Go Back   ADVrider > Riding > Regional Forums > Southeast, The Lair of the Dragon - The Blue Ridge and Smoky Mountains
Old 05-19-2005, 04:08 PM   #16
DNFjoe
Did Not Finnish
DNFjoe's Avatar
Oddometer: 653
Originally Posted by xsquiggy
Other than saving all my saved files on CD/R discs (which I haven't done), what systems are available to back up the hard drive info? Should I get one of those USB plug in hard drives and save everything twice, once on my computer and once on the USB drive? I really dont want to lose all the stuff on this drive (business records, etc.)
IOmega makes zip drives that use disks which hold upto 750meg each on them. nice that you can always buy more disks to add additional storage and you can save and delete info over and over again. If the drive fails the info is on the disk so no big deal. Just another option.
joe
The journey is more important than the destination.
DNFjoe is offline   Reply With Quote
Old 05-19-2005, 05:31 PM   #17
achilles
b00b
Oddometer: 73
Do you hear anynoise from the disk drive at all? If you put your hand on it, can you feel it spinning?
More than a few times, I have been able to get a failed disk to boot again by; removing the HD. Checking connectors for obvious damage or dust/dirt. Then, reinstall and try boot.
If the computer is anywhere abnormally cold, you might want to warm the drive up a bit before installing, maybe give a it few good whacks with your hand. Not real hard, just enough to get the spindle moving if it happens to be stuck or binding.
And also get a good backup of your stuff. Most computers suck, and they do eventually fail.
achilles screwed with this post 05-19-2005 at 05:35 PM Reason: Forgot to mention.
achilles is offline   Reply With Quote
Old 05-19-2005, 06:54 PM   #18
NCDan
Absolute Beginner
NCDan's Avatar
Oddometer: 1,191
The USB or network drive is not a bad way to go. Some have a a backup function built in them. Or a DVD-R can be another option. Good luck.
NCDan is offline   Reply With Quote
Times are GMT -7.   It's 08:48 PM.
