Old 02-11-2013, 12:19 PM   #76
lennie
Oddometer: 181
Def,
Perfect observation.
Or another view is
sprockets = move the performance where you use it
Lennie
Life is always good
lennie@boxer-performance.com
www.boxer-performance.com
lennie is offline   Reply With Quote
Old 02-12-2013, 07:12 AM   #77
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,685
Originally Posted by lennie View Post
Dan,
How are the intalls going for the 3 bikes?
I mounted them on the r1200rt and on the 1150 rockster.
Here's an important information for those who are going to install the sprockets: in case you have a torx screw, it's a good ideea to give it a few hammer taps before un-doing the screw. It helps A LOT the process of taking the bolt out.
Dan.
Dan Căta is offline   Reply With Quote
Old 02-12-2013, 08:50 PM   #78
DDT Rider
Oddometer: 473
Has anyone done before/after dyno on this install?
DDT Rider is offline   Reply With Quote
Old 02-12-2013, 10:22 PM   #79
crash a-ron
mmm...burnt steel
Oddometer: 328
Also, has anyone installed these in an HP2 enduro?
Aaron "It is all fun and games until Shoulder Surgery."
Seattle, Washington
crash a-ron is offline   Reply With Quote
Old 02-13-2013, 06:29 AM   #80
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,685
No, as far as I know. Perhaps Lennie can provide one.
The certain thing is that the bike feels a lot better with them installed.
Dan.
Old 02-13-2013, 02:09 PM   #81
lennie
Oddometer: 181
DDT,
I have done before and after runs but would need some time to locate the graphs as it has been over 12 years since I developed these. All but 2 or 3 have been very happy of the rides after installation.
Ron,
Yes I have had customers from the Pelican board install the sprockets in the HP2 enduro.
Lennie
Life is always good
Old 02-13-2013, 03:07 PM   #82
DDT Rider
Oddometer: 473
DDT,
Ron,
Thanks, Lennie!
Old 02-16-2013, 08:04 PM   #83
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,370
DDT,
Ron,
Lennie,
I'm still thinking about installing these. I'd like to see the graphs too if you can find them.
I tend to be a skeptic so please bear with me. I read your comment about these being developed in 2000 or there abouts. I know that advancing a cam, in particular closing the intake valve earlier can add low end torque. A few questions:
-Nine degrees advance seems like a lot, did you measure the lobe-centerline-angle for the intake? Where does it start out before adding your sprockets, how many degrees ATDC?
-Any chance you measured the overlap and duration for intakes and exhausts? Can you tell us those numbers too?
-At the end of this message I listed the 6 different cams for 1100,1150 and 1200 motorcycles that you've told us your sprockets work for. Since these six cams are different, I'm guessing that they have different LCAs, durations and overlaps. Why is a 9 degree advance the right number for all of them?
-which cam part number did you do the development work on? Would it be the 340 963 cam for the R1100S?
Thanks,
RB
1150 cams
PN 340 963 for rs, rt, 1100s
342 961 for rr, r, GS, GSA
1100 cams
PN 340 963 for rt, rs
341 560 for r, GS
1200 cams
PN 670 068 for rt, st, r, GS, gsa
704 528 for s
668 723 for GS, GSA earlier years
roger 04 rt is online now   Reply With Quote
Old 02-17-2013, 06:29 AM   #84
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,820
Originally Posted by roger 04 rt View Post
Lennie,
Thanks,
RB
1150 cams
1100 cams
341 560 for r, GS
1200 cams
704 528 for s
Remember, these sprockets do NOT change valve lift, duration, cam angle rates or other aspects of the cam profile....they only move the valve timing relative to the crankshaft angle.
Years ago, Isky and others sold offset keys installed on the camshaft drive gear to hot rodders that performed the same function. The results was moving the engines performance up or down the RPM range.
Some of us Brit bike tuners used to fit the gear on the factory camshafts at different locations in an attempt to extract more HP. Also, a different (flatter) radius on the cam follower (tappet) would change valve duration somewhat providing several extra HP. If you want a substantial HP increase, a new cam profile with more lift and increased duration will do the job (much better than an aftermarket exhaust and likely cheaper, as well).
Moving the valve timing relative to crankshaft angle with Lennie's sprockets will change the personality of the boxer positively without major work.
def is offline   Reply With Quote
Old 02-17-2013, 08:31 AM   #85
roger 04 rt
Oddometer: 2,370
Out of curiosity how much did those Isky keys move the advance. I've seen numbers in the 4-6 degree range for street machines.
Understood that all the openings and closings shift, and also understand that GENERALLY you get more low end torque with earlier closing of the intake valve. (As you advance the intake opening, exhaust closing and exhaust opening some other things happen too.) That said, with six different cams, all likely to have different lobe centerlines, overlap and duration, I'm surprised that one size (a large 9 degree shift) fits 1100, 1150 and 1200. So I'm hoping that in the good work Mark did to design these sprockets he took some data that he can share with us.
Old 02-17-2013, 08:37 AM   #86
roger 04 rt
Oddometer: 2,370
From an article on cam advancing (and I'm not saying nor do I have any opinion on whether 9 degrees is the right or wrong number for the boxers):
When the cam is advanced, the intake valve will open earlier during the exhaust stroke and the exhaust valve will shut earlier during the intake stroke. If the cam is advanced too far, reversion will occur and the exhaust gasses will not be adequately scavenged. Four degrees advance is usually the most that you can safely advance a cam beyond the manufacture’s recommended LC. When the cam is retarded, cylinder pressure will be reduced but the scavenging process is increased. If you are experiencing pre-detonation, retarding the cam will help. It also has a tendency to move peak hp to a higher rpm. Again, care should be taken when changing cam timing. Another consideration when playing with cam timing is piston to valve clearance. When you change the valve events (timing), the clearances will change and should be checked.
Old 02-17-2013, 10:12 AM   #87
def
def's Avatar
Oddometer: 10,820
Roger, you're correct, 5 degrees was typical. Also, I recall the performance cam manufacturers indicated that factory camshafts were rather crude in tolerance regarding drive gear keyways cut off specification and cam drives quickly loosened and provided poor valve timing as more miles wore cam drive chains. Aftermarket cam gear drive products were offered that reduced cam drive slop. I recall watching many an ignition timing mark dance around with the timing light due to worn camshaft drive chains.
Old 02-17-2013, 10:28 AM   #88
def
def's Avatar
Oddometer: 10,820
Since we're in the realm of engine breathing, BMEP, VE and other engine dynamics, the OE cam profiles we find in our boxers are designed not only to provide good performance but also to satisfy the EGR needs for emissions control. Also, the starter drive and starter motor size is determined to some extent by valve timing. Even the dimples in the intake runners (think golf ball) have an influence on engine breathing, mixture homogeneity and thus engine performance. We install free flowing air filters in hopes of more power. Some boxers owners even remove the FI system and install carburetors in an effort to change engine personality and performance.
My thoughts are that roger04rt has provided proof that his fueling adjustments improve the boxer's drivability considerably. Also, Lennie's sprockets move the HP curve into the range where most of us operate our boxer engines with an improvement in fuel mileage....what more could we ask for?
Oh, I forgot....more noise.
Old 02-17-2013, 08:39 PM   #89
lennie
Oddometer: 181
Roger,
I originally developed the sprockets for my 1998 R1100S and we used specially made vernier sprockets with 3 degree retarded, 0 degrees stock, 3,6,9 and 12 degrees advanced.
We started with the baseline for stock and adanced to 3 degrees and tested with improvements. We then tried 6 degrees with further improvements and again at 9 degrees. While the results on the dyno were there they were not as impressive as we expected and it was not until I rode the bike home that the change was quite beneficial.
As far as other models I researched the cam timing and decided to test the sprockets in each to find the same positive result. When the R1200xx engine was developed I had to drill the extra hole for the cam position sensor and they were tested in the USA with the same positive feedback.
To ease the manufacture and number of products I have I decided to just use the 9 degree advance as the product I sell.
I have had a look for the graphs and cannot locate them but try this link to Brad Black's site. http://www.bikeboy.org/ and this is a driect link to the performance data http://www.bikeboy.org/performance.html
There are plenty of graphs for the BMWs with just cam sprockets or in combination of other parts for you to look at.
Lennie
Life is always good
Old 02-18-2013, 08:03 PM   #90
roger 04 rt
Oddometer: 2,370
Lennie,
Thanks for the description of the process that you used. It seems thorough and a reasonable way to go about it.
I had a look at all the graphs on Brad's site and saw his comments as well. It looks like some of the graphs are with 6 degree sprockets and others with 9 degrees. All the runs that mention your sprockets are in motorcycles that use the 340 963 cams--the same one I have in my 1150. I wish the dyno runs were more conclusive.
Since you've settled on the 9 degree sprockets, it seems that you believe it's the best fit.
Just one more question, were you surprised that it took 9 degrees to get the results you were looking for?
RB
Times are GMT -7.   It's 07:26 AM.
