Old 07-12-2012, 09:18 PM   #16
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,201
Originally Posted by Oz-Strom View Post
Meaning? It was just an opinion ya know
Oh, it was for the other strom, with the lot longer user name. Too long to write.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is online now   Reply With Quote
Old 07-12-2012, 09:23 PM   #17
slowbike smallpenis
Tester of Tooheys Old
slowbike smallpenis's Avatar
Oddometer: 19,772
Similar to the (now discontinued) Aprilia Pegaso Trail and Strada in concept. Could be a popular mount for a mid range ADV ride.
Engine looks outwardly just like the usual Rotax offering .. wheres the gain I wonder? - pretty plastics and a name change over the 650 X range - mind you the seat looks a bit more comfortable
Fuel load is up by 5lts and still looks to be positioned behind the engine
No sump Guard - how ferking tight is BMW
Illusion is the first of all pleasures
slowbike smallpenis is offline   Reply With Quote
Old 07-12-2012, 09:35 PM   #18
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 770
From original post
"A new lighter forged piston bumps up the compression ratio (12.3:1) and much hotter camshafts acting on bigger valves help inject a little more animal into the engine."
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 07-13-2012, 12:45 AM   #19
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,328
power gains
power to help move the big heavy thing
For example, a new mould was developed for the cylinder head so as to produce even more aerodynamically optimised ducting of the intake and outlet ducts for increased power. As part of the redesign of the cylinder head, the spark plug thread was also reworked, involving a reduction in thread diameter from 12 to 10 mm. This results in an even more effective flow of cooling fluid in the spark plug area as well as enhanced heat dissipation and therefore a more favourable engine thermal dynamics.
Increased compression, new camshafts, larger valves.
Other features which contribute to the increased engine output are a new fuel-injection system, newly-designed camshafts with longer timing, new valve lift curves and deeper valve strokes. In combination with enlarged valve head diameters in the intake and outlet valves, the optimised intake and outlet camshaft enables improved filling and a more effective charge cycle. Another contribution to the performance enhancement of the single-cylinder engine is the increase in the compression ratio from 11.5 to 12.3:1.
um no comp for the dr
i believe the dr can go over heavy terrian
In conjunction with the constant-mesh 5-speed gearbox, the powerful and high-revving single-cylinder engine in the Husqvarna TR 650 Strada puts in an especially impressive performance on country roads, while a full torque curve and spontaneous response also allow supreme off-road excursions over light terrain on the TR 650 Terra.
why couldn't they just stick the motor in 630 chassis
that would put the wind up the dr's and klr's
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 07-13-2012, 12:57 AM   #20
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Was all looking good until i saw the weight. 186KG... it should be a twin with that figure.
and then the 190mm suspension travel...
NEXT.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 07-13-2012, 01:17 AM   #21
Phil_Fong
Labelled Extremist
Phil_Fong's Avatar
Oddometer: 13,289
Originally Posted by outback jack View Post
Could be a good replacement for a 990.
not quite, but its certainly showing its potential
tEAM nONG - Quorn Schnitzel Club
Phil_Fong is offline   Reply With Quote
Old 07-13-2012, 03:00 AM   #22
PBee
_
PBee's Avatar
Oddometer: 9,232
A bit loose in the rear end.
Is that pouch an accessory? Good place for me spanners.
QUORN SCHNITZEL CLUB Est 2011.
When in the FLINDERS RANGES SA stay at the
ANGORICHINA VILLAGE
PBee is offline   Reply With Quote
Old 07-13-2012, 03:48 AM   #23
circuit1
circuit1's Avatar
Oddometer: 74
See, your friendly Husky dealer for a test ride,..........Yes please
Growing old is manditory, growing up is optional.....
circuit1 is offline   Reply With Quote
Old 07-13-2012, 04:48 AM   #24
PiJiL
PiJiL's Avatar
Oddometer: 380
I am in......, always wanted a bmw650 with more grunt and a decent front end......
PiJiL is offline   Reply With Quote
Old 07-13-2012, 05:36 AM   #25
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,056
[QUOTE=WILL_S;19118690
that would put the wind up the dr's and klr's[/QUOTE]
Couldn`t agree more . That would have made it a very tempting bike . Why bother making it if they only give it 190mm travel .
Brute is offline   Reply With Quote
Old 07-13-2012, 05:42 AM   #26
PiJiL
PiJiL's Avatar
Oddometer: 380
190mm of travel makes a better all rounder
Old 07-13-2012, 06:10 AM   #27
Muddler
Muddler's Avatar
Oddometer: 779
190mm was the SM model specs. Maybe the DS has more?
The weight is a concern, but I must say all the cast alloy on my XCH used to worry me. Could be a good Adventure bike, and no heavier then a Tenere660 or a KLR.
Muddler is offline   Reply With Quote
Old 07-13-2012, 03:23 PM   #28
outback jack
outback jack's Avatar
Oddometer: 6,915
Correct, however once you add the pieces that are missing like part fairings, screens, etc etc that are standard on a KLR or Tenere, then it will be a real porker!
There's something ugly about a NEW bike on a trailer.
CCC ride Cattle, Coal & Cane or Captains Crossing & Castlemaine.
http://www.advrider.com/forums/showt...1#post17025601
outback jack is offline   Reply With Quote
Old 07-13-2012, 05:33 PM   #29
Muddler
Muddler's Avatar
Oddometer: 779
True. Actually, looking at the photos, I don't know how they managed to get that much weight in it. My old Dominator was twin exhaust and only weighed 165. Steel frame is a good thing, but I wouldn't think it would account for 40kg increase? Maybe that's wet weight? "road ready".
Old 07-13-2012, 05:45 PM   #30
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,328
unladen weight: 165 kg
weight fully fuelled: 183 kg
Times are GMT -7.   It's 01:55 AM.
