Old 06-09-2012, 09:59 PM   #1
Steve_Col OP
Steve_Col's Avatar
Oddometer: 13
Green Neutral light not showing - so won't Start?
GS100PD 1994
Grrrrrrr
Intermittent fault:
Happened twice a couple months ago; got going with no repetition so I did nothing
Happened again tonight :
Happens when I pull up and Before switching off. I know I just clicked her up to neutral , yet the green light does not show.
Later, I go to fire her up - no green light - no firing - no start.
I rocked forth and back - hit into gear and out a coupla / few times - messed about with the switches ... Randomly the light came on and I was away.
Late
Cold - Icy ;
Not Happy Irene.
Any suggestions?
(I have noticed the green light is slow to come on regularly ... as if there is 'lag' between hitting neutral and the sensor / machine mind catching on to that fact.)
(copied from 'Old Skool')
Steve_Col is offline   Reply With Quote
Old 06-10-2012, 12:17 AM   #2
BEAMER89
Oddometer: 14
One of my bikes didnt have the neutral light, try holding the clutch in while giving the start button a blurp, should still start.
BEAMER89 is offline   Reply With Quote
Old 06-10-2012, 12:26 AM   #3
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,364
The Neutral Switch sits at the low point of the gearbox. The switch can end up with sludge / water/ condensation around it, which will stop / slow it from functioning. Time for a gearbox oil change after a good fast run. Or to pull the switch out & replace it.
The bike has a lock out function to stop you starting it in gear. Just pull the clutch in to start it if the neutral light doesn't show.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 06-10-2012, 06:31 AM   #4
SRanger331
SRanger331's Avatar
Oddometer: 195
My wire came loose at the trans a few weeks ago. It was still in the hole, so sometimes it would make contact, sometimes not, which made the light act funny.
Ben
'73 BMW R60/5
'12 Yamaha FZ1
SRanger331 is offline   Reply With Quote
Old 06-10-2012, 07:08 AM   #5
Ray of Sunshine
Meat Donut 2 Some
Ray of Sunshine's Avatar
Oddometer: 16,862
There are two neutral lock out switches: the primary is in the bottom of the transmission housing, where it is a PITA to get to. The second is fight above the gear lever. It sometimes fails as well.
Usually, just pulling in the clutch lever will defeat these safety devices.
For the love of Baldy, would someone please buy my bikes?
Life is better, but why not?
Ray of Sunshine is offline   Reply With Quote
Old 06-10-2012, 04:17 PM   #6
daveoneshot
Oddometer: 402
Get the wires off the neutral switch with long nose pliers, and jump them together with wire and alligator clips, or something fabricated. Turn on the key, if you get your green light it's the neutral switch gone bad. Don't be a moron like me and try to jump the wires with a test light. That won't work. Keeping the wires jumped will get you a green light all the time.
daveoneshot is offline   Reply With Quote
Old 06-11-2012, 02:18 AM   #7
Padmei
enamoured
Oddometer: 3,739
Huh???
Padmei is offline   Reply With Quote
Old 06-11-2012, 05:13 AM   #8
patanga
BMWAirheadsDownunder
patanga's Avatar
Oddometer: 161
Originally Posted by Padmei View Post
Huh???
I'll second that ???
____________________
"The only reason people get lost in thought is because it's unfamiliar territory" (Joe Garcia)
Feel welcome to check us out on facebook at "BMW Airheads Downunder", (The Australia and New Zealand Airhead Community). "B.A.D"
http://www.facebook.com/groups/anzairheads/
patanga screwed with this post 06-15-2012 at 08:00 PM
patanga is offline   Reply With Quote
Old 06-11-2012, 08:35 AM   #9
daveoneshot
Oddometer: 402
Maybe he means clutch lever.
Old 06-11-2012, 08:56 AM   #10
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 554
Question 89 r100 gs
I have an 89 only starts in netural with the light on - will not start in gear with clutch lever pulled in. I thought this was a BMW by design feature. Are other's able to start their GS's in gear with clutch lever pulled in???? I may have a bad switch at the handlebar / clutch lever. Let hear from others.
Airhead
1974 R75/6 for sale & 1989 R100GS & 1983 Honda CB1000
Biebs is offline   Reply With Quote
Old 06-11-2012, 09:05 AM   #11
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,802
Switch might just need to be adjusted.
Old 06-11-2012, 09:21 AM   #12
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,037
Yes, just pull in clutch lever and bike will start.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 06-11-2012, 10:17 AM   #13
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,587
I had the safety switch on my ST. Couldn't start the bike in gear. No way! I jumped the clutch switch now I can start in any gear. I bet it's the neutral switch....the ONE and only under the trans
Old 06-11-2012, 01:02 PM   #14
ericrat
Oddometer: 1,221
Look more
Your clutch switch may not be working. I have a 78 so it is possible mine is different, but I don't think so. Also, I believe there is diode either in the headlight shell or near the starter relay too. I BELIEVE this keeps the clutch switch from back-feeding the neutral light or some-such, but will break the system if it goes bad.
In short, I think your problem is fixable and worth investigating. It is a bummer to stall at a light, or climbing up out of a creek bed and have to shift instead of just pressing the button and getting back going.
Eric
ericrat is offline   Reply With Quote
Times are GMT -7.   It's 03:17 AM.
