Old 07-13-2012, 07:30 AM   #1
sharkojoints OP
is a bit slow sometimes..
Oddometer: 72
Help! What have I fried?
Bike is a 1990 R80RT
I am no fan of electrics, and it's something I avoid.
I know I should have disconnected the battery straight away, but it would have helped if the previous owner had fitted a female bullet to the live...
Anyway, whilst removing the fairing I managed to briefly ground out the red live from the battery to the ignition switch.
The bike is coming together again now, but when I tun the ignition on I have:
1. No lights on the dash
2. Headlights and indicators work fine
3. Relay to the rear of the tank clicks
4. Starter button is dead
Both fuses are intact.
What should I be checking? There's nothing obvious wrong! Thanks in advance..
sharkojoints is offline   Reply With Quote
Old 07-13-2012, 07:36 AM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,551
Kill switch?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 07-13-2012, 07:50 AM   #3
sharkojoints OP
Oddometer: 72
Originally Posted by Airhead Wrangler View Post
Kill switch?
Genius.
I am officially an idiot.
Old 07-13-2012, 07:54 AM   #4
RaystheBMW
1986 R65
RaystheBMW's Avatar
Oddometer: 171
Well good catch! Does anybody actually use their kill switch? I don't, and I don't even think I'd remember it's there in an emergency.
RaystheBMW is offline   Reply With Quote
Old 07-13-2012, 08:11 AM   #5
Airhead Wrangler
Adios Mexico
Oddometer: 6,551
Genius.
I'm pretty sure just about everyone has done that once and only once. That'll be the first thing you check next time.
I use it. MSF really hammers that procedure into you. "Valve, key thumb" to start the bike, "thumb, key, valve" to park it. Valve = petcock, thumb = kill switch. Once it's part of your procedure you don't even think about it. The few times that I've needed to use it (stuck throttle), I went straight for it without thinking. Thanks, MSF.
Airhead Wrangler screwed with this post 07-13-2012 at 08:17 AM
Old 07-13-2012, 08:32 AM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,735
I use mine sometimes, like when I want to leave the bike in gear on a hill and my hands are too busy to reach the ignition switch. I have remembered to use it in a lay down.
---Albert Einstein
Old 07-13-2012, 09:44 AM   #7
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
the last time I used the kill switch, I was backing into a space in front of a restaurant and wanted to kill exhaust fumes quickly. Of course I neglected to turn off the ignition switch which I quickly forgot about and when in to eat and socialize. 2 hours later. I had killed the battery.
So that's why they call it a kill switch!
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 07-13-2012, 09:56 AM   #8
JustinP
JustinP's Avatar
Oddometer: 1,973
Genius.
Look on the bright side. I'd rather feel stupid, then have a much bigger problem to deal with
FAST: 2004 non-ABS "Silver Bullet" FJR - FASTER: 2008 Touring/Endurance Hayabusa - SLOW: 1997 R1100GS
Quality LED Lighting - ADV Discount inside:) - LEDRider LED motorcycle lights
JustinP is online now   Reply With Quote
Old 07-13-2012, 10:39 AM   #9
Rapid_Roy
finally understands
Rapid_Roy's Avatar
Oddometer: 26,153
Kill switch?
Thread killer!
It is better to have less thunder in the mouth and more lightning in the hand.
Rapid_Roy is offline   Reply With Quote
Old 07-13-2012, 10:46 AM   #10
sharkojoints OP
Oddometer: 72
Too right.
I was having nasty thoughts of melted diodes and expensive parts...
Anyway, pics of progress and (nearly) finished article on the other thread:
http://www.advrider.com/forums/showt...9#post19120949
Times are GMT -7.   It's 07:59 AM.
