Old 06-18-2012, 08:13 PM   #1
robotgoesnuts OP
Oddometer: 12
engineer a bultaco sidestand mount
senor bulto in his infinite wisdom decided that a detachable square stock sidestand was a good thing.
that works great in a race when you are going to circle back and pick up the side stand. not so good when you are just tooling around town, and need to haul the sidestand with you. currently some velcro holds the sidestand to the bars.
certainly someone has engineered an ingenious method to attach the side stand to the bars or somewhere else that is better than velcro?
i'd rather not reinvent the wheel. I can build something with a buncha polisport handlebar parts that will provide quick detach with a couple wingnuts. maybe someone has already done this?
robotgoesnuts is offline   Reply With Quote
Old 06-19-2012, 08:25 AM   #2
blaine.hale
blaine.hale's Avatar
Oddometer: 3,167
What the hell model are you running that has a detachable side stand?
Post some pics, I'm totally interested :)
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale screwed with this post 06-19-2012 at 08:47 AM
blaine.hale is online now   Reply With Quote
Old 06-19-2012, 03:19 PM   #3
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
all the pursang frames had detachable side stands..
current bikes
stainlesscycle is offline   Reply With Quote
Old 06-19-2012, 04:36 PM   #4
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 863
Take a piece of 8mm steelplate and cut it out so you have one hole for a pin, can be for a 6 or 8mm bolt and another hole for the sidestand, at least 18 - 20mm, you can too place a ring washer for better action between the bolt of the sidestand and the hole for the side stand mount. Ad an abutment for the side stand.
Weld it to the swing arm.
take a tube between 15 - 18mm, bend it to your needs, weld a plate to the lower end and full pipe to the other end,
drill a hole and a cut a 8mm groove in the full tube. then a second pin for the spring and then you have a nice side stand just mounted with one bolt. You can mount it on the left or right side as you want.
If you don't want to see the spring, weld the pins on the rear side of the mount and the side stand.
PSchrauber is offline   Reply With Quote
Old 06-19-2012, 06:44 PM   #5
robotgoesnuts OP
Oddometer: 12
not interested in adding a sidestand to the bike. looking for an elegant solution to mount the detachable sidestand. i think i have a pretty good solution with polisport bar end mounts attached to the crossbar. just looking for the quickest fastener mount/demount options. something faster/more convenient than lynch pins or hitch pins. the fastener needs to stay attached to the mounts whether the sidestand is on or not, this rules out the spring loaded hitch pins.
Old 06-19-2012, 06:52 PM   #6
robotgoesnuts OP
Oddometer: 12
here's a picture of the current velcro mount. this bike will never see dirt, but it needs to be a convenient around town bike
robotgoesnuts screwed with this post 06-19-2012 at 07:24 PM
Old 06-20-2012, 06:34 AM   #7
blaine.hale
Oddometer: 3,167
Still curious as to what model it is is because Pursangs are, by no means, street legal for putting around town.
If it is a pursang (the tank colors indicate it might be,) how are you riding that around town?
1974 BMW R90 /6
Old 06-20-2012, 09:01 AM   #8
PSchrauber
PSchrauber's Avatar
Oddometer: 863
This setup with the sidestand shown above is not contemporary
Old 06-20-2012, 09:36 AM   #9
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,282
Nice wing nut
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 06-20-2012, 06:30 PM   #10
robotgoesnuts OP
Oddometer: 12
owner wanted a street-legal pursang, so thats what this franken-taco is.
started as a model 192.with new fiberglass and a 134? tank. out came the motoplat, in went points.
6v electrics. headlight/taillight/brake switch/mini mirror/horn/license plate bracket.
street legal.
Times are GMT -7.   It's 07:32 AM.
