Old 07-08-2012, 12:30 AM   #1
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,147
Send a message via Skype™ to tagesk
Pool of DOT-4
At Ørnes, North Norway, with a large pool of DOT-4 on the ground beneath the bike.
It is dripping from the gearbox.
I thought I felt a little sliping on the clutch yesterday.
Now I know I was right.
Question: Will I get stranded or will I be able to limp along?
Bike has a mere 75.000 km on it.
TaSK
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is online now   Reply With Quote
Old 07-08-2012, 12:36 AM   #2
MIXR
MIXR's Avatar
Oddometer: 505
Dead bike
TaSK - If it's gone as far as pooling on the deck then it's either a line that's chaffed through or corroded, or a blown slave. Either way, you will soon run out of clutch fluid. Have a close look and if necessary, peel back the covering on the clutch line. Sometimes they corrode the line under the covering. I think blown slaves are more common than lines, but the paper gasket on the slave usually means the fluid runs down the clutch pushrod and into the housing. If it's leaking at the gearbox/engine join, it will be a slave. If it's leaking at the back of the bell housing (external), it may just be a line. Good luck.
MIXR is offline   Reply With Quote
Old 07-08-2012, 01:32 AM   #3
frodef
Oddometer: 12
Here's an action shot from Tage, fwiw:
frodef is offline   Reply With Quote
Old 07-08-2012, 02:42 AM   #4
Zoef zoef
Oddometer: 256
Hei,
Pokker, det er ikke så bra.
If it was the hose, then it should not contaminate the clutch, as the hose is outside the clutch housing. The slave cylinder however, if leaks, can spill the fluid into the clutch itself via the push rod. So I'm afraid my first suspicion is towards the slave cylinder. If you need assistance, just let me know.
If it is the cylinder, then if the leak is not too bad, then you can fill the reservoir regularly, but this could mean you'll have to replace the clutch later on (if you repair now, you may be fine).
Zoef zoef is offline   Reply With Quote
Old 07-08-2012, 03:59 AM   #5
billdonna
Ex Coelis
billdonna's Avatar
Oddometer: 530
TaSK
Umm....isn't Dot4 brake fluid? I thought the clutch used mineral oil? If there is brake fluid in the clutch system, that might explain the failure. Ciao...Best of luck!!!
I do not intend to tiptoe through life, only to arrive safely at death
billdonna is offline   Reply With Quote
Old 07-08-2012, 04:26 AM   #6
MIXR
MIXR's Avatar
Oddometer: 505
1150 not 1200
The R1150 is Dot 4 for brakes and clutch. The R1200 is different. He has the R1150.
We have a bike here with similar clutch slip symptoms and will be replacing the slave. It's not dumping yet. I'd agree that it shouldn't be ridden to avoid the prospect of damaging the clutch liner with that much leaking. Hopefully it's just dripping off the felt and going straight out the bottom of the housing.
As is, it may pay to spray some brake cleaner on to the clutch via the timing inspection plug. You can get a clean shot at the clutch lining from there and may be able to save the clutch. In neutral and rotate the back wheel while you spray. Can't hurt anything, so worth a try if the clutch is suspected of being contaminated. It all drains out the bottom of the housing and can't get into rear seals or anything else that's critical.
Old 07-08-2012, 05:44 AM   #7
fastredbike
out riding
fastredbike's Avatar
Oddometer: 460
interesting idea with the brake cleaner/clutch lining.
I'm sure you've done it already but inspect carefully all the way round the joins between the clutch housing and engine/trans. if there's any sign of fluid seeping there then it's likely on the clutch too. I couldn't see any in your "action shot" but it's not exactly the highest res. photo on the board
good luck
fastredbike is offline   Reply With Quote
Old 07-08-2012, 07:51 AM   #8
def
I have little to say
def's Avatar
Oddometer: 6,480
Send a message via Skype™ to def
DOT4 is correct for his model.
Old 07-08-2012, 02:58 PM   #9
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,147
I had no alternative so i had to ride the bike.
After having dumped all the fluid on the ground, it stopped leaking.
The clutch is still slipping at, say, 75% power and above, but below it holds.
We did 600 km today, and some 400 km remains before we reach the dealer in Trondheim.
If he doesn't have the slave cylinder at hand I'll look at my options.
[TaSK]
IBA: 33616
Old 07-09-2012, 01:05 PM   #10
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,147
This is what a pool of DOT-4 looks like.
I managed to ride almost 1000 km, and have arrived at the dealer. A new cylinder will arrive tomorrow and I hope he is talended enough to install it when I remove the wheel and the shock. If not I will have to remove the swing arm.
The slipping has gotten worse, but if I can stop the leak now and the slipping doesn't get worse we'll make it home.
Home, by the way, is at least 4.000 km away from here.
Thanx for the tip on the brake cleaner. I'll try to find out what they call it here in Norway, try t5o get hold of some, and see what happens.
[TaSK]
IBA: 33616
Old 07-09-2012, 02:37 PM   #11
Jazz62
Oddometer: 689
My thoughts are with you buddy. Enjoy the adventure and be careful.
Jazz62 is online now   Reply With Quote
Old 07-09-2012, 08:34 PM   #12
BluByU
BluByU's Avatar
Oddometer: 403
Did you park your GS too close to a HD? Has it learned to "mark its territory"
Yes you will make it home. Just do not come to a complete stop and learn to shift without a clutch..
OH Ya maybe time to replace the slave cylinder
Sorry to be harsh, I feel your pain BTDT
BluByU is offline   Reply With Quote
Old 07-09-2012, 10:06 PM   #13
Zoef zoef
Oddometer: 256
Hei,
I hope the dealer can fix it, and you can have a good ride.
As for the brake cleaner, at Biltema it is called: bremserens.
There is one in Trondheim too (Østre Rosten 22, 7075, Trondheim), but any other car / motorcycle maintenance shop should have it.
Success and good luck!
Old 07-09-2012, 10:53 PM   #14
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,147
Originally Posted by Zoef zoef View Post
Hei,
Tusen takk!
We're heading your way!
[TaSK]
IBA: 33616
Old 07-13-2012, 02:57 PM   #15
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,147
By cutting off a centimeter of so of a 4mm key, it is not very hard to replace the slave cylinder without removing the swing arm.
I didn't have time to remove the starter so I haven't tried to clean the clutch with brake cleaner.. I'll just have to ride on and sww what happens.
[TaSK]
IBA: 33616
Times are GMT -7.   It's 01:52 AM.
