Go Back   ADVrider > Riding > Regional forums > Australia > OZ Vendors
Old 07-08-2012, 01:05 AM   #1
lockyv7 OP
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,064
MTD Aluminum Panniers and Pannier kits
I am posting up some pannier kits to clear some stock at a reduced price.
$795.00 for a Basic style pannier kit, powder coated with liner bags
$950.00 for the Classic style pannier kits, powder coated with liner bags
I make these kits to fit these bikes.
BMW 1200GS W/C
BMW 1200GS
BMW F800GS
BMW F650/700GS
BMW G650GS
Tiger 800
Explorer 1200
V-Strom 650
Tenere 1200
Tenere 660
KTM 1190
Alloy panniers and pannier kits.
BASIC PANNIER & KITS
These panniers come in two sizes and with or without an exhaust cut-out
450Long x 380High x 210Wide 35lt / 30lt with Exhaust cut-out
450Long x 380High x 260Wide 45lt / 40lt with Exhaust cut-out
PRICE For pannier kit, thats with 2 panniers, pannier frames and pannier mount kit with Exhaust cut-out.
$895.00 Raw alloy
$100.00 Powder coating
ADV price $895.00 Powder Coated
CLASSIC PANNIER KITS
$1050.00 Raw alloy
$100.00 powder coating
ADV PRICE $1050.00 powder coated
For the BMW1200GSA
fitted with BMW GSA pannier frames i build a pannier kit to fit straight to those frames. These are in the Classic style with an exhaust cut. These kits also come in a small and a large size.
$850.00
$100.00
ADV PRICE $850.00 Powder coated
TOP-BOXS
large and Ex-large sizes.
400Wide x 350Deep x 280High 40lt large
550Wide x 350Deep x 280High 52lt Ex-large
$350.00 either size
$ 50.00 powder coating
ADV price $350.00 powder coated
All my panniers are hand crafted by myself on the Sunshine Coast Queensland, i freight Australia wide with TNT road express, contact me for a freight cost.
I can be contacted via PM or this thread, but i check my e-mail or answer the phone more often.
e-mail lachlan@mtdtours.com
PH- 07-54931381
or 0417622880
more to come.
lockyv7 screwed with this post 10-20-2013 at 12:08 AM
lockyv7 is offline   Reply With Quote
Old 07-08-2012, 02:57 AM   #2
Unstable Rider
Moto Fotografist
Unstable Rider's Avatar
Oddometer: 2,628
Very snazzy looking cans I must say..
Never do anything you would be uncomfortable explaining to the paramedics...
Unstable Rider is offline   Reply With Quote
Old 08-06-2012, 05:27 PM   #3
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,064
$1695.00 kits.
BMW1200GS Adventure style kits $1695.00
You get this.
1 x set Pannier frames powder coated Black with Exhaust cut for left pannier
1 x Adv style rear rack powder coated black, these racks are like a BMW adventure rack.
1 x Mesh style headlight guard powder coated black
1 x Set of MTD Basic style panniers in either a 30/35lt combo or a 40/45lt set. Powder coated
Yellow 1200 above has the 30/35lt Basic panniers
Black and Silver 1200 below has 40/45lt Basic panniers and 40lt Classic style top-box
1 x set of Adventure style crash bars, top and bottom sets. Powder coated black
Most of this kit, rack, pannier frames are also avaliable in stainless, stainless will cost you more so best to contact me before and ask, i dont carry everything in all colours and stainless as there would be just to much stock and money sitting on a shelf as there are other bikes and brands and models to carry stock for.
This kit can also be upgraded to Fit my Classic style panniers with the angles around the bottom, plus top-boxs if needed. For the Classic style panniers add an extra $150.00
This post is really about buying as a kit, i will be trying to put kits together for the F800/650GS and also the Tiger800 and the Tiger1200
Basic kits, good value.
Old 08-06-2012, 07:57 PM   #4
Russ
Russ's Avatar
Oddometer: 17,039
That is a great package
Russ is offline   Reply With Quote
Old 09-16-2012, 08:48 PM   #5
Fipsy
form. gonescratchin
Fipsy's Avatar
Oddometer: 489
Regarding fitting to an R1200GSA, using existing pannier frame, do/can the panniers actually key-lock onto the frame?
Also, is removing the pannier done from inside the box, or outside the box? (i.e. where is the release latch located?).
Some other questions:
1. Would you rate them as waterproof, water resistant, or dry-bag is a must? What sort of seal-system is built into the lids?
2. Would it be possible to see some pics of the innards, and under the lids?
3. What thickness aluminium are you using for them?
4. Is the powder coating that 'hammertone' finish? Or just a plane, non-textured, look?
5. Can they be ordered without the recessed lid handle (in the middle of the lid)?
Sorry for all the questions, but I have found it really hard to buy this sort of stuff site-unseen in the past! All the info you've got would be great.
They look fantastic, and it's great to see some Aussie-made options available.
Cheers,
Fipsy screwed with this post 09-16-2012 at 09:01 PM
Fipsy is offline   Reply With Quote
Old 09-17-2012, 02:32 AM   #6
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,064
Cheers,
Hi, the panniers dont key lock, they use a puck and loc tab for mounting.
The panniers are built from 2mm sheet
This photo is for the lids.
There fitted with a block rubber seal in the lid, a alloy angle is welded under the lid to hold the seal.
the powder coating is the textured look.
These are fully tig welded and waterproof
Without the recessed handles are no problem, may have to make and powder coat a set, i just end up with to much stock sitting on the shelf to carry everything.
To remove the panniers first you have to remove the lockable lids and undo the lock tabs from inside the box.
Old 09-17-2012, 04:57 AM   #7
Fipsy
form. gonescratchin
Fipsy's Avatar
Oddometer: 489
Thanks for getting back so quick. They look like a great piece of workmanship.
I only mentioned the handles on top cause of the tendency for corrugations to cause any edges to pretty well saw through anything touching them. (ie tent strapped on top).
I'm planning a 2 week trip over to Warburton early next year (once it cools down up there at least), from Adelaide, and will likely need more storage than my soft panniers can offer. Will be chasing dirt as much as possible. These look like they'll do the job nicely.
What sort of time frame should I allow for an order? (Am thinking of the Classics for the GSA, powder coated, let's assume you have none in stock and need to make them from scratch).
Old 09-17-2012, 09:57 AM   #8
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,064
To build a set from scratch with powdercoating a bit over 2 weeks, if i ask the powder coater to hurry the job through make it a bit over 3 weeks. I normally have a couple of set of lids without handles kicking around, soom i will also have my own expandable lit top bags, but there a couple of months off. If you need more photos or anything else just contact me through lachlan@mtdtours.com
Cheers Lachlan
Old 09-17-2012, 04:28 PM   #9
Fipsy
form. gonescratchin
Fipsy's Avatar
Oddometer: 489
Thanks Lachlan,
Once I've got some dates sorted I'll drop you an email.
Cheers
Chris
Old 10-02-2012, 03:59 AM   #10
OldDog
aka Hugh Jarse
OldDog's Avatar
Oddometer: 4,719
Panniers for Triumph 800XC?
Hey Locky, quick question mate, are you making panniers to suit the Triumph 800XC? I'm after a plain basic set.
Cheers
Bill
Your time is limited, so don't waste it living someone else's life. - Steve Jobs
Yesterday afternoon I was planning to ride Dakar, this morning I was planning to throw up in my helmet - Boris Mihailovich
Objects in the rear view mirror.....appear to be losing - Me
OldDog is offline   Reply With Quote
Old 10-04-2012, 02:50 AM   #11
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,064
Cheers
Bill
Hi bill, when you say 'plain' basic set is it raw alloy your after, if so yes i have a set here made up $895.00 for a kit, thats pannier frames, panniers one with a cut-out for the exhaust and a pannier mount kit, pucks and loc tabs and all the fittings.
$895.00
Cheers Lachlan
Old 10-11-2012, 06:24 PM   #12
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,893
Locky
Can you stick up some pics, words & price for your DR650 rack system? I've got a mate wanting to suss them out. Thanks.
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is online now   Reply With Quote
Old 10-12-2012, 02:45 PM   #13
Sydney Andy
Oddometer: 47
Do you do anything for the Yammy XT600E ???
Sydney Andy is offline   Reply With Quote
Old 10-14-2012, 06:17 PM   #14
Precis
Maladroit malcontent
Precis's Avatar
Oddometer: 3,709
I've got a set of these boxes and they're world-class - easily a match for the stuff from Germanland; They even take being whacked into the bench at Campsite picnic tables with no structural damage.....
Being a notorious tight-arse, I grabbed a set which came up second-hand - only set I've ever seen offered for sale; One of the latches had lost its lock on a previous trip around Australia; when I contacted Locky about the cost of a replacement, he sent it gratis. Free. No charge. Despite the fact that I hadn't paid him for the boxes but bought them second-hand.
That, Ladies & Gents, is Customer Service - something which most traders in Australia have either forgotten, or never knew.
The only way these panniers could be improved? By having a slide-out fabric bag to sling over your shoulder as you step into the hotel.
But if you're weighing up the cost of these or boxes from Germanland, Remainhere, India, China or wherever, you not will be unhappy with Locky's products, his price or his service.
For the next or other bikes, I'd certainly only make one call.
(NB: No affiliations other than as a very happy non-customer!)
"I would like to die on Mars; just not on impact." Elon Musk
Precis is offline   Reply With Quote
Old 10-17-2012, 02:14 AM   #15
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,064
Originally Posted by farcall View Post
Locky
A few photos of the DR650 stuff
Pannier frames and rear rack , heavy duty. $450.00
Times are GMT -7.   It's 07:31 AM.
