Old 06-12-2012, 01:06 PM   #16
Dustodust OP
Dustodust's Avatar
Oddometer: 1,036
Originally Posted by Cyclops Motorsports View Post
I do. and thanks. Before starting my lighting operation I was an aerospace and automotive composite toolmaker since the late 70's We still do quite a bit of prototype work
There are a lot of different ways to skin a cat. Ive developed a process of compression molding that does leave a very good face, however I still struggle with getting a perfect part every time. The naca ducts in that shield are a pain to say the least.
One advantage to infusion is that you layout the cloth dry, so you really see what you have, the disadvantage is that it is expensive. The next step up is RTM molding this requires a two sided sealed mold much like the compression process only the resin is injected..This is typ how high end ornate production composites are made. Alu or steel tools.
There is nothing wrong with a vacuum assist layup, its time consuming and expensive, then requires secondary ops to finish the part. Its still the way 90% of composite aircraft parts are made, only they use prepreg and dont care about the finish.
thanks for that, I dont feel too bad then that I just get a few small bubbles around the edges
can you suggest a better mold release than mguires carnuba ? it releases the part well but seems to interact with the surface of the epoxy,
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Dustodust screwed with this post 06-12-2012 at 01:11 PM
Old 06-12-2012, 02:26 PM   #17
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,732
any of the carnuba waxes should work well. Believe it or not for a very large unmentioned aircraft company the norm was treewax sold for doing wood floors. I still use it if I'm in a pinch.
I often use freekote, but that requires an oven.
what kind of reaction are you getting? Did you seal the mold surface?
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 06-12-2012, 02:38 PM   #18
el queso
toda su base
el queso's Avatar
Oddometer: 745
Could you also use PVA?
el queso is offline   Reply With Quote
Old 06-12-2012, 03:39 PM   #19
Dustodust OP
Dustodust's Avatar
Oddometer: 1,036
I originally planned to make only one so i didnt even do a gelcoat
it seems like the mold always needs a few runs to get conditioned , even after 5 coats and melting a few coats in with a hairdryer
if I use PVA it is really hard to release but the surface is more clear, the wax works great but leaves a dull finish that requires wetsanding with 600 and 1000 grit.
so I guess it doesnt get any better
04 KTM 950 S
Old 06-12-2012, 04:07 PM   #20
Off Road Ryder
Oddometer: 2,732
It does sound like a mold issue. Using pva is giving you a seal and making a better part. PVA has its own issues and is problematic for most. I think your doing fine..
1-800-624-0278
Old 06-15-2012, 04:04 PM   #21
Dustodust OP
Dustodust's Avatar
Oddometer: 1,036
just popped out another new baby
this one is real clean
04 KTM 950 S
Dustodust screwed with this post 06-17-2012 at 07:40 PM
Old 06-17-2012, 07:36 PM   #22
Dustodust OP
Dustodust's Avatar
Oddometer: 1,036
got another one done
I sold the last one I'll sell this one for $220 shipped
took this picture a few minutes ago , youll get the one pictured
04 KTM 950 S
Old 07-04-2012, 10:01 AM   #23
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,917
I would like to purchase your windscreen.
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Old 07-04-2012, 11:32 AM   #24
etingelefunts
retem-odo
etingelefunts's Avatar
Oddometer: 818
I tried to reach you yesterday.
PM'd you my email address the other day.
Posted in your other thread (link shown) yesterday as well; http://advrider.com/forums/showthread.php?p=18975877#post18975877
Still standing by.
If you send payment instructions to my email address in the PM I will pay immediately.
Thanks,
Kip
Less pondering. Simply march ahead, to the ends of this majestic planet.
etingelefunts is offline   Reply With Quote
Old 07-04-2012, 12:56 PM   #25
Dustodust OP
Dustodust's Avatar
Oddometer: 1,036
sold that one and another
thanks, I will get more out asap but I am working a regular job too
it takes me aboiut three days each
I replied to the email and PM
Still standing by.
Thanks,
Kip
04 KTM 950 S
Old 08-26-2012, 10:29 AM   #26
Dustodust OP
Dustodust's Avatar
Oddometer: 1,036
Still standing by.
Thanks,
Kip
Sorry for taking so long Kip still working on that one for you
thanks for your patience
04 KTM 950 S
Old 09-16-2012, 09:40 PM   #27
Dustodust OP
Dustodust's Avatar
Oddometer: 1,036
I had a few structurally correct,, four layers of carbon/epoxy
they had some cosmetic flaws on the face
I finished them with finish polyester
Glorious Gloss Black
I put them up in the Flea Market section
http://advrider.com/forums/showthrea...6#post19610386
Buy one and help me make it to production level
your neck will thank you
and so will your ears
vacuum bagged epox and 2x2 twill
04 KTM 950 S
Dustodust screwed with this post 09-16-2012 at 11:02 PM
Old 09-18-2012, 09:47 PM   #28
Dustodust OP
Dustodust's Avatar
Oddometer: 1,036
Got the UV coating sorted
now working on more casting
04 KTM 950 S
Dustodust screwed with this post 09-18-2012 at 09:53 PM
Old 09-19-2012, 09:15 PM   #29
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,834
Your finishing them with polyester what? paint or gelcoat?
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is online now   Reply With Quote
Old 10-15-2012, 08:26 AM   #30
catalina38
Contrarian
Oddometer: 1,659
Got a chance to use mine yesterday, excellent at highway speeds and better visibility off road.
Looks good on the bike as well, I never liked the look of cut down standard shields.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Times are GMT -7.   It's 06:35 AM.
