Old 07-09-2012, 06:08 AM   #31
JGoody OP
Oddometer: 290
Originally Posted by tkent02 View Post
Changing the lever to get more mechanical advantage may help too, or perhaps using a longer lever on the other end down by the clutch. This is a common mod done on other bikes.
How about those really expensive fancy aftermarket levers they sell in the bike shops?
I think I'm going to try the Moose Racing box for $40. It fits between the clutch perch and the cable and apparently has pulleys or gears to give some mechanical advantage -- and I'm assuming it'll be easily reversible. What I'd really like is something more on the theory of the throttle tamer -- easier pull at the start and then maybe easier to hold in at the fully "in" position -- like a compound hunting bow. Not sure if the Moose has that "cam effect" or just reduces pull effort linearly. Pazzo levers may be in my future too.
http://www.mooseracing.com/catalog.j...67&startPage=1
JGoody screwed with this post 07-09-2012 at 06:13 AM
JGoody is offline   Reply With Quote
Old 07-09-2012, 12:06 PM   #32
Lensgrinder
Oddometer: 1,317
To fit the EZ Pull clutch I had to modify the perch to accept the larger diameter on one of the cable housings.
To reverse it you would need a bushing to re adapt to the smaller BMW OEM cable housing to the perch.
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder is offline   Reply With Quote
Times are GMT -7.   It's 07:43 AM.
