Old 07-19-2012, 11:56 AM   #181
aarlint OP
noob rider
aarlint's Avatar
Oddometer: 53
no reply.. that figures
Peter's email replies are sporadic sometimes I get emails within hours and other times it takes weeks sometimes a response never comes. Most of the time they are 1 sentence long answering only 1 of the 5 questions I sent in my emails.
Sorry to hear about your issues. I hope he can give you a similar deal like he gave me.
Speaking of which. He emailed me yesterday and said the bike is a week out on delivery. So by this time next week I hope to be riding away with my tiger!
utah2argentina.blogspot.com
'12 Tiger 800 xc
'11 BMW g650gs (wife's ride)
aarlint is offline   Reply With Quote
Old 07-19-2012, 11:58 AM   #182
aarlint OP
noob rider
aarlint's Avatar
Oddometer: 53
Originally Posted by phillipsrog View Post
No big surprise. Rode the bike to work, everything was fine. Came home at lunch and went to leave and after turning the key the immobilizer light was on and the bike won't start. I'm waiting for it to reset, or whatever the hell it does. No telling how long it will take.
Sent Peter Carleo an email on Friday updating him on my problem. It's now been a week and I've heard nothing. The first time I emailed him he replied within hours. I just sent him another email before posting this.
Maybe he's on vacation. Who knows? All I know is I still have the immobilizer problem and do not appear any closer to having it resolved.
And here's a really weird coincidence. I have a Pelican case mounted on the back, and the latch broke. While I was home at lunch, I called Pelican about it, and they're sending me two latches completely free. I just told them I had a problem and they sent replacement parts. That's good customer service.
Did you cover the ignition so it isnt in direct sun?
'12 Tiger 800 xc
Old 07-19-2012, 02:33 PM   #183
phillipsrog
Oddometer: 151
It happened in the garage
It was only the second or third time that's happened in the garage. I pulled the key and waited a couple minutes and then retried several times. Then waited about 15-20 minutes and no luck. I had to get back to work, so I took my truck. Odds are very good it will fire up when I get home.
Thanks for the intel on Peter. I need to call Sandy, too. I'm going to do that now.
phillipsrog is offline   Reply With Quote
Old 07-19-2012, 04:55 PM   #184
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,786
Longshot here but when it happened did you immediately try the other key?
My Mazdaspeed sometimes won't accept one of the keyless fobs. Trying the other one gets me going every time. It's a Mazda thing. :
Sent from my SGH-T959P using Tapatalk 2
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is online now   Reply With Quote
Old 07-19-2012, 05:27 PM   #185
phillipsrog
Oddometer: 151
Tried it in the past.
No difference. Still doesn't work. Fortunately for me, this problem usually resolves itself in a short amount of time, then crops up again later. Usually at least once per week, sometimes more often, and occasionally less often. And I ride it almost daily.
Old 07-19-2012, 05:49 PM   #186
Fasttrak
Captain Crash
Fasttrak's Avatar
Oddometer: 359
Have you tried doing a power cycle of the ECM? Not sure how difficult it is to get to the battery but disconnect the negative lead for a couple minutes and try it again. See if there is some software glitch with a timeout or such causing your trouble. Grasping at straws and all I came up with.
Fasttrak
Ken
'09 Husqvarna TE610
'12 Tiger Explorer Graphite
Fasttrak is offline   Reply With Quote
Old 07-19-2012, 06:00 PM   #187
phillipsrog
Oddometer: 151
Tried that too
And I don't mind the suggestions. Just got home from work and it fired right up, which it has consistently done. It's just a matter of the immobilizer rebooting or something, unfortunately, I have no idea what that means or how or why it does it. Apparently, Triumph doesn't either.
Old 07-19-2012, 07:01 PM   #188
aarlint OP
noob rider
aarlint's Avatar
Oddometer: 53
I supposed the time it takes to start it again is a safety no start time after a failed key attempt. Remember the bike thinks you have a copy cut of the key but the wrong digital signature. It would be interesting to get a key cut and try it and then try the other right key and see if it starts immediately.
'12 Tiger 800 xc
Old 07-19-2012, 07:04 PM   #189
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,853
Well this certainly sucks. Made even worse by your distance from the dealer. The shitty thing would be for it to not act up once taken to the dealer. Hopefully there is a scenario which tends to give this problem even if not 100% of the time so you might be more likely to be able to create the problem at the dealer. The immobilizer should be an option at least if not discarded all together for the US.
Best of luck.
swimmer is offline   Reply With Quote
Old 07-19-2012, 07:25 PM   #190
docsherlock
docsherlock's Avatar
Oddometer: 479
I haven't read the whole thread, but have you downloaded TuneECU and checked for fault codes?
docsherlock is offline   Reply With Quote
Old 07-19-2012, 08:57 PM   #191
aarlint OP
noob rider
aarlint's Avatar
Oddometer: 53
This was posted in another thread but unlike his a replaced immobilizer didn't fix mine.
"I had it twice. I used Tunecu to see the error code, it was something like 1650. It was the immobilizer that was causing problem (the thing that check the code of your key). Replaced under warranty by my dealer."
'12 Tiger 800 xc
Old 07-19-2012, 10:27 PM   #192
phillipsrog
Oddometer: 151
I'll spare you reading the whole thread. Austin (Aarlint) and I both having the same problem, and the dealer in Salt Lake was working on his for months and Triumph punted on the repair and decided to replace his bike. I was waiting for his to be fixed so I could take mine 350 miles (one way) to get it repaired.
They decided to replace his, and mine hasn't been in a shop yet to have an official diagnostic, which hopefully will happen soon so I can at least know for sure I have the same problem.
Old 07-19-2012, 10:56 PM   #193
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
This has been an interesting thread. Sorry to the OP and phillipsrog for the hassle.
As for Triumph's response, I really don't have a dog in this fight as I don't even have a Tiger, but if Triumph is going to replace the OP's bike and he didnt have to involve an attorney, that sounds like pretty good customer service to me. 3 months doesnt sound egregiously long either.
All brands have their issues. Hopefully this will get sorted out soon for the affected owners. Good luck and please post if a particular solution is discovered.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 07-21-2012, 02:03 AM   #194
bridwell52
bridwell52's Avatar
Oddometer: 143
Two bikes with the same issue does not sound good. How many others are out there ?
bridwell52 is offline   Reply With Quote
Old 07-22-2012, 02:27 PM   #195
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,334
Well I have just read the entire thread. I own a 06 Sprint ST 1050 bought new and only one issue, the rear shock linkage replaced under the recall way later than Triumph wanted, but still covered and was a complete failure. Lucky I never crashed. I also own an 06 Tiger 955i I bought last summer. The dealer was great customer service, knowing I was 100 miles away and told he needed it over night to diagnose, he asked if I could be back the next Saturday I said yes. He said because we thought it was a one day deal and wasn't, told me to take is brand new Sprint GT demo until the Tiger was repaired. His service Dept royally pissed me off recently, but would still deal with him because of great customer service.
I feel for the OP, my VTX1300 went down when the starter button went down and was backordered. The dealer was willing to just let the bike sit in his service dept indef. Two monthes later I told him that he would have until Sat or it would be stored for a year, I am a soldier, he canabolized a showroom unit to get rid of it before I deployed.
I am truly sorry for what the OP had to go through, but ALL motorcycles are getting more and more complicated unfortunately he may be not be the only one seeing issues like this from all brands.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is offline   Reply With Quote
Times are GMT -7.   It's 07:48 PM.
