06-25-2012, 03:39 PM
#1 |
Oddometer: 25
BMW Final Drive Oil
I was over at Sierra BMW the other day inquiring about final drive oil. The guys in the shop told me that they just got a lower cost oil for the final drive. It is a BMW labeled oil. The cost 22.90 for a liter bottle. The label reads:
BMW Group Final Drive Gear Oil C-SAF-XO SAE 75W-90 P/N 07 51 2 293 972 On the back it says API GL-5 Made in USA |
06-25-2012, 03:57 PM
#2 |
"Cool" Aid!
Oddometer: 41,507
![]() Jim
06-25-2012, 04:03 PM
#3 |
Oddometer: 310
I still like my royal purple 75w-90 gear oil. for half that price. plus the color helps if i start getting leaks.
Follow me on Facebook--- http://www.facebook.com/2wheeladventures My Blog---- http://www.mygsadventures.blogspot.com 100 things all GS owners should read---http://advrider.com/forums/showthread.php?t=836736 Repair and Maintenance DVD's--- http://www.jimvonbaden.com/ |
06-25-2012, 04:36 PM
#4 |
I have little to say
Super Tech 75w-140 GL-5, ~$8.00/quart. Ad some moly and you've got a good, low cost GL-5.
06-25-2012, 04:44 PM
#5 |
TheBooneMan
Oddometer: 177
I am about to do mine, first time...new '12 gsa
75w-90 or 75w-140? I was thinking about getting the Royal Purple too? would this work for the transmission? http://www.amazon.com/Royal-Purple-0...xgy_01_02_t_lh |
06-25-2012, 05:12 PM
#6 |
Oddometer: 137
I just did my FD oil back in april with Royal Purple 85W 140.
Seems to be fine so far! Should do really well if you do long rides, and ride in alot of hot weather. |
06-25-2012, 05:55 PM
#7 | |
Oddometer: 310
I got royal purple in the trans too. I think i got the same can't remember have to look at the bottle but i believe i have 75w-140 in the trans and 75w-90 in FD. works well.
06-25-2012, 07:38 PM
#8 |
06-25-2012, 07:44 PM
#9 |
Oddometer: 721
WOW, an oil thread
...I'm curious as well......I need to replace the spring air in the Anakee's and replace it with summer air.....whatcha ya'll think?
About women, I say... "Never trust anything that bleeds for a week and doesn't die." 07GSA....Holy Cow! 06 K1200R "Der Naked"....SOLD...too damn fast ![]() 05 R1200GS "Das Boot" ....SOLD...already miss her! 01 K1200RSFL "Das Pig" |
06-25-2012, 07:56 PM
#10 | |
Oddometer: 310
I'd stay away from city air who knows whats in it. ![]() ![]()
06-26-2012, 06:03 AM
#11 | |
06-26-2012, 10:37 AM
#12 |
Oddometer: 331
Another local guy uses Red Line for his final and tranny; a 75-90 quart goes for $13 and change on line. He also changes the oil every 6K in the final. I've got my 6K coming up so I'm trying to learn from a broad spectrum here too. All of my other bikes had wet clutches so I'm learning here...
An interesting comment he made was that he uses the same weight in the tranny and if I remembered correctly he suggested not to use moly in the tranny. I know everyone hates oil threads, but the question that I have is where you would put moly in - and leave the moly out? I'm thinking of engine, tranny, and final drive. I had thought the 600 mile service drained all of the moly out of the final drive and replaced it with a non moly lubricant. True or not? Thanks Rick |
06-26-2012, 10:50 AM
#13 | |
Also, modern motor oils have used moly as an EP additive for a decade or longer. Molydenum dislufide is an EP friction reducing additive that tolerates heat, shear, pressure and other forces typical in gear, chain and bearing systems. Also, it is used as chain lube by the motorcross folks. Finally, Honda Molypaste 60 is the preferred grease used on our driveline splines. Now, are you going to deliberately eliminate it from your gear lubricants? I don't because it can help reduce friction and heat. |
06-26-2012, 11:02 AM
#14 |
Blargh!
I was doing some of my 6000 miles service, and I decided to change the final drive along with the engine oil.
I found a 60cc syringe and I used 3 squirts of Royal Purple 75w90. I use the same stuff in the transfer case, front and rear diffs of my Toyota. ![]() I thought the final drive change would drop my service charge by a lot, lol. Dropped it a whole 17$.... I still don't have a GS911 to reset the light, and they said they were going to check the valves, I'm still too lazy to do that... ![]() 138$ for... nothing? lol
ALL ADDERS ARE PUFFS! 2012 BMW R1200 GSA, 2009 Kawasaki Versys (sold), 2001 Yamaha XT225 (sold) PC Gamer? Support Star Citizen! Save PC Gaming and bring back Space Sims! Pledge today! Service guarantees citizenship. @ http://www.robertsspaceindustries.com Thanks. |
06-26-2012, 11:21 AM
#15 | |
Oddometer: 331
I didn't know if there was a time and reason -not- to use it; other than wet clutches etc. That was the main reason for the question... and the misunderstanding of the first final drive oil change... Thanks |
