Old 06-23-2012, 07:36 AM   #1
jdub OP
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,894
Another R1200GS Adv. 100,000 Miler
I thought it most appropriate that my faithful 2007 R1200GS Adventure just rolled over the 100,000 mile mark while carrying the lovely Missus jdub and I on a great 5,124 mile trip through the western U.S. The event happened on beautiful U.S. Rt. 89 just past Bear Lake, shortly after crossing into Wyoming from Idaho. I'm getting used now to seeing six digits on the odometer! A few appropriate pics marking the occasion are provided below.
Before:
After:
This bike continues to prove itself as the best, most versatile motorcycle I've ever owned, and I'm already looking ahead to at least the 200,000 mile mark with it. While various issues on GSs/GSAs have been well documented on this forum, this bike has had zero issues with the final drive, driveshaft u-joints, ABS, etc. It just continues to take all of the road miles and the off-road usage (including drops) as well and as reliably as could be expected of any bike.
For anyone interested, here's some historical background:
- I purchased it used from Carolina BMW in August 2008 with 15,717 miles. The key/antenna ring thingie had already been replaced under warranty at 8k miles.
- All engine oil changes performed every 6,000 miles per OEM recommendation. Used Castrol GTX 20w-50 until 30k miles, then Mobil 1 15w-50 synthetic ever since. Has always used about half a quart between changes; less consumption during long trips/less starts, and more consumption with shorter trips/more starts.
- Gearbox and final drive oil changed every 12,000 miles per OEM recommendation, using Mobil 1 75w-90 synthetic.
- Bob's BMW replaced leaking gearbox output seal and clutch slave cylinder under warranty at 35k miles.
- NGK DCPR8EIX Iridium spark plugs used for the last 60k miles, on second set now after 48k miles on the first set.
- Battery changed once, at 53k miles.
- Elka custom-built shocks installed at 50k miles; serviced/rebuilt at 90k miles with no wear or damage found.
- Bob's BMW performed three recalls at 59k miles: front brake hose, fuel pump controller seal, and fuel tank mounting hardware.
- I pulled the gearbox at 68k miles for clutch spline lube, details can be found on the link provided at the end of this post (no issues found, and the original clutch is still installed). I'll pull the gearbox again this winter for another lube and check of the clutch thickness, likely at about 120k miles.
- Rear brake disc replaced at 75k miles, too thin to pass annual PA state safety inspection.
Tire history:
1. Replaced Anakees with Tourances at 16,606 miles.
2. Installed Anakee 2s at 28,591 (11,985 miles on Tourances)
3. Installed Shinko 705 bias ply at 39,918 (11,327 on A2s)
4. Installed TKC-80s at 44,340 (4,422 on Shinkos, had the infamous tread block separation)
5. Installed TKC-80s at 51,270 (6,930 on 1st pair of TKCs)
6. Installed Tourances at 56,514 (5,244 on 2nd pair of TKCs)
7. Installed Tourances at 67,783 (11,269)
8. Installed Heidenau K60s at 71,805 (4,022 on Tourances, kept for later remounting)
9. Reinstalled Tourances at 83,893 (12,088 on K60s, both still had thousands of miles left)
10. Installed Kenda Big Blocks at 89,193 (9,322 total on Tourances)
11. Installed TKC-80s at 92,008 (2,815 on BBs)
12. Installed Tourances at 97,073 (5,065 on TKCs with tread remaining)
(Note: Below additional tire update info added 5/28/2014)
13. Installed new Pirelli Scorpion Rally rear and used TKC-80 front at 109,957 miles (12,884 on Tourances)
14. Installed new front TKC-80 at 113,615 (8,723 total on front TKC-80)
15. Installed new rear TKC-80 at 115,210 (5,253 on Scorpion Rally)
16. Installed new TKC-80s at 120,232 (6,617 on front, 5,022 on rear)
17. Installed new Conti Trail Attacks at 123,312 (sold TKCs w/ 3,080)
18. Installed new Trail Attack 2s at 136,651 (13,339 on TAs)
Except with the BMW dealer warranty/recall work as noted above, I perform all of my own maintenance including tire changes and balances. Maintenance is per the BMW schedule, except for the last 60k or so miles I've only checked valve clearances every 12k miles instead of the 6k miles called for. The most I ever find is two or three valves off by .0005" (one-half thousandth), and I'll adjust those when I find them. I haven't even bothered checking throttle body synchronization in probably 36k miles because the bike remains perfectly smooth and I'll only mess that up if I fiddle with the TB sync.
I'll add two more pics below for your viewing pleasure, the first I took while descending Beartooth Pass (U.S. Rt. 212) in Montana because the routing on the GPS screen was pretty unique with the switchbacks. The second is an end of trip shot, again with the lovely Missus jdub and some gray/bald guy who spends a lot of time riding and loving this GSA!
I hope all of your rides go well, my fellow inmates!
Current: 2014 R1200GSW
jdub screwed with this post 05-28-2014 at 07:51 AM Reason: Additional tire usage history
jdub is offline   Reply With Quote
Old 06-23-2012, 07:53 AM   #2
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,305
Congrats! Hope you have a great time getting to 200K.
ride till you can't.
1200GS/black
Boxer Cup Replika/red-white-blue
Semper Paratus
marty hill is online now   Reply With Quote
Old 06-23-2012, 08:04 AM   #3
ghostryder
made it
ghostryder's Avatar
Oddometer: 5,962
Congrats.....hope you enjoy it for many more miles!!!!
ghostryder is offline   Reply With Quote
Old 06-23-2012, 08:53 AM   #4
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,848
Great job, Jdub!! Congratulations.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 06-23-2012, 09:03 AM   #5
kildala2000
The GS Store.
kildala2000's Avatar
Oddometer: 2,070
Thumb Cool
Good Job,
I know you will make the 200K mark with good maintenance and some TLC.
Ride Safe,
Rick
kildala2000 is online now   Reply With Quote
Old 06-23-2012, 09:10 AM   #6
AdventurePoser
AdventurePoser's Avatar
Oddometer: 1,972
Great post, JDub! Thanks for the detailed info about the bike as well....For me, 24,000 on my 2011 GSA since last April and no issues.
I've had about a trillion bikes in the past (ok, 8) all of them except one a BMW and this GSA is easily the best overall scoot I've ever owned, bar none! This summer 12k miles around the intermountain west, the deep south and then up to Maine for a lobster roll.
One thing...you might try the Shinko 705 radials. Super inexpensive and great mileage. Reasonable on dirt roads too. My front Shinko has 14,000 on it and looks new. Replacing the rear every 8-10 k. Not bad considering a full set costs about $140.....
Ride safe,
Steve
"Converting oxygen to carbon dioxide since 1951."
www.ridesroadsandeats.com
AdventurePoser is offline   Reply With Quote
Old 06-23-2012, 10:48 AM   #7
Litespeed602
Going in Circles
Litespeed602's Avatar
Oddometer: 846
Good to hear you are home and well. Sounds like a great trip, Lisa must be as tough as you
More photos ----more photos
2010--Labrador City----no report
2011--James Bay Road---http://www.advrider.com/forums/showthread.php?t=715690
2013--Nova Scotia---http://www.advrider.com/forms/showthread.php?t=907004
2014---Deadhorse, Alaska
http://www.advrider.com/forums/showthread.php?t=991514
Litespeed602 is offline   Reply With Quote
Old 06-23-2012, 11:01 AM   #8
mtwillyman
Lost and Cornfuzed
mtwillyman's Avatar
Oddometer: 623
Wow!
More posts like these could restore my faith in the marque. Post brightened my morning.
mtwillyman is offline   Reply With Quote
Old 06-23-2012, 11:20 AM   #9
Big Bro
Oddometer: 14
It's great to see posts like this. Most folks just post when they have a problem, so thank you!
Big Bro is offline   Reply With Quote
Old 06-23-2012, 11:41 AM   #10
cozmo2312
Canyon Carver
cozmo2312's Avatar
Oddometer: 288
so much this! thanks!
2014 Ducati Hypermotard SP
cozmo2312 is offline   Reply With Quote
Old 06-23-2012, 01:32 PM   #11
bobobob
badbadbad
bobobob's Avatar
Oddometer: 6,599
Nice detailed report. Thanks.
It is just a bunch of inner tubes Roy . . . - Cannonshot
Growing old is compulsory - growing up is optional. - Haroon
bobobob is offline   Reply With Quote
Old 06-23-2012, 04:32 PM   #12
Davis53
Oddometer: 576
What kind of seat for 100,000 miles? Looks like a Sargent?
Davis53 is offline   Reply With Quote
Old 06-23-2012, 04:44 PM   #13
AdventurePoser
Oddometer: 1,972
I agree...I'm not the highest mileage rider out there (about 270,000 in the past 12 years) but I've done nearly all those miles on BMW's and have suffered only one breakdown that required a tow truck.
So far, I am a very happy GSA rider!
Steve
Old 06-23-2012, 05:33 PM   #14
Bluecomet
What, me worry?
Bluecomet's Avatar
Oddometer: 117
Thanks for the POSITIVE Report
Great positive report and success story. Your experience is why I bought a Beemer. Thanks for sharing!
Bluecomet is offline   Reply With Quote
Old 06-23-2012, 05:56 PM   #15
going south
hero & Zero...
going south's Avatar
Oddometer: 1,180
congrats on 100K good luck on 200K
Thanks on the low down on tires & maintenance..
I love these bikes....
going south...
Never Lost! Just Don't know where I am!
"Don't worry about your money, let your money worry about you" Jorge González
going south is offline   Reply With Quote
Times are GMT -7.   It's 08:36 PM.
