Old 06-26-2012, 01:49 PM   #1
Vulfy OP
Vulfy's Avatar
Oddometer: 571
School me on Supermoto please.
So I'm trying to figure out, what makes a supermoto, "supermoto"?
Is it just any old dirt bike that has road tires (not knobbies) and is street legal?
Than what is the difference between supermoto and dual-sport?
I'm looking to purchase an older bike, somewhere in 250 - 400 cc range, that is light, and can be dropped on the pavement without too much worrying about internal as well as external damage. Needs to be pretty low, no high stools that I'm seeing on some of the dirt bikes. It needs to have road tires, no knobbies of any sort. I need as much grip as I can get, and it will never leave pavement.
This bike will be used for technical riding, so tight turns, sharp bank angles.
Is it possible to convert a bike to be a supermoto?
Is it better / cheaper to buy a supermoto bike that is already supermoto, or just get a dirt bike and convert / street legalize it to be supermoto?
Would I have to change suspension on a dirt bike, to make it softer / harder for street / technical use?
How durable are these bikes? If I'm putting her down on pavement from time to time, do I need any additional protection such as sliders, or are they designed to be well protected by default?
Vulfy is offline   Reply With Quote
Old 06-26-2012, 01:56 PM   #2
Grainbelt
marginal adventurer
Grainbelt's Avatar
Oddometer: 27,069
First and foremost, Supermoto is a form of racing. Street-legal supermoto bikes are either converted dirt bikes, or more recently factory offerings.
The most prevalent is probably the Suzuki DRZ400SM, there is also the Kawasaki KLX250SF, and the Yamaha WR250X. A few euro brands have street legal supermotos, I think.
The factory bikes come with 17" wheels, sticky rubber, different suspension setup, gearing, and brakes.
WR250R dual sport:
WR250X supermoto:
Grainbelt is online now   Reply With Quote
Old 06-26-2012, 02:31 PM   #3
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,513
I wont go into the history of Supermoto, it started here, was exported to France, where it got big, and found it's way back.
But I'll try to answer some of your questions. I have a Supermoto, one of the best factory "street" supermoto's IMO, an '04 625SMC.
Typically supermoto now is known as a dirt bike or dual sport with 17 inch rims. Usually your standard 3.5 front and anything up to about a 5 in the rear (smaller is better, IMO). Historically a Supermoto was a cross between a road racing single, a dirt track bike, and a moto-crosser. They could have just about any rim/tire combination and were probably closest to dirt trackers. A dirtbike with street tires on dirt rims is known as a "sportsman" set-up, and is better then most people give them credit for.
The biggest difference is based on the donor bike. Enduro or DS vs Motocrosser. Enduro/DS bikes are generally better at being street supermoto's, MX'ers are better race bikes.
What's your definition of "older"? How much did you want to spend?
Sounds like you're looking for a gymkhana-type bike. Supermoto would be great for that. You're best bet is probably something that's already built, either factory or swapped. Converting a dirt bike is expensive, and you can get the same thing already built for less then what you'd spend building it, a second set of rims alone would be a grand, maybe more, and that does nothing to the suspension or brakes. In the range you're looking at the prime factory contender is probably the WR250X. It's small, relatively light, six speeds, FI, low maintenance. Another from the factory option would be the DRZ, it's a little bigger, similar weight, and there's a big aftermarket for them, they've also been built for a while. If you want to go slightly older an "E" model that's swapped would be a good contender too. Lighter than the S or SM, better carb, exhaust, cams, and higher compression. XR400 wouldn't be bad either, but that might be hard to find swapped. The disadvantage of factory supermoto's is they're going to be heavier then a purpose built bike that's been swapped. And Japanese factories just started building them a few years ago, so "older" is tough. The advantage to factory built bikes is they're a little better on-road. The DR650 and XR650L are very popular converts, they make great road bikes and commuters, and still handle off-road pretty well, but that's bigger then what you're talking about.
For a dirt bike that's been built, your best bet might be a CRF250X that's been swapped (depending on how hard it is to get tags where you are). It'll be lighter, and faster, but less suited to around town/commuting. If you want to go older then that the WR yamaha's are good too. IMO the CRF X and WR make better SM's than the CRF and YZF models because of the wider gear ratios and other enduro mods. If you're looking for a 250 for kart-track days and gymkhana, one of those might be the best bet.
If you get more specific with what year range you're looking at, what specifically the usage is going to be, and how much you want to spend, I could narrow it down even more. Oh, and here's a gratuitous SM shot:
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 06-26-2012, 06:14 PM   #4
kpt4321
kpt4321's Avatar
Oddometer: 1,674
A supermoto does not need to be road legal; I'd argue that a majority of them are not. At the last supermoto open track day I went to, probably 75% of the bikes were not road legal, but rather race bikes (conversions and factory).
Dual sport implies ability to go off-road as well. There is no strict definition, but I would expect a dual sport to have a 21 inch front wheel.
In my opinion, to be a supermoto a bike has to have a 17 inch front and rear wheel, rim width to accept proper sticky road rubber, AND appropriate suspension and brakes to make the tires work. There are no strict definitions for this stuff, but I would propose that a KLR on stock suspension with 17 inch wheels and tires isn't really a supermoto (as the suspension, let alone the motor and chassis, are not really up to the task). You can't put a 190 profile rear tire on a Ninja 250 and call it a superbike.
TAT 2008 / Colorado 2010
"Both the man of science and the man of action live always at the edge of mystery, surrounded by it." -Oppenheimer
2007 Monster S2R / 2006 TE610 / 1999 KDX 200 / 2000 DRZ-E
kpt4321 is offline   Reply With Quote
Old 06-26-2012, 07:55 PM   #5
DAKEZ
DAKEZ's Avatar
Oddometer: 19,740
All you really need to know is it is the most fun you can have on two wheels without going out of town.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 06-26-2012, 08:49 PM   #6
ViperJustin
Retired HH60G Gunner
ViperJustin's Avatar
Oddometer: 671
Agreed!!! I owned the factory built BMW XMoto (650 sigle) and now own the HP2 MegaMoto (really big supermoto-like bike). To me, a true supermoto is one that's converted from a 250-650 dirt bike. That's just my opinion though.
Motostrano.com sells packages to convert motocross bikes to supermotos.
ViperJustin is online now   Reply With Quote
Old 06-26-2012, 08:53 PM   #7
ViperJustin
Oddometer: 671
Also....
The best part about owning a sumo is out cornering guys on bikes that have two to three times the power you have. The looks on their faces are priceless. Then, to really put on a show, slide the back end out around corners!
Old 06-26-2012, 09:04 PM   #8
Harvey Krumpet
Oddometer: 908
Busted Vulfy!!!!
I'm no expert but something like a DRZ 400 would be ideal, there is a lot of information on converting bikes like XR's, WR 250 / 400's etc. Mainly finding 17" wheels that fit or may need some spacers machined to suit. A pucker Super moto is a bit of a beast, the trail bikes are still light but more manageable & with softer suspension, lower. If you want to go really light 2 T's are fun & easy to maintain. KTM do 17" conversion kits for some of their bikes, lovely rims & a bloody great big front disc. I nearly bought an EXC 300 with the super moto kit chucked in. Self preservation prevented me.
They are all fairly tough, most I see down here have crash knobs for protection, not a lot more. The plastics are tough too, they bend rather than snap. Simple things like having spare clutch & front brake levers keep the bike rolling after an off.
They are huge fun too, you can get away with murder on grippy, light bikes. I do.
Bearing in mind the purpose of the bike, sport touring tires would be a good choice, they heat up quicker than sport or racing tires & have truck loads of grip from the off. A lighter bike will not justify super sticky tires unless you intend going racing.
Harvey Krumpet screwed with this post 06-26-2012 at 09:09 PM
Harvey Krumpet is offline   Reply With Quote
Old 06-26-2012, 09:46 PM   #9
J. Thompson #5150
300-pound Gorilla
J. Thompson #5150's Avatar
Oddometer: 213
Ya could always go nuts with something like this
Marriage 101: The ball is your home, the shackle is love, and the chain is made up of little circular guilt trips.
J. Thompson #5150 is offline   Reply With Quote
Old 06-27-2012, 10:46 AM   #10
GPrairie_Rider
Dirt Junkie
Oddometer: 931
Im looking at the new Husky SMR511. Just seems like the Europeans have the Motard linup down. I dont want a damn Yamaha 250. When they bring out a SM with the new WR450 engine in it i will come back to Yamaha. Until then im seriously looking at Huskys.
Chris
Current Bike: 2013 Triumph Tiger 800XC
I deserve the best, anything less is unacceptable.
GPrairie_Rider is offline   Reply With Quote
Old 06-27-2012, 08:03 PM   #11
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,660
That is fing sweet, looks like a HD engine with the rear cylinder removed?
Where do I find more about this bike? Would love to see a build thread!
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 06-27-2012, 09:45 PM   #12
Kai Ju
Kai Ju's Avatar
Oddometer: 1,896
Xr650r s/m
Since PhiSig1071 mentioned one, here is a pic of mine.
Absolutely great in the tight technical stuff, cruises at 85 all day, gets 45-48 mpg and makes a great commuter to boot.
If I could only keep one bike, this is it.
Find one already set up and plated and be a happy man, that's how I got mine.
Kai Ju is offline   Reply With Quote
Old 06-27-2012, 09:49 PM   #13
Harvey Krumpet
Oddometer: 908
I would be tempted with that. Do you have a lot of exhaust thefts in your neighborhood?
Old 06-27-2012, 10:00 PM   #14
Kai Ju
Kai Ju's Avatar
Oddometer: 1,896
So I'm reading your comment and wondering how you know that I've had two Catalytic converters stolen off my Nissan Pickup Truck, both in front of my house.
In the infamous words of Gilda Radner: Never Mind.
The disc lock is looped through a band clamp that is bolted to the frame at one of the muffler bolts.
I use it to lock the rear disc since the bike has no steering lock. I also added a key switch to shut the ignition off since the XR doesn't have one stock.
Old 06-28-2012, 12:33 AM   #15
Vulfy OP
Vulfy's Avatar
Oddometer: 571
Excellent info here. Thank you everybody.
Bike will be used for motogymkhana, yes.
I definitely do not want to get a brand new bike, just to slide it the next day at a practice session.
Budget would probably be around 2-2.5 grand, that's total, including any mods that I would have to do, registration and insurance.
I honestly don't know how realistic this budget is for this type of a bike. So it might change.
Harvey, hehe busted indeed.
That XR looks very tempting, but might be too much power for my needs.
WR250 or maybe drz would be more up my alley.
Power needs to be manageable, and for the motogymkhana type of riding, displacement is not critical. In fact, I would rather prefer less power, as top gears are never used, and I just need the low end pull and acceleration.
I'm on my Speed Triple right now. Its a great bike, but its a bit of a pig for this type of riding. The act of picking it up off the ground alone, is a story in itself.
I will continue on my Triumph, but for the next year, already gathering up info on a more dedicated gymkhana bike. This is a great start.
Times are GMT -7.   It's 07:15 AM.
