Old 12-10-2013, 05:40 AM   #1
XTrovert OP
chick magnet
Oddometer: 120
Would anyone volunteer correct o-ring sizes for 32mm bing carby
Hi All and greetings from Argie-bargy, the place for economic madness!
I need o-rings for my bing 32mm carbys and I am having a helluva time sourcing something locally.
I have checked Max, Motobins, largiader....
Everything is confusing and vague so I wonder if someone with those o-rings in hand could please tell me the exact sizes in mm. External diameter, internal and thickness.
I need only three sizes:
Idle jet / Idle screw 13 11 1 254 735
Choke 13 11 1 257 819
Venturi Mix 13 11 1 257 81
The rest I do not touch
Thanks in advance and sorry if this post has been covered somewhere I just did not find it.
Merry Xmas to all
XTrovert screwed with this post 12-10-2013 at 05:41 AM Reason: as usual stuffed up...
XTrovert is offline   Reply With Quote
Old 12-10-2013, 07:18 AM   #2
190e
Oddometer: 734
The sizes I have on record are:
main jet holder 8x1.75mm
mixture screw 3x1.75mm
idle jet 3x1.75mm
enrichener shaft 5x1.5mm
Sizes are ID x section which is the usual standard.
I use generic nitrile O rings from a kit and have never bought the genuine articles from BMW. They seem to last for several years and I have plenty of them on the shelf for when they are needed.
190e is offline   Reply With Quote
Old 12-10-2013, 08:17 AM   #3
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,448
Here are links to Max BMW which has photo's of the o-rings on a ruler (properly aligned):
http://www.maxbmwmotorcycles.com/fic...er=13111254735
http://www.maxbmwmotorcycles.com/fic...er=13111257819
http://www.maxbmwmotorcycles.com/fic...er=13111257812
Anton and Snowbum have the o-ring dimensions on their web pages:
http://www.largiader.com/tech/carbs/
http://bmwmotorcycletech.info/bingcv-2.htm
Note that part #13111254735 is declared M1.75x3 (at least,here in the states by industrial standards). The oringstore shows the closest size is M1.78x3: http://www.theoringstore.com/index.p...Path=368_12_43. However, upon scrutiny of the MAX BMW photo, it appears the O-ring OD is 7mm and looks like a M2x3.
Whenever I measure o-rings it is done optically (or by comparison). Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 12-10-2013, 12:00 PM   #4
190e
Oddometer: 734
Got to admit that's what I do too.
When I looked at my Kit the O rings I have been using are indeed 1.78 in section.
The idle jet/mixture screw 2.9 x1.78 - They work fine.
Enricher shaft 5.28 x 1.78 - A bit tight but they seem to settle down and work OK
Main jet holder 7.66 x 1.78 - This is the nearest I have and not such a good fit. The diameter is too small and I have doubts that the 1.75 specification for the section is correct as the locating groove looks distinctly wider though I haven't measured it. Having to stretch the O ring will reduce the section a little further which won't help. The picture on Max's web site looks more like 8 x 2 and I'm sure that would be a better fit.
Old 12-10-2013, 02:10 PM   #5
Warin
Retired
Oddometer: 2,194
If you have the thing to bits then measure the metal bits the O rings ride in. The O ring ID will be a little less than the OD of the metal it rides on, and the difference in diameters (id - od) will give an indication of thickness - add something for pressure. Of those two, the O ring ID will be the more accurate, the thickness will be more vague. As the metal bits are hard you should get 'good' numbers.. it it then the estimate as to how much pressure the O ring should exert.
Warin is offline   Reply With Quote
Old 12-10-2013, 03:30 PM   #6
JimGregory
JimGregory's Avatar
Oddometer: 698
from a kit.
I dont know where they go but these are the rings for 2 carbs.
Hard to measure the wiggly things I can say.
There is 4 the same on the bottom two rows so two per carb.
Jim Gregory, Southern CT USA
92 R100RS, 99 VFR
JimGregory is offline   Reply With Quote
Old 12-11-2013, 10:04 AM   #7
190e
Oddometer: 734
From the top:
Main jet holder
Throttle shaft
Enricher shaft
idle jet or mixture screw
Those sizes tend to confirm my feeling that the sizes usually quoted are not all quite correct i.e. the main jet holder should be 2mm not 1.75 in section otherwise it will be too loose.
Old 12-11-2013, 01:05 PM   #8
JimGregory
JimGregory's Avatar
Oddometer: 698
Originally Posted by 190e View Post
From the top:
Main jet holder
Throttle shaft
Enricher shaft
Main jet is definitely not 1.75. I measured it a few times to be sure. I think you can go a bit over these numbers or a tiny bit under but I wouldn't go under myself. A bit over with a touch of dielectric grease and all should be fine.
92 R100RS, 99 VFR
Times are GMT -7.   It's 01:02 AM.
