Old 07-03-2012, 10:19 AM   #16
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,013
If these bags really are ABS you don't need to use any special expensive paint, ABS is very compatible with standard formulas, but you do need to make sure and prep the bag for for paint.
So noted for ABS (plastic, that is).
'73 R60/5 Toaster
Old 07-03-2012, 07:50 PM   #17
lake_harley
Oddometer: 687
I spray discolored and faded plastic parts on old bikes with Gibbs Brand penetrating oil. It doesn't leave an oily, sticky film, but after I let it soak on the parts I sometime give it a little "buff" to get rid of the excess. Probably isn't any worse than any of the other magoozzel that's been suggested, and certainly less work than properly preparing them for painting. I like it better than Back To Black, though that would be my 2nd choice.
Lynn
IBA Member #49541
lake_harley is offline   Reply With Quote
Old 07-03-2012, 08:00 PM   #18
DaveBall
DaveBall's Avatar
Oddometer: 1,163
I tried Back to Black. It looked great for a short while, but faded away fairly quickly.
I have also painted a set of Krausers with Krylon Fusion black. They turned out great after a few coats. Then waxed them a few times and they still look good after 2 years. I don't have any photos, but the next time I see the guy that bought the bike, I will get some and post them.
The only problem with painting is the prep. You have to clean them really well. I wiped them down with a cloth and reducer a few times and could not get the rough finish to come out right, so I put some reducer into a clean spray bottle and misted them a few times, then wiped them down. That did the trick. the paint seems to have stuck really well.
DaveBall is offline   Reply With Quote
Old 07-04-2012, 03:07 AM   #19
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,586
My BMW Classic panniers are also looking a tad bland. I just cleaned a couple of unsighted sections with a spray of brake cleaner, scrubbed with a old clean toothbrush and used two different methods to bring the black back. The brake cleaner gives it a lighter colour, so I won't use that again.
1. Ebony Rub 'n Buff. It seemed to work ok, as it does look better, but it should be better still.
2. Rubber grease (pbr brand) It's great for rubber bit's and pieces so despite the case not being rubber I gave it a shot. It blackened it up a bit better than the r.'n.b and a quick polish makes the greasy touch go. It's not a new look either, but certainly better than it was.
I might give a wider area a good go in the next few days, after getting some bonami to use as the cleaning product.
boxerboy81 is offline   Reply With Quote
Old 07-04-2012, 03:34 AM   #20
Boxer Metal OP
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
So far I have found that a light rubbing compound works the best. Still experimenting.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 07-04-2012, 07:39 AM   #21
apt13
Oddometer: 476
i thought i had read on another post or possibly a post on bmwmoa recently that the car bumper paint was the best way to go. i'm eager to see what kind of results you get in your tests as i need to do the exact same thing to my cases. actually the outside of the case is fine, but the inner area where they attach and by the seat is extremely faded. are they 2 different kinds of plastics? or is it because one is smooth and one is textured?
'78 R80/7
'74 CB360
Airhead Tshirts!
apt13 is offline   Reply With Quote
Old 07-04-2012, 09:07 AM   #22
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
Brake cleaner on some plastics....nasty. Does melt ABS and sure turns it grey.
Better fix some of that quickly Eh!
Step one, Leather Dye, let dry then buff.
Step two, good old shoe polish, more buffing.
Step three, Back to Black. Good for a few thousand miles before touching up again....maybe.
That's my old practice lid so never mind the scratches, I have put most of them on intentionally to practice removing them.......Ebony Rub'nBuff not so good.
Have tools, will travel!
Old 07-04-2012, 09:16 AM   #23
bmwloco
bmwloco's Avatar
Oddometer: 1,460
First, a heavy soak in Simple Green. Then a good brush and take them to the car wash. Give 'em a good spray.
Once dry, a good ABS cleaning solution. I like McGuiers plastic cleaners. They do a good job. Wipe it on with a shop towel or good heavy paper shop towel. Let dry, then wipe off.
YMMV, but a little elbow grease and time, they'll look good.
Have fun ;)
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 07-04-2012, 03:56 PM   #24
QdE RedBaron
QdE RedBaron's Avatar
Oddometer: 7
on mine, I use a simple silicone spray and a soft cloth..
QdE RedBaron is offline   Reply With Quote
Old 07-04-2012, 05:02 PM   #25
Mike V.
Mike V.'s Avatar
Oddometer: 66
Euro,
Lot's of great recommendations here. Something I stumbled upon accidentally is regular old Silicone Lube (paste) if you have some laying around the shop. It restored the luster in my instrument cover and bags surprisingly well. Rub it in well with fingers or cloth then buff with dry clean cloth. Might take a couple applications. Doesn't do much for UV protection but it just might bring them back to life.
Mike V. / San Diego
1978 R100/7 (original owner)
1981 R65 (fully restored)
ABC-MOA-AMA-VBMWMO
http://tinyurl.com/4df7hgs
Mike V. is offline   Reply With Quote
Old 07-04-2012, 09:18 PM   #26
Boxer Metal OP
Mad Scientist
Oddometer: 3,521
Originally Posted by Mike V. View Post
Euro,
I did a small spot last night and it helped a bit but the area still looks a little grey. I think rubbing compound first and silicone paste or spray last.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 07-05-2012, 08:11 AM   #27
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
Seriously ... go the shoe/boot polish way ... you will be surprised
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 07-08-2012, 01:44 PM   #28
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
Yep....cheap. Altough the "polish" has shot up in price the last few years. Must be less demand.
Altough the dollar stores do sell black shoe polish, I won't buy it, not very good.
If you have an electric polisher, worth putting the polish right on the pad, goes faster and then you can do your boots/gloves/jacket at the same time.
Old 07-12-2012, 03:20 PM   #29
Boxer Metal OP
Mad Scientist
Oddometer: 3,521
So over the weekend I sprayed the bags with WD-40 and wiped them down really good to get the grime off. Next I sprayed them again and repeated over a couple of days. It looks like the WD-40 is soaking in and making them shiny again. I will wipe them off tomorrow and take some pictures.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 07-12-2012, 06:13 PM   #30
craydds
craydds's Avatar
Oddometer: 1,167
Too bad the WD-40 will destroy the plastic. So sorry.
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Times are GMT -7.   It's 05:58 PM.
