not know that! Is it somewhere in there manual?
supershaft screwed with this post 06-10-2012 at 04:25 PM
Old 06-10-2012, 05:36 PM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,462
They'll give you a rough starting point. They stay well to the rich side to be safe.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 06-10-2012 at 05:41 PM
Old 06-10-2012, 05:44 PM   #19
Kai Ju
Kai Ju's Avatar
Oddometer: 1,817
Jetting pecs
I don't know if they have different specs for different bikes. As you can see from my previous post they were close but did need a bit of work.
Times are GMT -7.   It's 11:39 AM.
