Old 08-06-2013, 10:16 AM   #886
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,452
I just reused the stock throttle tube also, wasn't a big deal to me. Cut the grip off and shave the plastic down with a utility knife if you are tool limited. A high speed drill or a die grinder or a bench grinder with a wire wheel makes it go much quicker.
I epoxied heating elements to mine, been on there a few years now.
sagedrifter is offline   Reply With Quote
Old 08-11-2013, 03:09 PM   #887
BluesCruiser
BluesCruiser's Avatar
Oddometer: 83
Are there just 3 fuses on the DR? The 30 amp on the starter relay and the two 10 amp fuses for the headlights? The shop manual shows a fuse between the battery and the ignition switch; is that the 30 amp fuse perched on the starter relay or is there another one buried under the tank someplace?
Thanks...I'm chasing gremlins and feeling like its Miller time!
2009 DL650A "Mendoza"
2000 DR650 "Thumpa"
California East Bay
BluesCruiser is offline   Reply With Quote
Old 08-12-2013, 08:24 AM   #888
KiwiMtnClmbr
Fresh!
Oddometer: 50
Gremlins abound
On gremlins... I had a 'lil one rear it's head during a gas stop on my first group ride yesterday. I'd also appreciate any insight into where to start my search for full power loss that only returned after removing the side panels and seat which must have jarred something back into place.
2007 DR650se
2002 KAWASAKI EX250F - gone
KiwiMtnClmbr is offline   Reply With Quote
Old 08-12-2013, 09:42 AM   #889
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,732
You were with Walter ? He sent me that pic of mike working on it.
How about the side stand safety switch ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 08-12-2013, 11:06 AM   #890
BluesCruiser
Oddometer: 83
That sounds like what is going on with mine! Total power loss, then it comes back on for no obvious reason, now its off again. Wiggled and thumped everything that can be wiggled and thumped. Nada!
Is there a hidden line fuse somewhere other than the 3 I know of? It isn't the side-stand switch, as there is absolutely NO power. No neutral light, no headlights, nothing. The battery is good and those 3 fuses are OK.
2000 DR650 "Thumpa"
California East Bay
Old 08-12-2013, 12:58 PM   #891
sagedrifter
Southern Explorer
Oddometer: 1,452
If there is no power at all and you have a good battery, the ignition switch harness needs a good look see. If the head light and dash lights work still, then the kill switch could need attention. The little red button on the right can get dirty and cause issues. No power at all makes me think the main ignition harness has shorted or the switch failed.
I've heard of some older bikes with burned through wires near the front where the harness bends and moves the most. Some are tighter than they should be. I loosened mine up, its was too tight IMO, but there was enough slack when routed right.
sagedrifter screwed with this post 08-12-2013 at 01:08 PM
Old 08-12-2013, 01:23 PM   #892
BluesCruiser
Oddometer: 83
Found the gremlin!! Under the tank is a green multi-wire connector that was still plugged together but had gotten loose. I guess the little clippy-thingy that is suppose to hold it tight has lost its snap. I tightened it up with a zip-tie.
So simple once you find it!!
2000 DR650 "Thumpa"
California East Bay
Old 08-13-2013, 08:34 PM   #893
KiwiMtnClmbr
Fresh!
Oddometer: 50
So it was me with Walter and gang. Not the side-stand switch or kill-switch as I've already bypassed both of those. It seemed to be somewhere along the ignition circuit, most likely near the connection/fuse underneath the seat on the right leg side. I'm leery of trying to intentionally get it to lose power but if the next go-round with the meter doesn't turn anything up that will be the option.
2007 DR650se
Old 08-13-2013, 09:06 PM   #894
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Sometimes bypassed safety switches can rear their ugly heads ... depending HOW they were bypassed. Double check they are still sound and not going intermittent on you.
If you're at home, I would not hesitate to start wiggling and pulling on wires ... unless you need your DR650 every day for transport. If not, wiggle a way and find that fault.
Will have to be done sooner or later anyway. Proceed slowly and carefully.
Look at the wiring harness up near the steering head, right side. When bars are turned, harness RUBS on frame, can sometimes abrade through protective sheath.
Pull off front cowl. Have a close look at harness routing, look for rubbing or wear spots. Suzuki has done a really good job in general on the wiring routing. Most problems start when well meaning owners get creative with re-routing or doing mods incorrectly.
Good Hunting ... a VOM meter is your friend.
Old 09-21-2013, 07:16 PM   #895
FLASH1970
Oddometer: 1
Here's my 92 DR650
I picked this up a few weeks ago. Pretty easy to ride. I don't have much riding experience and so far it's been really easy to handle. I live in SE Wisconsin. It needs to be dropped a little bit for me. I like being able to have both feet flat on the pavement if I'm stopped, not just my toes or one foot flat. Gas tank is dented and the seat is ripped. But other than that, it runs, handles well, suspension does it's job... It's been re-geared for highway riding, forks were rebuilt, aftermarket exhaust and carb re-jetted for it.
FLASH1970 is offline   Reply With Quote
Old 09-21-2013, 08:22 PM   #896
drdubb
OFWG
drdubb's Avatar
Oddometer: 431
Check out seat concepts foe new foam and cover. Easy do it yourself.
'14 NC700XD - Honda, '06 DR650 - Suzuki, '83 650 Nighthawk - Honda - for sale, '71 SL 350 - Honda
drdubb is offline   Reply With Quote
Old 09-21-2013, 08:52 PM   #897
Nessman
Cluttered Minimalist
Nessman's Avatar
Oddometer: 1,789
My DR650 is my every day commuter. Six miles to work, six miles home she always answers the call and seems to have fun doing it. I've washed her once in the two years we've been together but she doesn't seem to mind as long as her chain is lubed and she has clean oil in her case. I don't remember the last time I rode her for fun, if I ever have, she's a working girl and I respect her for that.
How's that?
'07 Bandit 1250ABS
'78 XS650 with patina
Huge piles of Guzzi that aren't motorcycle shaped.
Nessman is offline   Reply With Quote
Old 09-21-2013, 09:17 PM   #898
ER70S-2
ER70S-2's Avatar
Oddometer: 6,777
Hi FLASH, welcome to the site.
I can only offer this:
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
How's that?
A girl's gotta do, what a girl's gotta do.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
ER70S-2 is offline   Reply With Quote
Old 09-22-2013, 06:09 AM   #899
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,838
How's that?
sounds good
but we cant see it
plugeye is offline   Reply With Quote
Old 09-22-2013, 06:16 AM   #900
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Put my dr 790 for sale in the flea market, here's the link:
http://advrider.com/forums/showthread.php?p=22384945
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Times are GMT -7.   It's 01:22 AM.
