Old 06-09-2012, 05:39 PM   #1
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
Question about triple tree alignment
My R90/6 has what we think are XR600R forks and triples. The top tree has stripped threads, so I ordered a nifty billet one:
http://www.rswracing.com/xr600r.htm
But this part has about 3mm more offset than the one on my bike. The fork and stem holes are the right size, and the right distance side-to-side, but the fork holes are ~3mm farther forward than mine.
Am I right in assuming I can't use this? It doesn't line up with the bottom triple, and that would cause bad stresses if I tried to use it, correct?
If that's the case, I'll have to return it.
'74/'70 R98/6/GS Traveling Bike (construction under way)
'91 Bill Holland Steel w/Dura Ace
DiabloADV is offline   Reply With Quote
Old 06-09-2012, 06:08 PM   #2
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 3,254
If it doesn't line up properly it will put your tubes in a bind.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 06-09-2012, 07:01 PM   #3
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
That's what I thought. I emailed the vendor to try and figure out what triples I have.
Old 06-09-2012, 07:28 PM   #4
pommie john
pommie john's Avatar
Oddometer: 1,115
If you're prepared to spend a bit more money you could get it fixed.
I had the same problem with an old Honda I'm restoring, I bought a top triple clamp off ebay and it was from the same model, but a different year and the offset was 4mm different.
I took it to a good machine shop and they bored the centre hole bigger , but offset by 4mm and then made a sleeve to take it down to the original size.
Worked a treat and cost $50
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 06-10-2012, 05:34 PM   #5
hardwaregrrl
Shit for brains
hardwaregrrl's Avatar
Oddometer: 4,859
Man! That must've been a while ago, machine shops in the us routinely charge $150 an hour!
Old 06-10-2012, 06:15 PM   #6
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
I've now figured out that I have triples from a late-80's CR125R (before they went to USD forks on those). They have less offset than the XR600R, but same fork and stem sizes. Plenty listed on Ebay...if I can't find a nifty milled one, I'll get a used cast one and clean it up.
Those CR125's used the same forks as an XR600R.
Old 06-10-2012, 10:47 PM   #7
pommie john
Oddometer: 1,115
Last month!
The guy who did it used to spanner for Phil Read and always helps out racers.
Bertrand Russell
Times are GMT -7.   It's 11:48 AM.
