Old 07-05-2012, 07:42 PM   #1
fosters2 OP
It is what it is
fosters2's Avatar
Oddometer: 201
What is this plug for?
Can anyone tell me what plug on the top of the battery in the picture below is for? I already did some searching but could not find the info (did find this picture).
Picture borrowed from ebrabaek in this thread.
F800GS
IBA#42277
SOLD - K1600GTL, S1000RR, R1200GSA, K1300GT, R1100, K75
http://www.scfoster.com
fosters2 is offline   Reply With Quote
Old 07-05-2012, 08:13 PM   #2
1P8RIOT
1P8RIOT's Avatar
Oddometer: 390
You can connect small accessories there that will go on and off with the can-bus system (they'll come on with the key in the on position and go off 10 - 15 seconds after you shut off the bike) I have a voltage meter and the hard wire for my gps hooked up there. I don't remember where I got it from; but there is a plug made for doing this. I think it was called the can-bus helper. Hope that helps.
A ship in a port is safe but that is not what ships are built for. - Mom
'09 F800GS YEAH BABY!!!
1P8RIOT is offline   Reply With Quote
Old 07-05-2012, 08:42 PM   #3
Snowy
Oddometer: 1,820
This one?
Don't know exactly. Can't find a description anywhere in the useless BMW repair and service DVD.
It's not wired into the battery is it? edit: no it isn't.
Snowy is offline   Reply With Quote
Old 07-05-2012, 09:04 PM   #4
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,230
Its the conection fot the BMW navigator GPS.
Sent from my HTC Desire using Tapatalk 2
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 07-05-2012, 09:06 PM   #5
sieg
sieg's Avatar
Oddometer: 2,861
Just an accessory hook up. Got my GPS hooked to mine.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 07-06-2012, 04:29 AM   #6
fosters2 OP
It is what it is
fosters2's Avatar
Oddometer: 201
Thanks. Hadn't gotten around to putting a voltmeter on it, so I thought I'd ask. The plan is to install a PDM60 power distribution block. I've owned all the others with various bikes but this one is better, imo. Solid state, waterproof and Aerostitch won't tell you this... it's completely programmable.
Posted about it in this thread.
F800GS
IBA#42277
Old 07-06-2012, 05:32 AM   #7
OrcasKen
OrcasKen's Avatar
Oddometer: 125
You can get the wire/plug from your dealer for about $20. As I recall, I believe it carries up to 5 amps and as said above, it runs off of CAN bus and goes off ~30 seconds after the bike shuts off. Usually. I've got mine wired to the relay for a power distribution block and it has not gone off a couple times in the past year, so on my list of things to do is to change over to a headlight tap for my relay.
2010 F800GS
2006 KLX250S
2008 CRF230L
OrcasKen is offline   Reply With Quote
Old 07-06-2012, 06:08 AM   #8
fosters2 OP
It is what it is
fosters2's Avatar
Oddometer: 201
Was planning on doing the same to provide the switch power sensor for the PDM60.
F800GS
IBA#42277
Old 07-06-2012, 06:44 AM   #9
JRWooden
Oddometer: 4,262
The mating plug is available as a service part from BMW, or from F800Depot.com
Here's a little ditty I did with the thing:
http://f800riders.org/forum/showthre...mp-GPS-adapter
A word of warning: I originally wired my voltage monitor and my garmin power "brick" voltage converter to the plug.
The Garmin converter accepts 12V and knocks it down to 5V for the GPS.
What I found was that the converter somehow confused the canbus and at times would leave the circuit energized indefinitely (the voltage monitor LED would stay lit all the time). In order to fix the problem I ended up wiring the Garmin unit directly to the battery leaving just the voltage monitor LED on the GPS "plug".
Old 07-07-2012, 01:13 AM   #10
casperghst42
casperghst42's Avatar
Oddometer: 213
You can maximum pull 5amp from the cambus.
Casper
casperghst42 is offline   Reply With Quote
Old 07-07-2012, 03:14 AM   #11
Cesar Serpa
Cesar Serpa's Avatar
Oddometer: 25
I did the same and put a switch to switch ON/OFF the GPS
"The value of things is not the time they last, but the intensity with which they occur. So there are unforgettable moments, inexplicable things and incomparable people." - Fernando Pessoa.
Cesar Serpa is offline   Reply With Quote
Old 07-07-2012, 03:43 AM   #12
Dirt Junkie
Oddometer: 12
I connected my GPS on it using a plug supplied by BMW part number 83300413585 the 1200GS also uses the same plug your GPS will switch off 60seconds after you turn your bike egnition off
Dirt Junkie is offline   Reply With Quote
Times are GMT -7.   It's 10:52 PM.
