Old 12-26-2012, 10:21 PM   #16
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Originally Posted by dnrobertson View Post
Try this manual here to see if it's listed:
http://www.ktm-parts.com/pdf/TechBul...Connectors.pdf
Couldn't find the exact connector KTM uses on the LC8's but that is a GREAT source of information. Thanks a lot for that David. I'd like to share this link on Orange Crush as well and i hope you don't mind me doing so.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 01-01-2013, 03:09 PM   #17
Jhammer OP
Jhammer's Avatar
Oddometer: 277
Shindengen kit link
Here is the link to the Shindengen conversion kit:
http://motoelectrixcom.myshopify.com...-f700gs-f800gs
Originally Posted by Jhammer View Post
Jhammer is offline   Reply With Quote
Old 02-04-2013, 01:33 PM   #18
fernan_ci
fernan_ci's Avatar
Oddometer: 201
I sent you a private message, could you check it? thanks.
fernan_ci is offline   Reply With Quote
Old 05-22-2013, 06:33 AM   #19
gravityisnotmyfriend
gravityisnotmyfriend's Avatar
Oddometer: 1,427
Hello, I sell a universal SHINDENGEN MOSFET FH020AA REGULATOR/RECTIFIER KITS.
Works with all 12-volt systems with a 2 or 3 wire stator can handle up to 50amp max 30amp continuous.
The kits I sell are currently all universal. In the future I may make up some bike specific kits if needed. We have had very good luck with the universal kit. It comes with complete instructions. I'm here to answer any questions you have here on the ADV forum,there is also more info on my website.
Kits sell for $121.00 on my website here is a link http://motoelectrixcom.myshopify.com/
Can you tell me if this system will work on a '94 KTM 620 EXC? It's odd that it's a 3 phase generator, but part of the 3 phase stays AC and runs the ignition, and some of the 3 phase gets rectified to DC.
I've already bought a universal R/R for single phase AC and it didnt' work.
Any help would be great! I'll send you a PM as well - I really need to get this bike back on the road.
Thanks,
Gravity
ETA:
What's the difference between this:
http://motoelectrixcom.myshopify.com...r-w-connectors
and this:
http://motoelectrixcom.myshopify.com...-rectifier-kit
Is the only difference in the more expensive one the extra wires, connectors and fuse block? Is the R/R itself the same?
gravityisnotmyfriend screwed with this post 05-22-2013 at 06:53 AM
gravityisnotmyfriend is offline   Reply With Quote
Old 05-23-2013, 06:28 AM   #20
ebrabaek
Oddometer: 4,726
Thanks,
Gravity
ETA:
and this:
Could you post a picture of the R/R on your 640.... The R/R are really generic, and as long as you dont go down in capacity. Ie... your old one was capable of 40 amps, the new one....only 30 amps, then you should be able to cross brand them. I am not aware of any AC that does not get rectified to DC....
Erling
ebrabaek is online now   Reply With Quote
Old 05-23-2013, 09:59 AM   #21
Oddometer: 1,427
Well, here's what it's supposed to look like:
But, that's not what was on my bike when I got it. Judging by the part number, it came off a honda NS125 or a 300 atv.
I can scan in the electrical schematic if you'd like, but I assure you that half the generated current remains AC and goes directly to the ignition coil. This bike is weird that it needs no battery and non of the other electrical to run. Three of the wires go directly from the generator to the coil, and 3 go to the RR. It's odd and proving to be a PITA!
Not sure if it makes a difference, but mine is a 620, not a 640. I know there are a lot of similarities between the two, but I'm pretty sure the 640 needs some juice from the battery to run. My 620 will happily start with the battery disconnected.
Old 05-23-2013, 04:19 PM   #22
Jhammer OP
Jhammer's Avatar
Oddometer: 277
Thanks,
Gravity
ETA:
and this:
Thanks for asking, my r/r kit will not work on your model we have tried this on some similar snow mobiles with your type of system with no luck it is a very proprietary system.
Jason
Old 05-23-2013, 09:04 PM   #23
Oddometer: 1,427
Thanks for the reply. I think I have found a solution, to my particular electrical woes. Or so I hope!
Old 05-24-2013, 06:23 AM   #24
ebrabaek
Oddometer: 4,726
Wow.... your right.... Strange setup. Hopefully you will get it sorted.
Erling
Old 05-28-2013, 03:35 PM   #25
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Does this fit the F650GS single as well or just the twin?
Ride more, bark less
Gangplank is offline   Reply With Quote
Times are GMT -7.   It's 08:24 PM.
