Old 07-11-2012, 12:34 AM   #1
yvs OP
Oddometer: 4
950: noise from gearbox
Hi, people! :)
There is a suspisious noise from gearbox, when it works on neutral gear. It seems like ringing sound of rotating gears (really? ) ...but it's too loud. But if I switch any gear, this sound vanish. Is this normally for LC8 or mainshaft/countershaft/gears inspection/replacing awaiting me soon?
yvs is offline   Reply With Quote
Old 07-11-2012, 12:55 AM   #2
TcRulz
Oddometer: 270
gearbox noise
Does the noise just go when you put it in gear or just when you pull the clutch in.
TcRulz is offline   Reply With Quote
Old 07-11-2012, 01:30 AM   #3
yvs OP
Oddometer: 4
Just when I put it in gear, pulling the clutch doesn't change the situation
I dont't know, maybe it's normally, but in comparision with my previous Honda's it's too loud. It's my first KTM :)
Old 07-11-2012, 01:45 AM   #4
Sumi
Sumi's Avatar
Oddometer: 1,145
See, that's the problem.. You are comparing it to a Honda.. You should compare it to a steel cooking pot beeing shaked, with bearing balls in it:))
2005.5 950 Adventure
Old 07-11-2012, 01:59 AM   #5
yvs OP
Oddometer: 4
It that case, I'll be calm!
Old 07-11-2012, 02:35 AM   #6
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,125
I suggest you have a look at your clutch inner parts.
Could be worth it but anyway is not too much of a hassle. You will not loose but some drops of oil.
Cheers.
There is always a reason!!
Old 07-11-2012, 02:55 AM   #7
yvs OP
Oddometer: 4
Times are GMT -7.   It's 08:13 AM.
