Thread Tools Rating: Thread Rating: 68 votes, 5.00 average. Display Modes
Old 02-24-2013, 05:48 PM   #331
jdiaz
Oddometer: 32,314
Wait. You can't adjust the shock damping from the driver's seat?
Don't start taking shortcuts now.
jdiaz is offline   Reply With Quote
Old 02-27-2013, 04:49 AM   #332
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,147
That's going to be one tight suspension.
Laconic is offline   Reply With Quote
Old 03-01-2013, 07:40 PM   #333
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,098
Received the new Lemforder upper ball joints today.
After reading about Lemforder ball joints having more range of movement than the Febi units I had purchased I decided to give them a try.
Here's a picture of the Lemforder joint on the left and the Febi unit on the right.
Now lets test the range of motion. The Lemforder unit is in the rear and the Febi joint is in the front. I'm holding the Febi joint all the way up since the boot is wanting to make it spring back down a bit. Looks like a good 10+ percent increase in range of motion over the Febi joint.
Now lets see how the factory grease looks!
As a review this is the factory grease in the Febi Joint, almost dry! There is no excuse for this from a factory new part, if you are using the Meyle or Febi brand joints make sure you re-pack them with grease before installing!
And the factory grease in the Lemforder Joint, 100% better! It's fully packed with extra grease packed inside the boot. The grease felt good and it was packed well so I just sealed it back up. :-)
Installed.
If your going to replace the upper ball joints I would recommend picking up the Lemforder units.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 03-01-2013, 10:27 PM   #334
maloryII
more north, more wet
maloryII's Avatar
Oddometer: 3,687
kinda meh on the Syncro and I think for the money involved a Defender 130 would be a way cooler solution
BUT
BUT
goddamn if this isn't a lesson in doing it fuckin' right. love this thread
2006 KTM 950 Adventure
"The pen & sword, in accord."
"It's never over in a Rover."
maloryII is offline   Reply With Quote
Old 03-02-2013, 05:13 AM   #335
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Eek
You're obviously askin' a different question if a Defender 130 is the solution to the same thing a Westy Syncro is
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 03-02-2013, 07:59 AM   #336
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,539
Old 03-02-2013, 09:13 AM   #337
JNRobert
Breaking Wind
JNRobert's Avatar
Oddometer: 9,971
Originally Posted by Hodakaguy View Post
Total suspension porn
Love this thread
Crusader of Slack
JNRobert is offline   Reply With Quote
Old 03-02-2013, 09:53 AM   #338
Slimie
Oddometer: 1,080
Hodakaguy
I'm not sure you should be covering all that lovely work up!
Beautiful, inspirational work. Thanks for taking the time to show us all.
-Simon
Slimie is offline   Reply With Quote
Old 03-02-2013, 10:42 AM   #339
koncha
Oddometer: 10,044
This thread is an inspiration for the abolition of half-assedness.
koncha is offline   Reply With Quote
Old 03-02-2013, 04:26 PM   #340
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,098
Thanks guys! It's been a lot of fun so far, ready to drive it now
Some more progress today. Not a lot of pictures...but progress.
Ready to install the new T3 Techniques end link urethane bushings.
And Installed. NOTE: If you are installing new end link bushings it's a lot easier to have the anti-sway bar unbolted from the bus during install. Install the end link bushings and tighten them up, then install the four bolts holding the anti-sway bar to the body. I ended up removing the four bolts then re-installing them since I had previously mounted the anti-sway bar.
Installed the passenger side shock, spring, mounted the shock reservoir (they are provided with rubber spacers that fit into the channels), and torqued all the ball joints, bolts etc.
More to come soon!
Hodakaguy
Old 03-02-2013, 07:27 PM   #341
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Wicked
Lookin sweet! Good job !!
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-02-2013, 07:28 PM   #342
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Sexy craftman jacks!
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 03-03-2013, 03:10 PM   #343
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,098
Those jacks have held up great and are super handy!
Hodakaguy
Old 03-03-2013, 03:14 PM   #344
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,098
Time to start getting the brakes installed.
I'll be installing a set of Front CV Protectors but thought I would mock up the brakes to make sure everything fits.
I wanted to upgrade the front brakes on the bus since it's a heavy vehicle and the OEM brakes are marginal at best. I went with the VanCafe Big Brake kit which is a Audi based kit, You can save some money by piecing it together yourself but in the interest of time I just ordered the kit.
Some Stainless Steel hoses to replace the worn out OEM rubber units, should provide a more solid pedal feel.
New stainless steel dust shields.
Kit came with 285mm vented rotors to replace the OEM 250mm solid units.
50% greater pad contact surface than the OEM pads.
Installed for mock up.
Everything fit up perfectly with proper clearances etc. The one thing I don't like about the kit is there is no tab to hold the hose/metal tubing to the caliper. Instead they provide you with a snap tie to keep the hose from flopping around......Hmmmm
Well the snap tie just isn't going to cut it. The Audi calipers have a pre-tapped hold to accept a bracket but the VW bracket is the wrong angle. I did try swapping the VW brackets left to right and they do fit on the Audi calipers that way, but the brackets are to short and they stretch the brake hose at full extension.
Stock bracket at red arrow below.
I'll fabricate new brackets before going any further.
More updates soon.
Hodakaguy
Old 03-03-2013, 05:37 PM   #345
RickS
RickS's Avatar
Oddometer: 611
Wow, nice build. I have never heard of a 4x4 bus. Learned something new today. Actually I do not thinking had ever seen one, but I will pay attention and look at one in person. Makes me want to work on the 57 Chevy
RickS is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 10:58 PM.
