Old 12-23-2012, 11:57 AM   #466
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,224
Originally Posted by Rus View Post
Yep, add mine to that list, replaced at approx 7,000 kms. Plus snapped the rear subframe at 10,000 kms. Apart from these two known issues the bike has run faultlessly & I'm very happy with it.
Add temp sender to the list.In 5 months almost everything warned about i've had[leaky clutch,breather hose,airbox inserts,temp sender,steerer bearings] ,except subframe which i'll sort before it happens.
Maybe a friday bike
Would i sell it .....nope
Fantastic bike with a few teething issues
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 12-23-2012, 05:32 PM   #467
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
will it do a simpson crossing as well as a DR?
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 12-23-2012, 05:50 PM   #468
Muddler
Muddler's Avatar
Oddometer: 751
Aqualine working on a tank yet??
Muddler is offline   Reply With Quote
Old 12-23-2012, 06:15 PM   #469
glitch_oz
glitch_oz's Avatar
Oddometer: 1,741
According to one dealer: yes, a 25l jobbie supposedly.
Cheers
pete
www.AusTouring.com
A Dozen Years Of Adventures
glitch_oz is offline   Reply With Quote
Old 12-23-2012, 06:32 PM   #470
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
Who would know until someone tries?
And then at least 5 or 10 people try etc etc etc.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 12-23-2012, 06:36 PM   #471
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,884
Seem common on the 630
I have heard of a couple of te630's eating steering head bearings. 1 I know of has had 3 sets in under 10 oooks, and I know that one for sure. The others are just hearsay.
I like the sound of this bike, it would be great to see other manufactures have a crack at this market
Originally Posted by WILL_S View Post
I dunno we'll see when it comes apart
Did hear there is a recess in the steerer that will allow mud,grit,water in
At least a few 630 have had this prob to date
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 12-23-2012, 08:17 PM   #472
Muddler
Muddler's Avatar
Oddometer: 751
Nice, I reckon this will make it a great outback bike.
Dammit, I just got rid of the XC, now I want another one (yes, I know this is different)
Old 12-23-2012, 08:50 PM   #473
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 15,946
Just "emptied" the first full tank 283 k's till the light came on.
Pulling some you beaut mono's and I am shit at 'em despite years of practice.
Pick it up on the throttle in first, through second no probs, into third it drops gently down. Nothing but good things to say - cant stop grinning.
7th Day Adventourist.
Re-incarnated
Terrafied
The best cure for Sea Sickness, is to sit under a tree.
davorallyfan is offline   Reply With Quote
Old 12-23-2012, 09:56 PM   #474
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
That's pretty good Davo, how much is in reserve, or is it just an empty light before it stops?
xronly
Old 12-23-2012, 10:02 PM   #475
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,261
that sounds like seriously good range from a 14L tank, davo. the US owners have been saying it's very economical and that sort of mileage means i wouldn't be looking at safarit tank with the rides we do.
did you find out how much was left when the light came on, around two litres as usual?
trouble keeping it up in third sounds about right... the DR650 is about 20kg lighter and would mono fine in third (standard gearing) but very difficult in fourth without sacrifices to the gods of levitation.
B1 is offline   Reply With Quote
Old 12-23-2012, 10:16 PM   #476
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
One tooth down at the front will help you Barry!
xronly
Old 12-23-2012, 10:31 PM   #477
B1
B1's Avatar
Oddometer: 3,261
maybe two for the terra. there's photographic evidence the terra can mono in both directions...
Old 12-23-2012, 10:46 PM   #478
Rus
Rus's Avatar
Oddometer: 370
2.5 litres, so DRF achieved 283kms on 11.5 litres which is a lot better than the 630 can do. Having said that, DRF may be taking it a little easy during the run-in period.
My 630's economy deteriorated markedly after run in, due to being able to use full throttle and addition of JD EFI kit. On its best day I'd be very lucky to get 200kms from it's 12 litres, & that'd be moderate throttle & open cruising. I have hit reserve (10 of 12 litres) as low as 140kms.
Regards,
Rus
Rus is offline   Reply With Quote
Old 12-24-2012, 03:53 AM   #479
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,224
How does an open hollow steerer get water into the bearings, water goes straight through. Was hollow on my BMW too and had no problems. You could always buy a H cap to fit inside the steerer.
Had a look down the steerer tube and i think i can see where water grit etc can get in.Had a bit of dirt down there.
Bit of a design fault on the 630.Just replace the bearings and it'll happen again.
The slot isn't needed for the steering lock on the te so i'm guessing the triples are left overs from another model.Probably fill the slot and run a couple of plugs to stop anything entering.
Does the terra run the same setup?
Old 12-24-2012, 04:02 AM   #480
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
Pop along to Clark Rubber and find a rubber plug that fits the top.
xronly
Times are GMT -7.   It's 10:06 AM.
