Old 12-24-2012, 03:14 AM   #481
Muddler
Muddler's Avatar
Oddometer: 779
Originally Posted by Rus View Post
2.5 litres, so DRF achieved 283kms on 11.5 litres which is a lot better than the 630 can do. Having said that, DRF may be taking it a little easy during the run-in period.
My 630's economy deteriorated markedly after run in, due to being able to use full throttle and addition of JD EFI kit. On its best day I'd be very lucky to get 200kms from it's 12 litres, & that'd be moderate throttle & open cruising. I have hit reserve (10 of 12 litres) as low as 140kms.
Regards,
Rus
I reckon that economy will be pretty standard. You have to be really caning it to do worse then 20km/L with the FI Rotax on the X-Challenge.
Muddler is offline   Reply With Quote
Old 12-24-2012, 06:49 PM   #482
TheStromACT
Have DL will travel
TheStromACT's Avatar
Oddometer: 118
Terra (firma?)
Originally Posted by davorallyfan View Post
I tried to hit the roughest bits on Captains Flat Rd but could not shake it off line.
Slim with a big plastic rack - for a plastic rack it seems pretty solid.
I can find 3 possibly 4 potential mount points on both sides of the bike for pannier racks -2 off the rack and 2 off the pillion pegs / steel mount. It has a steel subframe and swingarm (some people think that this is a bad thing).
Hey DRF - had a ride of Gregs Demo yesterday and was quite impressed with it. Seems like a good package. The factory panniers are the new givi Trekka jobbies. Just my thoughts but if after pannier frames, get the givi frames, then remove the top and the bottom mounting bits and you have a flat pannier frame to strap on soft panniers. Have done this with my strom and it works well. Best of both worlds as I can quickly re attach the mounting hardware and fit the hard panniers for two up touring.
TheStromACT is offline   Reply With Quote
Old 12-24-2012, 09:00 PM   #483
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,289
TSACT
Done a bit of touring... Got a solution in mind to fabricate a mount need to turn up some sacers to keep the rack and look - I want to swap panneirs between my bikes - less unpacking (soft/hard luggage) I don't think the Terra is a two up bike - at least for any great distance (younger folk might disagee).
DRF
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is offline   Reply With Quote
Old 12-24-2012, 09:29 PM   #484
McChecker
Oddometer: 33
Terra (firma)
Teasing yourself again Doug????
Cheers,
P Mc
McChecker is offline   Reply With Quote
Old 12-24-2012, 11:28 PM   #485
davorallyfan
Commonist
Oddometer: 16,289
Cheers,
P Mc
Hi Doug
Re-incarnated
Terrafied
Old 12-25-2012, 03:42 PM   #486
TheStromACT
Have DL will travel
Oddometer: 118
Cheers,
P Mc
no just curious, Greg offered, I couldn't say no.
DRF, fair enough was just an idea. Full of ideas - some good, some well you know.
Old 12-25-2012, 04:28 PM   #487
Bigem
Bigem's Avatar
Oddometer: 2,565
When just cruising behind other guys I quite often got 360-370ks out the 16litres in my Dakar, bloody impressive mileage.
These Rotax engines are phenominal on fuel.
A while back, the group I was riding with up north was so slow that between naps I had to drain fuel out of my F8GS tank because it was producing its own and over-flowing!!
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is online now   Reply With Quote
Old 12-25-2012, 05:12 PM   #488
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,336
Originally Posted by WILL_S View Post
Had a look down the steerer tube and i think i can see where water grit etc can get in.Had a bit of dirt down there.
Bit of a design fault on the 630.Just replace the bearings and it'll happen again.
The slot isn't needed for the steering lock on the te so i'm guessing the triples are left overs from another model.Probably fill the slot and run a couple of plugs to stop anything entering.
Does the terra run the same setup?
Appologies to the 650 thread, but curiousity had me check some pics i took when playing with the 610. I have had no issue with steering head bearings. Looks to be a similar set up Will. They even went to the trouble of deburring the hole on the 630
poppy screwed with this post 12-25-2012 at 05:23 PM
poppy is offline   Reply With Quote
Old 12-25-2012, 10:13 PM   #489
davorallyfan
Commonist
Oddometer: 16,289
Standard gearing 5,500 rpm is bang on 140kph.
Still very impressed with the silky smooth flexible engine.
When out for an hour today.
Re-incarnated
Terrafied
Old 12-26-2012, 01:03 AM   #490
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,301
doug i've posted this phenomenon over in the 610 thread
so the mighty 650 can get on with business without the old bikes
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 12-26-2012, 01:38 AM   #491
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,106
What do you think Will, have you had a chance to test ride or look at one at Caboolture yet?
Tossing up whether it could replace the Tranny or not?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 12-26-2012, 02:03 AM   #492
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,301
Not yet , got me 6000 service coming up
I'll have a looksy then
Old 12-27-2012, 06:29 PM   #493
Chuffa
TR650 Terra
Chuffa's Avatar
Oddometer: 163
For those in Perth, Peter @ T4B has just had 2 Terra's come in.
Not licensed yet though.
One of them is mine
Chuffa is offline   Reply With Quote
Old 12-27-2012, 09:09 PM   #494
iconman
Good vibrations
iconman's Avatar
Oddometer: 1,057
Yes, I had a close look at one of them. Not bad... would be a bit low for me though.
13 KTM EXC 300 Ring-a-ding-ding!
09 DRZ 400 E Gone to a new home
05 KTM 640 Adventure Gone but not forgotten
03 Honda CT110 'Postie' Abducted by an alien
98 Suzuki DS 80 Gone to a new home
iconman is offline   Reply With Quote
Old 12-27-2012, 09:27 PM   #495
bully1
bully1's Avatar
Oddometer: 4,590
Stopped by for a look this morning, I like it a LOT, as I want 2, 1 for me and 1 for Dremented, we may have to wait till Feb. pete is goung to see what he can do next week.
'02 GSX 1400 outfit........lot's of grin factor
'11 Husky TE 630.......tyre shredder
'06 HUSKY TE610 x 2............ for the boys
'92 R100GSPD ( modified)...........slow and easy
bully1 is online now   Reply With Quote
Times are GMT -7.   It's 09:53 PM.
