Thread Tools Rating: Thread Rating: 33 votes, 5.00 average. Display Modes
Old 02-04-2013, 06:41 AM   #301
NoLurkerAnymore
NoLurkerAnymore's Avatar
Oddometer: 10
And it still gets better and nicer...
“A journey is like marriage. The certain way to be wrong is to think you control it.” – John Steinbeck
NoLurkerAnymore is offline   Reply With Quote
Old 02-04-2013, 06:58 AM   #302
ducnut
Oddometer: 3,297
That's the nicest, closest fitting, and most appropriate looking aftermarket bumper I've seen put on anything.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-04-2013, 10:55 AM   #303
PaulGinAZ
FNG
PaulGinAZ's Avatar
Oddometer: 259
Very nice work! I am a big fan of the Rocky Mountain Westy bumper setup.
-Paul
- All bikes gone... thanks for the memories!
-2013 Yotota Tacoma TuRD (daily)
-1989 VW Syncro Tristar TDi (long-term project)
-Too many bikes and cars in my sordid past to list...
PaulGinAZ is offline   Reply With Quote
Old 02-05-2013, 09:24 AM   #304
RocketJohn
Hook em' Horns!
RocketJohn's Avatar
Oddometer: 11,330
Fantastic build! Thank you for sharing... Can't wait to see some video of this machine off the pavement!
RocketJohn is offline   Reply With Quote
Old 02-16-2013, 06:53 PM   #305
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,090
Thanks for the comments....can't wait to see this baby finished myself
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 02-16-2013, 06:55 PM   #306
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,090
Pressed the lower ball joints in this am. I removed the boots to press the joints and noticed there was very little grease in the joint from the factory.
Here's a picture of the factory grease. The other ball joint had more grease that this one...but still not a lot. They are both Meyle joints, one had while lithium grease and one had a red grease in it.
I carefully cleaned all the factory grease out of the joints and re-greased them with Redline CV2 grease, working it down into the joint. They should last a LOT longer properly greased.
Inner seal pressed in to place. I had this part powder coated at a local company to save time. They did a good job other than coating a couple areas they shouldn't have and leaving a couple spots bare.
A coat of POR15 applied to the bare area around the inner seal.
Steering rack bushings removed.
The new PowerFlex Urethane steering rack bushing next the OEM rubber bushing that was removed.
After pulling the rubber boots off the steering rack you need to pry up the lock tab to separate the Tie Rod Assy from the steering rack.
My father giving me a hand cleaning up the steering rack :-) It is now a lot cleaner, although it has some undercoating on it that doesn't want to come off :-)
After seeing the factory grease in the lower ball joints I decided to check the new tie rod ends as well. They had more grease than the lower joints did although I fully cleaned them out and packed them with the same Redline CV2 grease as well.
The new steering rack rubber boots didn't come with clamps, a quick trip to NAPA turned up the correct OEM style Oetiker clamps :-)
New boot clamped in place.
Nice thick coat of BelRay grease installed on the steering rack bushings...ready to install.
Steering rack ready to re-install.
Using a Dremel tool and wire wheel to remove the powder coating from the tapered ball joint holes that the powder coating facility didn't cover.
Hodakaguy
Old 02-17-2013, 02:34 AM   #307
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,464
I saw a white westfalia in Tillamook this weekend, with the same headlight conversion, custom bumpers and washington plates, thought it might be you...guess not.
Old 02-17-2013, 04:57 AM   #308
klp
Oddometer: 244
Originally Posted by Hodakaguy View Post
I don't think I am in a minority here - when I see stuff like this it just makes me feel all warm and fuzzy...
Great build and thread, I have really enjoyed watching this come together.
Lots of old Hondas, 2 Yamahas, 2 Kawi's.
klp is offline   Reply With Quote
Old 02-17-2013, 08:08 AM   #309
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,774
Hoodka, are you using stock EFI for the Subaru?
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 02-17-2013, 04:55 PM   #310
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,090
Yep...using the stock Subaru ECU/EFI. I had a friend running a LINK ECU on his H6, it never was set perfectly and as a result never ran quite right. I figured the factory spend a lot of time on the ECU mapping so I'd just use theirs .
Hodakaguy
Old 02-17-2013, 04:55 PM   #311
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,090
Installed the Lower Control Arm bushings.
Power steering rack installed, lower control arms installed with Powerflex radius rod bushings.
Burley upper control arm installed.
Here's the factory grease in the upper ball joint....pathetic.
Cleaned out the old grease and packed it with Redline CV2 grease. Ready for service.
Now it's starting to look like something. Drive shaft freshly packed with grease and bolted in place.
Trying the Fox shock on for size. Looks like plenty of clearance....we'll see how it looks when the spring is in place.
More to come......
Hodakaguy
Old 02-17-2013, 06:11 PM   #312
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,374
What wheels are you planning on running on this thing? Just picked up an old audi wagon with the same lug pattern and have been looking to see what's out there. Wanna run something small (15-16"), with big meaty sidewalls.
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 02-18-2013, 06:16 AM   #313
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,090
I'm running these 16" Mercedes wheels.
Here's a thread that has a whole list of wheels that fit the Vanagon: http://www.thesamba.com/vw/forum/viewtopic.php?t=203519
Post pics up of your off road wagon when ya get it done
Hodakaguy
Old 02-18-2013, 07:40 AM   #314
ducnut
Oddometer: 3,297
Those just look "right".
'96 Ducati 900SS
Old 02-18-2013, 07:53 AM   #315
dlearl476
Two-bit Throttle Bum
dlearl476's Avatar
Oddometer: 23,454
Well, HG, I gave up on ever being able to afford your syncro once you get it done about 15 pages ago.
But I may have found a nice Eurovan Winnie out west.
"When the power of love overcomes the love of power, the world will know peace" - Jimi Hendrix
Politics is the gentle art of getting votes from the poor and campaign funds from the rich by promising to protect each from the other. -- Oscar Ameringer
dlearl476 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 01:49 AM.
