Old 06-24-2012, 05:47 AM   #1
soul_adventurer OP
grin and bear it
soul_adventurer's Avatar
Oddometer: 353
inflatable tubes for river crossings
im searching for inflatable river tubes to carry the bike across deep water crossings. ive seen them in use in a motosyberia.com picture on another part of the forum. basically it looks like a small raft comprised of 3 separate chambers which when inflated, carries the bike high and dry (on its side).
i trying to locate a supplier or any other information about them but not having any luck at present.
can anyone assist?
bernadette
soul_adventurer is offline   Reply With Quote
Old 06-24-2012, 06:28 AM   #2
ssevy
Oddometer: 931
These folks make a great product, and you may be able to use one of their existing designs for your purpose (and have the bonus of using it as intended for yourself when you want), or perhaps they would do a custom design for you? Just tossing this out in case you can't find the other system you mentioned.(maybe military in origin?)
http://www.alpackaraft.com/
ssevy is offline   Reply With Quote
Old 06-24-2012, 10:26 AM   #3
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,291
You could try working with a local fly fishing or whitewater rafting supply outlet. Some of the float tubes and catarafts are made to be light and portable enough to backpack with. You might be able to get just the tubes for a deal.
Sparrowhawk is offline   Reply With Quote
Old 06-24-2012, 10:39 PM   #4
Thinc2
Paciugo
Thinc2's Avatar
Oddometer: 4,659
Guess you would have to wait for the engine to cool down before putting it on the rubber tubes...
Me: You should think before you speak.
Daughter: That always backfires on me.
F800GS review.
Thinc2 is offline   Reply With Quote
Old 06-24-2012, 11:18 PM   #5
KZDon
KZDon's Avatar
Location: N of 49 but actually S of 49 - it's complicated
Oddometer: 51
Well, let's see. Arrive at big honkin' river on bike with hot engine - stop bike - get off bike - remove helmet - talk about the river with riding buddies... 5 minutes of bike cooling complete - inflate big tube raft things ...bike's really cold now...probably okay to go on the raft thing now.
KZDon is offline   Reply With Quote
Old 06-25-2012, 01:42 AM   #6
soul_adventurer OP
grin and bear it
Oddometer: 353
er guys....yes...of course you dont want to burn a hole in the inflatables so a cold bike is preferrable. thought that was obvious to all....
Old 06-25-2012, 07:18 AM   #7
gbmaz
Power Newb
gbmaz's Avatar
Oddometer: 429
Check out Jack's Plastic Welding in Aztec, NM - http://www.jpwinc.com
I am pretty sure they manufacture the Alpacka rafts as well as all sorts of their own products. And they build all sorts of custom stuff for government and industry.
George Marsden
Los Alamos, NM
"You have never really lived until you have done something for someone who can never repay you."
gbmaz is online now   Reply With Quote
Old 06-25-2012, 08:44 AM   #8
the_gr8t_waldo
Oddometer: 2,149
either buy some thing off the shelf or...go to a local inflatable boat service/repair/inspection station and have 'em make something for this use. these sorta places are usually found near comml. fishing ports. they will probably already have a few oddball tubes canablized from other inflatables . if it's a one time use, a cheap inflatable is as easy as it gets. has anyone told you about letting the bike cool down?
the_gr8t_waldo is offline   Reply With Quote
Old 06-25-2012, 01:43 PM   #9
surferbum
surferbum's Avatar
Oddometer: 398
See this website for good info.
Check out this ride report for them in use. The RR starts here.
2014 KTM690 Enduro R; 2010 R1200GS & 2007 Versys sold
BT2012 ICT 2012 nOObs DV
BT2011.2 - This time only 1 NF ... BT2011 - Big Trip 2011 15 Days of Ridin' ...
BT2010 - Big Trip 2010 13 days and ...
My Spot WhereAmIriding
surferbum is offline   Reply With Quote
Old 06-25-2012, 06:00 PM   #10
AceRider01
Fully Loaded
AceRider01's Avatar
Oddometer: 643
you can always just lie the bike on both side 1 minute each on the banks of the river to facilitate a fast cool down!
AceRider01 is offline   Reply With Quote
Old 06-25-2012, 06:36 PM   #11
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,329
how do you get yourself across the river if it too deep to push a bike across?
2 SPOT is online now   Reply With Quote
Old 06-25-2012, 07:45 PM   #12
soul_adventurer OP
grin and bear it
Oddometer: 353
um yes i have thought about letting the bike cool down first. common sense fact #1.
and if its deep deep water then i would swim with my bike to get to the other side. common sense fact#2.
thanks for the info people. much appreciated.
bernadette
Old 06-25-2012, 08:16 PM   #13
fatboy
Oddometer: 312
Truck tire tubes. Simple and available. Make sure you practice. Use a throw bag to get line across. Make sure it will swing bike to a spot on opposite shore where you can get it back on dry land. Looks easy enough.
fatboy is offline   Reply With Quote
Old 06-26-2012, 01:51 AM   #14
soul_adventurer OP
grin and bear it
Oddometer: 353
surferbum, thanks for the link to the ride report and the guys that make the pontoons.
the ride reoport is something else. those guys did the best ever ride i reckon!
Old 06-26-2012, 06:11 PM   #15
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,329
huh, guess i dont have any common sense cause if i HAD to i would swim across with a rope in my mouth then pull the floating bike across the river.
and even less common sense would put two or more guys on a ride that would lead you into a situation like that, and at that point one guy could swim across with the rope, then the two or more of you would trolly the floating bikes across one at a time with better control and dumb stuff like that.
if i had more common sense i woulda thought of trying to one hand swim a floating bike accross a moving river and not asked such a silly question.
thanks for clearing it up for me
2 SPOT screwed with this post 06-26-2012 at 06:22 PM
Times are GMT -7.   It's 05:26 AM.
