Old 05-20-2013, 06:02 PM   #1
DR-Zamboni OP
DR-Zamboni's Avatar
Oddometer: 101
drz suddenly wont start
Went to go for a ride today and sure enough there were problems.
Heres the background: The bike has been consuming oil for the past 1000 miles since I did a big bore upgrade. Other than that it has been running fine, and yes i have been super meticulous about keeping a good amount of oil in it. I made sure fuel was flowing, can smell gas out the pipe, and cleaned the air filter. I pulled the plug and it there was a good amount of soft carbon build up around the edge of the plug, but not much on the electrode. I had a spare new plug so i put a fresh one in.
The no start issue is like this: turns over freely, nothing sounds bad. It does fire but only while i have the starter button pressed, with full choke, and half throttle. It will sputter the whole time the starter is engaged.
Im thinking my valves may have a good amount of carbon on them resulting in a bad seal and low compression. the weird thing is the fact it will fire and run for a second and then die under the conditions i stated above.
Im pretty mechanically inclined so im really just looking for a little push in the right direction. I know the rings didnt seat after the big bore upgrade so i have a new set and a gasket set on hand. Pulling the top end off is this weekends project.
DR-Zamboni is offline   Reply With Quote
Old 05-20-2013, 06:16 PM   #2
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Rings were my guess on oil consumption and not firing.
Danjal is offline   Reply With Quote
Old 05-20-2013, 10:30 PM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
I think a compression test is the first place to start, then go from what you find there.
GreaseMonkey is offline   Reply With Quote
Old 05-21-2013, 01:36 AM   #4
willis 2000
neo-quixote
Oddometer: 3,659
intake air leaks have caused no-start conditions
on a coupla my 'thumpers'
o-rings get smashed flat
gaskets and boots fail
willis 2000 is offline   Reply With Quote
Old 05-24-2013, 09:46 PM   #5
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Did you change the jetting after increasing the displacement?
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 05-25-2013, 12:53 AM   #6
fetchfire
Oddometer: 35
It's probably not this but here's something simple to check that I felt really dum finding after hours of trying get my drz started. If the reserve hose is not in properly then the main hose doesn't get any fuel. Must be a suction thing. Mine wouldn't start after changing the spark plug and that was it.
fetchfire is offline   Reply With Quote
Old 05-26-2013, 05:24 PM   #7
DR-Zamboni OP
DR-Zamboni's Avatar
Oddometer: 101
I did not re-jet after the big bore, i was told i did not have to. The reason being that the bike comes stock pretty lean, and adding displacement would result in a richer mixture. that makes sense if you think about how a carb works.
I did some work to the carb today to try and see if that was the issue. Cleaned the pilot and main, and just did a good overall cleaning. Hit the starter and same thing. Starts for half a second while my finger is on the starter with half throttle. Otherwise it just sputters.
Gonna put some time aside, look for a willing friend with a garage, and pull the top end apart in the next week or two. Unfortunately I have a lot of time tied up with work and travel currently.
Times are GMT -7.   It's 06:52 PM.
