07-05-2012, 03:30 PM
#1 |
Stop washing it and ride
Shock Springs question
OK so my 950 ADV 2005, soft as hell front end as many comment on...especially after the Safari tanks. So, I spoke to Craig at CJ, super nice guy, he says go with .58's. I'm 5/10 200 pounds so the springs get here. One thing he tells me is that it will even raise the bike a bit.
Now, the bike rides absolutely better, much stiffer and the handling is just better all the way around BBBBUUUUUUTTTT... ...when I removed the springs, the .58's I bought are actually lower than what was in there in height. Did the PO already upgrade or what the hell? CJ's .58 are on the right.
I'd rather do something someone will write about...than read something someone did. Patrick Buckley |
07-05-2012, 03:40 PM
#2 | |
suspension guy
Oddometer: 167
James
www.superplushsuspension.com Never argue with stupid people, they will drag you down to their level and beat you with experience. James Siddall screwed with this post 07-05-2012 at 03:41 PM Reason: spelling |
07-05-2012, 06:50 PM
#3 |
Holy crap...
Thanks for the response James...does that men I just lowered the bike 2 cm.? I will measure them tomorrow and give you the length.
07-06-2012, 08:11 AM
#4 |
More Ride, Less Google
Oddometer: 5,757
Well, I'm not James but I did drive by a Holiday Inn once...
The shorter springs will not change your fork travel (neither will longer ones). All you need are some 20 mm spacers to make up the difference for correct spring preload. However...if you have a 2005 standard Adventure (ie. not an S or R bike), you have 8" travel forks and those should have come with the same length springs as CJ sold you, 465mm. So it's a fair bet that a PO changed fork springs before you. Now, AFAIK you certainly can run the longer springs in your 8" forks, just use no or very little spacer on top. That's exactly what I'm doing with my 485mm 6.0's in my 8" forks, and it seems to work fine...but hopefully James will be along to straighten us all out and I can justify buying some softer (and shorter) springs.
2003 Kawasaki KLR650 "Reality" 1993 Ducati 900SS "L'evento" Chuckracer screwed with this post 07-10-2012 at 05:23 PM |
07-10-2012, 03:27 PM
#5 | |
suspension guy
Oddometer: 167
Fork Spring length
Your travel refers to the maximum stroke top to bottom, which has not been impacted. But likely you are riding lower in the stroke dynamically. James
www.superplushsuspension.com Never argue with stupid people, they will drag you down to their level and beat you with experience. |
07-10-2012, 06:12 PM
#6 |
Oddometer: 5,757
Aha!
![]() I'm glad he asked!
2003 Kawasaki KLR650 "Reality" 1993 Ducati 900SS "L'evento" |
#7 |
So are we critical
Ok so if I leave it as it is...am I;
damaging anything? Compromising ride safety? Stiffer ride? Softer ride (can't be). If I leave the ground will I bottom out easier? Or can I just leave it be and ride on? My original intention was to stiffen the ride and add some clearance to the bike.
