Old 07-07-2012, 09:11 PM   #1
roger 04 rt OP
roger 04 rt's Avatar
Oddometer: 2,272
R1150RT Fuel System Higway Failure
Removed site admins explained this site is for GS riders. See BMWMOA and BMW Sporttouring.
Tank Fuel Hose Rebuild
Fuel System Failure MOA
roger 04 rt screwed with this post 07-20-2012 at 05:54 AM
roger 04 rt is offline   Reply With Quote
Old 07-07-2012, 10:15 PM   #2
Yeahbaby
Yeahbaby's Avatar
Oddometer: 77
Just order the correct line from Max BMW. You get a 1 meter length of hose for a lot less than NAPA or others will charge. NAPA tried to charge me $27.00 a foot for in-tank line. The MAX type is the correct in-tank type. Also change out the "U" shaped hose, don't choke on the price. Remember to get the large and small hose. When you replace the O ring order 2. If you open things up and quickly try to button up again. You will notice that the O ring might be too large and a bugger to put back together. The fuel makes the O ring swell. I have a spare that I replace each time I open things up. Same goes for the fuel cap O ring.
You can outrun a motorcop....but you can't outrun Motorola
When you start loosing your mind over a woman remember this one simple fact.................it's just the hairy end of a gut!!!!!!!!!!!!
Yeahbaby is offline   Reply With Quote
Old 07-08-2012, 04:04 AM   #3
roger 04 rt OP
Oddometer: 2,272
Removed site admins explained this site is for GS riders. See BMWMOA and BMW Sporttouring. I want to be proactive and help ADVRIDER.com conserve web space.
roger 04 rt screwed with this post 07-20-2012 at 04:33 AM
Old 07-09-2012, 03:28 AM   #4
roger 04 rt OP
Oddometer: 2,272
roger 04 rt screwed with this post 07-20-2012 at 04:31 AM
Old 07-10-2012, 12:27 PM   #5
roger 04 rt OP
Oddometer: 2,272
Old 07-10-2012, 08:05 PM   #6
izzy's
Oddometer: 321
in tank fuel line
I just returned from an Alaska trip from Arkansas last Thursday. On the way up North I had a similar fuel line failure in the middle of Nowhere, Montana. On the side of the road I had the opportunity to totally unload the bike, remove the fuel tank and inside found one of the fuel lines attached to the filter had a hole in it. Because of lack of parts I had to use some redneck engineering and two zip ties to close the hole and make it to a farm store about 15 miles further down the road. At the farm store they had some standard off the roll fuel line I used to make a better repair and get back on my trip. I finished the trip without any further problems.
In this thread is the first time I've heard of "in tank" fuel line. Do I need to order "in tank" line and replace the standard fuel line that I used for the roadside repair.
Not that it matters but my bike is an '04 1150 GS.
Izzy
izzy's is offline   Reply With Quote
Old 07-11-2012, 06:53 PM   #7
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,279
Yes, you do. R10 hose will degrade in sunlight and R9 hose will degrade when submersed. Each has its place.
However, even the R10 hose can decay when left in old fuel for a long time. Sometimes it just needs to be replaced even though it was being used correctly.
EDIT: the BMW hose isn't marked R9 or R10. It's NBR-NBR for internal, and CR-NBR (or a variant of that) for external.
Old 07-11-2012, 07:15 PM   #8
roger 04 rt OP
Oddometer: 2,272
Old 07-12-2012, 02:32 PM   #9
roger 04 rt OP
Oddometer: 2,272
roger 04 rt screwed with this post 07-20-2012 at 04:32 AM
Old 07-12-2012, 04:32 PM   #10
Steve W.
Boxer Pilot
Steve W.'s Avatar
Oddometer: 317
Euro Motoelectrics offers a fuel line kit for in tank.
http://www.euromotoelectrics.com/BMW...fp-hosekit.htm
Looks like the hose is a nylon corrugated to allow bending. It is rated 30r10. I've seen this type of hose used on oem automotive in tank pumps (GM).
Anyone using this type hose? It looks like the hose could replace the U and the other pieces at the pump and filter.
Cheers
Steve
"Never say Never"
Steve W. is offline   Reply With Quote
Old 07-13-2012, 11:04 AM   #11
roger 04 rt OP
Oddometer: 2,272
Steve,
Thanks for the recommendation, already ordered from Max BMW.
RB
Old 07-13-2012, 11:05 AM   #12
roger 04 rt OP
Oddometer: 2,272
Old 07-13-2012, 11:26 AM   #13
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,537
Great info Roger.
and you might be on to something about the leaky internal fuel hose.
mine pings and knocks terribly lately, even with 94 octane in it.
I guess I should open it up and have a gander.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 07-13-2012, 11:29 AM   #14
cardoctor1
cardoctor1's Avatar
Oddometer: 545
great post had the same thing happen to me a few weeks ago fuel line between and fuel filter and outlet split. replaced the lines inside the tank with 180psi efi hose but didnt know about the hose itself being submersible . even after replacing the fuel hoses i still get a random lean condition where it falls on it face unless i keep the revs at 2500rpm's it clear up in a mile and may not do it again for a few hundred miles.
IBA#35592
RIDE EVERY RIDE LIKE ITS YOUR LAST
00 R1150GS
cardoctor1 is offline   Reply With Quote
Old 07-13-2012, 06:08 PM   #15
sonnyb
Oddometer: 126
roger,
which pump did you get?
sonnyb is offline   Reply With Quote
Times are GMT -7.   It's 02:22 AM.
