Old 06-21-2012, 07:43 AM   #1
Myway OP
Myway's Avatar
Oddometer: 3,103
Data record wheelsensor/RBpoint for roadbook.
Here it goes futher
Originally Posted by Myway View Post
You need a new kind of tripmaster. for making a roadbook ride.
That record wheel distance and have a button to push where you want a roadbooksymbol. (RBpoint, lat/lon)
Because track gps record is not that accurate.
A bluetooth module with that button and the wheelsensor attached.
Are there such commom modules.????????
On your device (with gps) a software app to record the data.
Or even moving waypoint symbols to handle with gloves on.
Or even record CAP change.
I would like that in wm android etc.
Writing on paper takes a lot of time time. Then rewriting it again.
On PC laptop
And data is easier to change in a xml enviroment.
Next to each other:
  • the wheelsensor datatrack and RBpointdata.
  • GPS track data
  • Map of both tracks.
Clicking on the dat shows were you are.
Hand change the data.
BT more devices we can use.
There is Ant+
something like the:
http://www.royaltek.com/index.php/bv-3200
2.4GHz ANT+ communication
pedal frequency, front wheel frequency?
This need a new topic!!!!
Myway screwed with this post 06-24-2012 at 07:45 AM
Myway is online now   Reply With Quote
Old 06-22-2012, 03:29 PM   #2
schattat
schattat's Avatar
Oddometer: 1,442
Interesting
RNS - Rallye Navigation Solutions
Yamaha WR450F Rallye Spec
schattat is offline   Reply With Quote
Old 06-24-2012, 04:49 AM   #3
Myway OP
Myway's Avatar
Oddometer: 3,103
RB button that also makes a voice recorded file (button holding down) attached to that RBpoint. (GPSdated) with BT helmet set.
Or/and
making a file Voicenotepoint VNpoint (GPSdata) new VN button
For collecting easy Roodbookinformation, but keeps the hands on the bar.
No pencil writing, saves a lot of time. Spoken a lot more info.
No taken out extra tools out of bags.
Must be cheap, the cheaper the more people can make easier collect info for roadbooks. Common components.
The more roadbooks we can ride.
What you get:
1. RBpoint track with RBpoints with VN ( holding down RB button is recording voice). Track set also on: meter or second wheeldistance data tracking. Reeditble afterward.
2. VNpoint track with VNpoints, VN button holding down. voice notes
3. GPS track.
Old 06-24-2012, 03:12 PM   #4
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,715
3. GPS track.
That's in the works already, with a lot more features! It's not cheap though. If you want cheap, buy I basic digital voice recorder ($15) like I use for making roadbook notes while prerunning. I took this one and rewired the switch for handlebar mounting. I originally had it mounted in my helmet, but it didn't work so well there. Engine noise can be a problem, so it's sometimes best to let the revs go down or stop while you speak.
http://www.dealextreme.com/p/usb-rec...-48624?item=26
New desert racing frontiers
It will be Devilish !
HogWild is offline   Reply With Quote
Old 03-10-2013, 05:27 AM   #5
Myway OP
Myway's Avatar
Oddometer: 3,103
Old 03-10-2013, 10:06 AM   #6
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,715
That iPhone app looks pretty good! But the video doesn't show how of if you can get the GPS tracks and waypoioints out of the phone and into a computer.
Of course it comes right after I already bought this GPS logger / voice recorder:
http://cbgps.com/v900/v900_index_en.htm
I'll be testing the Columbus unit next weekend while doing some diabolical rally prerunning in Mexico.
Old 03-10-2013, 10:51 AM   #7
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,698
the trippy gps records and has softaware included to write roadbooks the only thing lacking is a voice recorder... but I will velcro a cheap sansa mp3 with voice recorder to mine
wrk2surf is offline   Reply With Quote
Times are GMT -7.   It's 01:59 AM.
