Old 05-18-2005, 07:39 PM   #1
Batman640 OP
Oddometer: 40
Question Sprocket Size gearing
I have a 05 640adv, stock sprockets are 16/42, with this combination it rev at about 4200rpm at 100kms/hr on the speedo.
What changes to the rpm does changing the sprockets, ie putting a 51 on the back will make it rev higher, but does anybody have the rpm number it would change it to.
We could make up a table with all sproket combinations?
05' 640 Adv
Batman640 is offline   Reply With Quote
Old 05-18-2005, 08:08 PM   #2
Jeff620RXC
Jeff620RXC's Avatar
Oddometer: 567
gearing
Like this?:
Spreadsheet
Jeff620RXC is offline   Reply With Quote
Old 05-18-2005, 08:13 PM   #3
Batman640 OP
Oddometer: 40
Thanks Jeff, just what I need.
05' 640 Adv
Old 05-18-2005, 08:31 PM   #4
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,732
how about the one i made specifically for the ktm lc4
http://www.ktmcanada.com/lc4_gearing.xls
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 05-18-2005, 08:36 PM   #5
Batman640 OP
Oddometer: 40
Thanks, even better
05' 640 Adv
Old 05-18-2005, 08:43 PM   #6
Jeff620RXC
Jeff620RXC's Avatar
Oddometer: 567
You just had to one up me, didn't ya!
Almost as bad a Creeper!
Thanks, I hadn't seen that one. Nice! Even if it is in freakin km/hr!
Old 05-18-2005, 08:50 PM   #7
Loadedagain
making chips
Oddometer: 26,732
one flippin imperial country left.... and you lot build all yer stuff in metric... so feegure it out sunshine.
Old 05-18-2005, 09:12 PM   #8
viverrid
not dead yet
Oddometer: 30,482
Don't go making it harder than it is. Not a complex secret formula by any means, when starting from an already known single point, and just wanting to know the change, it is not necessary to start from scratch using tranny ratios, primary drive, tire diameter, etc.
Looky here, if you doubled the size of the back sprocket (yeah, not possible, wouldn't fit, but for example) the rpm would double for the same speed. 25% larger, up 25%. 10% higher, up 10%. So just figure the percent change in the sprocket sizes, and then its that same percentage change to the rpm.
The next step would be to look at the front sprocket. And then simultaneous changes to both front and rear.....
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 05-18-2005, 10:09 PM   #9
Loadedagain
making chips
Oddometer: 26,732
true true... i made the spreadsheet coz i'm a fuckin engineer. thats what i do.. i beat shit to death with numbers, ok? i found it helpful when i graphed the valus with different sprockets. gave me an idea what to order.... then i ordered three gear sets i need more r&d
Old 05-18-2005, 10:20 PM   #10
ram1000
ram1000's Avatar
Oddometer: 1,833
My 2002 dualsport came with 16/42 and I recently put new sprockets on. I went 16/44 this time and with a 15 front I have what I think is just the right gearing for dirt single track. I will go back to 16 for desert and up to 17 for street trips.
ram1000 is offline   Reply With Quote
Old 05-18-2005, 10:22 PM   #11
Loadedagain
making chips
Oddometer: 26,732
just remember the 17 requires a trip to the grinder, or the duke2 front sprocket guard.
Old 05-18-2005, 10:58 PM   #12
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,223
Resistance is futile; you will be assimilated.
Or you will die while we try to free you godless pinko commie arses from the satanic metric system...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-18-2005, 11:17 PM   #13
Loadedagain
making chips
Oddometer: 26,732
why does america build everything metric then convert to imperial?
as soon as the general population figure that out they're gonna be pissed. you don't believe me take a look at a carton of milk... it's litres man. litres! your cars use metric bolts with metric dimensions... how big is the eingine in your car? 5.4 litres right?
you are metric already... just don't know it.. that's all.
Old 05-19-2005, 12:14 AM   #14
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,357
SHHH!
Its a sneaky attempt by the govt to get us to give up the Imperial/SAE units.
Over my 172cm tall dead body! (that's 5'8" for the rest of us)
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 05-19-2005, 12:54 AM   #15
viverrid
not dead yet
Oddometer: 30,482
Please remain calm....
Loaded, wasn't "lecturing" YOU. More addressed to the OP, saying hey, its not really that hard to figure out what your RPM will be, at a given speed where you knew what the RPM used to be, with a specific new sprocket. (And he could also test it empirically....)
I (used to be) an engineer too. (Now I just move money around.) What's that saying, "I didn't even used to be able to spell enjineer, and now I are one!"
Times are GMT -7.   It's 05:35 AM.
