Old 06-10-2012, 05:47 PM   #1
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
Rear Brake rod, is it OK...
Is it ok to have an offset in the rear brake rod (drum brake) on a r75/5? During my rear end modifications things have been moved around, more specifically the rearsets I am using. I will end up with a 1" offset between actuator arm on drum and lever on rearset. So is it acceptable to make a brake rod with a 1" offset? Also while I have you reading, is it acceptable to use right angle ball joint linkages on a brake rod?
thanks
Leadnuts is offline   Reply With Quote
Old 06-10-2012, 05:54 PM   #2
JonnyCash
turd polisher
Oddometer: 1,625
The only thing I can think might happen is that if you're really stomping on the brake pedal, it might tend to straighten out the offset. I'd say give it a shot, it seems that a failure in this wouldn't be a dangerous situation, just a trip back to the drawing board.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 06-10-2012, 06:21 PM   #3
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,300
IMO, the real question here is if the brake rod breaks, is the failure mode brakes on or off?
The reason for my concern here is that a brake rod failure, of sorts, on a drum K-bike send me on a slow speed yet still painful highside...
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 06-10-2012, 07:08 PM   #4
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
i think
I think I may be able to use a "rose joint" and it just run at an angle...
Old 06-12-2012, 12:48 PM   #5
adventure950
Anglo-Saxon
Oddometer: 571
I have the rear brake rod offset on my dakar replica, I used a plate attached to the brake lever /rod mounting arm - to move the pivot point about 15mm inboard from the original point, the brake rod remains straight to aleviate any problems with distortion etc. May be a solution that might help.
'A tourist sees what he went to see,
a traveller sees what he sees'
adventure950 is offline   Reply With Quote
Times are GMT -7.   It's 03:36 PM.
