Old 06-16-2012, 05:28 AM   #16
Mavtroll OP
Oddometer: 22
Cheers will look
Sent from my iPad using Tapatalk HD
Mavtroll is offline   Reply With Quote
Old 06-16-2012, 06:11 AM   #17
sandwash
sandwash's Avatar
Oddometer: 1,361
I drilled 3 1" thought he chamber on my 35,ya now you can see daylight though it. I am sure it breaths way better now.
97dr650
sandwash is offline   Reply With Quote
Old 06-17-2012, 03:21 PM   #18
Mavtroll OP
Oddometer: 22
just a quick one, found a 2004 hyabusa exhaust at a reasonable price, with a custom mid pipe would that fit and improve the sound of the bike?
cheers
Old 06-18-2012, 01:02 AM   #19
LukasM
Oddometer: 5,425
I have never heard of anybody using a Hayabusa muffler.
Unless you have a tubing bender and TIG welder I would say save yourself the headache and get the perfectly fitting and well proven 01/02 mufflers, ideally the Titanium 1000 version, or the easier to find but heavier and a bit more restrictive 600/750 one.
Old 06-18-2012, 06:16 AM   #20
gunut75
Oddometer: 84
Cool2 The Busa unit!
x24FOx is the Busa muffler. It works well, and is 1" longer and weighs 1 lb more than the titanium unit. I got one for nothing that I'm going to use on my SP600 (same as a DR600 but with a CV carb). From what I've read, they work just as well performance-wise. Like said before though, you will need to custom fab a mid-pipe. Also the flange on the Busa muffler has 3 studs instead of 4.
05 Buell XB12RsTT
85 Suzuki SP600 tard project (in progress)
gunut75 is offline   Reply With Quote
Old 06-19-2012, 12:26 AM   #21
Mavtroll OP
Oddometer: 22
Awesome - just got a pair cheaply so will see how I go - and now I have a spare:-)
Will post a before and after video
Old 06-28-2012, 04:37 PM   #22
Mavtroll OP
Oddometer: 22
New busa exhaust goes on today, getting custom mid pipe (very simple as the 3 bolt flange is a standard car fitment) thinking of turning the second pipe into a reserve fuel tank and bolting to the other side to look like twin pipes... worked out the volume to be around 4.5L. will report back with pics when i get started
Old 06-28-2012, 05:39 PM   #23
40cu.in.of.furey
40cu.in.of.furey's Avatar
Oddometer: 224
We were at an event that requires sound check and I have a GSXR pipe and FCRmx carb with the stock pipe and it was at 93db
07 DR650SE w/ FCR MX carb
01 Honda VFR800FI
73 Honda SL125
40cu.in.of.furey is offline   Reply With Quote
Old 06-28-2012, 06:29 PM   #24
ER70S-2
ER70S-2's Avatar
Oddometer: 6,671
Good info. How about you copy that post here:
http://www.advrider.com/forums/showthread.php?t=636381
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 06-29-2012, 03:12 AM   #25
Mavtroll OP
Oddometer: 22
Cost for mid pipe including fitting $90... Removed the guts of the lh pipe ready to make my fuel tank
Straight with BALLS!!!!
Old 06-29-2012, 05:09 AM   #26
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
Definately put the money on a pumper carb or suspension. Better improvements than an exhaust IMO.
You could do what I did and get the DG exhaust off Ebay for $159. It's a well made exhaust and sounds good if you like the louder aftermarket sound, but I got it because of the well made mid pipe and will be having an adapter plate welded on for the GSXR x40F0x titanium muffler that I finally found! You can get the adapter plate and nice mounting hardware from Jesse at Keintech, or make your own You could also get the midpipe and mounting kit from Jesse for $220. I wanted the DG midpipe since it had an additional mounting point that the others are missing.
Jesse now has kits for the Busa 1300 24F0 muffler. He did this since the 40F0s were getting harder to find and more costly. He also may have some 24F0 mufflers left so you could get the complete setup from him fitted and ready to bolt on.
http://www.kientech.com/DR650GSXRExaust.htm
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper screwed with this post 06-29-2012 at 05:15 AM
GaThumper is offline   Reply With Quote
Old 08-07-2012, 08:01 PM   #27
Pike Bishop
Pull Down the Ponzi.
Pike Bishop's Avatar
Oddometer: 10,573
I know this has been discussed to death but ... what year GSXR600 muffler would I want for a 2009 DR650 ?
Pike Bishop is offline   Reply With Quote
Old 08-07-2012, 08:21 PM   #28
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,211
I have both the GSXR 40F0 and the Busa 24F0; I had the GSXR on my bike, but ended up putting it on my son's bike and going with the Busa on mine... IMO the 40F0 sounds better, but tends to pop more on decel. The Busa can seems to have the perfect amount of back pressure for a DR650, which makes sense, as it's half the cc's of the 1300 Busa. Here is a youtube video comparing the two...
http://www.youtube.com/watch?v=Blgfck1ni-A
I recently came across a huge stash of GSXR and Busa cans in a local salvage yard, all of them new take offs, sent them all to Jesse, so he may have some of these left over. Having personally had the 35, 40, and 24, I chose to stay with the 24, though I wouldn't hesitate having any of them on my bike; they make that much difference.
dogjaw is offline   Reply With Quote
Old 08-07-2012, 08:22 PM   #29
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,211
and the GSXR 600/750 cans are from 2000-2004, 35FO stamped on the side...
Old 08-07-2012, 08:30 PM   #30
Pike Bishop
Oddometer: 10,573
Thanks, Dogjaw. I guess this one (LINK) is a no-go...?
Times are GMT -7.   It's 02:49 AM.
